Having Trouble with SQL Tool and FF3 (PB version)
Started by James Reeder, March 15, 2016, 02:47:25 PM
James Reeder
I have a multi-threaded application that I am adding a feature that requires SQL support.  I have read the SQL Tools documentation and have used it for many years, however, I am running into a runtime issue where I get an error setting up the SQL_Threads
I am using the #LINK version of SQL Tools version 3.14
My code is placed in FF_WinMain and basically looks like the following (minus the error checking conditionals)
SQL_Authorize %mycode
Sql_Initialize(1,32,32,3,3,0,0,0)
SQL_Thread(%THREAD_MAX,16)  <--- I get a runtime error: Untrapped Error #9 (Subscript/Pointer out of Range)
Is FF_WinMain executed in the primary thread (Thread 0) or is it in another thread of execution?  I assume it is the primary thread.
If it is not the primary thread, where would one setup the initialization of SQL Tools?
I am check here before contacting Perfect Sync for support.
Klaas Holland
This is my way of connecting to a DataBase.
Function FF_WINMAIN( ByVal hInstance     As Dword, _
                     ByVal hPrevInstance As Dword, _
                     ByVal lpCmdLine     As Asciiz Ptr, _
                     ByVal iCmdShow      As Long ) As Long
   ' If this function returns TRUE (non-zero) then the actual WinMain will exit
   ' thus ending the program. You can do program initialization in this function.
    Function = %FALSE    'return %TRUE if you want the program to end.
    SQL_Authorize %MY_SQLT_AUTHCODE
    SQL_Init
'    SQL_ErrorClearAll
    SQL_OpenDB "DSN=SQLxxxxxxx"
Klaas
James Reeder
Thank you all.  I figured that FF_WinMain is within the primary thread, but I wanted to verify.
I may have found a bug in SQL Tools SQL_Thread function. I will need to contact Perfect Sync to verify.
When the SLL version is linked in, the function fails with an Run Time error 9.  Using the DLL version, I receive ERROR_BAD_PARAM_VALUE.
