Author Topic: CWindow: Petzold's Alternate and Winding Fill Modes  (Read 1710 times)
  • Master Member
    • Jos
« on: September 11, 2015, 01:30:24 AM »
' Microsoft Windows
' File: CW_Petzold_AltWind.fbtpl - Template
' This program is a translation/adaptation of the ALTWIND.C-Alternate and Winding Fill
' Modes Program © Charles Petzold, 1998, described and analysed in Chapter 5 of the book
' Programming Windows, 5th Edition.
' Displays the figure twice, once using the ALTERNATE filling mode and then using WINDING.
' Copyright (c) 2015 Jose Roca. Freeware. Use at your own risk.
#define unicode
#INCLUDE ONCE "windows.bi"
USING Afx.CWindowClass
' Window procedure
   DIM hdc AS HDC
   DIM i AS LONG
   DIM ps AS PAINTSTRUCT
   DIM apt(9) AS POINT
   STATIC aptFigure(9) AS POINT
   STATIC cxClient AS LONG
   STATIC cyClient AS LONG
   FUNCTION = 0
   SELECT CASE AS CONST uMsg
      CASE WM_CREATE
         aptFigure(0).x = 10 : aptFigure(0).y = 70
         aptFigure(1).x = 50 : aptFigure(1).y = 70
         aptFigure(2).x = 50 : aptFigure(2).y = 10
         aptFigure(3).x = 90 : aptFigure(3).y = 10
         aptFigure(4).x = 90 : aptFigure(4).y = 50
         aptFigure(5).x = 30 : aptFigure(5).y = 50
         aptFigure(6).x = 30 : aptFigure(6).y = 90
         aptFigure(7).x = 70 : aptFigure(7).y = 90
         aptFigure(8).x = 70 : aptFigure(8).y = 30
         aptFigure(9).x = 10 : aptFigure(9).y = 30
      CASE WM_SIZE
         cxClient = LOWORD(lParam)
         cyClient = HIWORD(lParam)
      CASE WM_PAINT
         hdc = BeginPaint(hwnd, @ps)
         SelectObject hdc, GetStockObject(GRAY_BRUSH)
         FOR i = 0 TO 9
            apt(i).x = cxClient * aptFigure(i).x / 200
            apt(i).y = cyClient * aptFigure(i).y / 100
         SetPolyFillMode hdc, ALTERNATE
         Polygon hdc, @apt(0), 10
         FOR i = 0 TO 9
            apt(i).x = apt(i).x + cxClient / 2
         SetPolyFillMode hdc, WINDING
         EndPaint hwnd, @ps
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   ' // Set process DPI awaree
   AfxSetProcessDPIAware
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "Alternate and Winding Fill Modes", @WndProc, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT, CW_USEDEFAULT)
   pWindow.Center
