Author Topic: CWindow: YouTube example  (Read 2689 times)
  • Master Member
    • Jos
« on: September 09, 2015, 11:06:33 AM »
And the fun begins!
' Microsoft Windows
' File: CW_YouTube_HDPI.fbtpl
' Contents: CWindow YouTube example (High DPI)
' Copyright (c) 2015 Jose Roca. Freeware. Use at your own risk.
#define unicode
#INCLUDE ONCE "windows.bi"
USING Afx.CWindowClass
   END WinMain(GetModuleHandle(""), NULL, COMMAND(), SW_NORMAL)
' Window procedure
   FUNCTION = 0
   SELECT CASE AS CONST uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
      CASE WM_SIZE
            ' // Resize the buttons
            DIM pWindow AS CWindow PTR
            pWindow = CAST(CWindow PTR, GetPropW(hwnd, "CWINDOWPTR"))
            pWindow->MoveWindow GetDlgItem(hwnd, 1001), 0, 0, pWindow->ClientWidth, pWindow->ClientHeight, TRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
' Build the YouTube script
FUNCTION BuildYouTubeScript (BYVAL strCode AS STRING, BYVAL nWidth AS LONG, BYVAL nHeight AS LONG) AS STRING
   ' // Build the URL
   DIM strURL AS STRING = "http://www.youtube.com/v/" & strCode
   ' // Build the web page. Remember to always start it with "MSHTML:".
   DIM s AS STRING
   s  = "MSHTML:<!DOCTYPE html>" & CHR(13, 10)
   s += "<html>" & CHR(13, 10)
   s += "<head>" & CHR(13, 10)
   s += "<meta http-equiv='MSThemeCompatible' content='Yes'>" & CHR(13, 10)
   s += "<title>YouTube video</title>" & CHR(13, 10)
   s += "" & CHR(13, 10)
   s += "</head>" & CHR(13, 10)
   s += "<body scroll='no' style='MARGIN: 0px 0px 0px 0px'>"
   s += "<object width=" & STR(nWidth) & " height=" & STR(nHeight) & ">" & _
        "<param name='movie' value=" & strURL & "</param>" & _
        "<embed src=" & strURL & _
        " type='application/x-shockwave-flash' width='100%' height='100%'>" & _
        "</embed></object>"
   s += "</body>" & CHR(13, 10)
   s += "</html>" & CHR(13, 10)
   FUNCTION = s
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   pWindow.Create(NULL, "CWindow YouTube Test", @WndProc)
   pWindow.Center
   DIM hLib AS ANY PTR
   hLib = DylibLoad("atl.dll")
   DIM AS SUB AtlAxWinInit
   AtlAxWinInit = DylibSymbol(hLib, "AtlAxWinInit")
   AtlAxWinInit()
   DIM strCode AS STRING = "_oAgkTwFRuM"   ' --> Change me: 11 character video code
   DIM s AS STRING = BuildYouTubeScript(strCode, pWindow.ClientWidth, pWindow.ClientHeight)
   pWindow.AddControl("AtlAxWin", pWindow.hWindow, 1001, s, 0, 0, 0, 0, WS_VISIBLE)
« Last Edit: September 10, 2015, 12:09:52 AM by Jose Roca »
