Pages: [1] 2
Author Topic: mCtrl grid example  (Read 2867 times)
James Fuller
  • Senior FireFly Member
mCtrl grid example
« on: June 14, 2016, 07:59:56 PM »
Here is my first grid attempt.
James
#define unicode
#Include Once "windows.bi"
#Include Once "win/CommCtrl.bi"
#Include Once "Afx/CWindow.inc"
#Include Once "mCtrl/mCtrl.bi"
#define CBCTLMSG HIWORD(wParam)
#define CBCTL LOWORD(wParam)
#define CBHNDL hWnd
#define CBHWND hWnd
#define CBLPARAM lParam
#define CBWPARAM wParam
#define CBMSG uMsg
#define IDC_GRID 100
Using Afx.CWindowClass
Dim Shared As HWND ghwndGrid
Declare Function WinMain (Byval hInstance As HINSTANCE, _
                          Byval hPrevInstance As HINSTANCE, _
                          Byval szCmdLine As ZSTRING PTR, _
                          Byval nCmdShow As LONG) As LONG
Sub LoadGrid()
    Dim hTable As MC_HTABLE
    Dim tc As MC_TABLECELL
    Dim As wstring *32 buffer
    Dim As Long row,height
    '/* Set size of the table to 8 columns and 16 rows. */
    SendMessage(ghwndGrid, MC_GM_RESIZE, MAKEWPARAM(8, 16), 0)
    tc.fMask = MC_TCMF_TEXT
    tc.pszText = @buffer
    For row = 0 To 15
        buffer ="Row:" & Str$(row)
        SendMessage ghwndGrid, MC_GM_SETCELL, MAKEWPARAM(MC_TABLE_HEADER, row), Cast(LPARAM, @tc)
    Next
        '/* Set a text of some cell */
    buffer = "Hello World"
    SendMessage ghwndGrid, MC_GM_SETCELL, MAKEWPARAM(1, 1), Cast(LPARAM, @tc)
    '/* We can also get the data model of the grid control and manipulate it directly. */
    hTable = Cast(MC_HTABLE,SendMessage(ghwndGrid, MC_GM_GETTABLE, 0, 0))
    tc.fMask = MC_TCMF_TEXT OR MC_TCMF_FLAGS
    buffer = "top left"
    tc.dwFlags = MC_TCF_ALIGNLEFT OR MC_TCF_ALIGNTOP
    mcTable_SetCell(hTable, 4, 10, @tc)
    buffer = "top center"
    tc.dwFlags = MC_TCF_ALIGNCENTER OR MC_TCF_ALIGNTOP
    mcTable_SetCell(hTable, 5, 10, @tc)
    buffer = "top right"
    tc.dwFlags = MC_TCF_ALIGNRIGHT OR MC_TCF_ALIGNTOP
    mcTable_SetCell(hTable, 6, 10, @tc)
    buffer = "middle left"
    tc.dwFlags = MC_TCF_ALIGNLEFT OR MC_TCF_ALIGNVCENTER
    mcTable_SetCell(hTable, 4, 11, @tc)
    buffer = "middle center"
    tc.dwFlags = MC_TCF_ALIGNCENTER OR MC_TCF_ALIGNVCENTER
    mcTable_SetCell(hTable, 5, 11, @tc)
    buffer = "middle right"
    tc.dwFlags = MC_TCF_ALIGNRIGHT OR MC_TCF_ALIGNVCENTER
    mcTable_SetCell(hTable, 6, 11, @tc)
    buffer = "bottom left"
    tc.dwFlags = MC_TCF_ALIGNLEFT OR MC_TCF_ALIGNBOTTOM
    mcTable_SetCell(hTable, 4, 12, @tc)
    buffer = "bottom center"
    tc.dwFlags = MC_TCF_ALIGNCENTER OR MC_TCF_ALIGNBOTTOM
    mcTable_SetCell(hTable, 5, 12, @tc)
    buffer = "bottom right"
    tc.dwFlags = MC_TCF_ALIGNRIGHT OR MC_TCF_ALIGNBOTTOM
    mcTable_SetCell(hTable, 6, 12, @tc)
    '/* Set heights of few rows to a different value. */
    height = LOWORD(SendMessage(ghwndGrid, MC_GM_GETROWHEIGHT, 10, 0))
    height *= 2
    SendMessage(ghwndGrid, MC_GM_SETROWHEIGHT, 10, MAKEWPARAM(height, 0))
    SendMessage(ghwndGrid, MC_GM_SETROWHEIGHT, 11, MAKEWPARAM(height, 0))
    SendMessage(ghwndGrid, MC_GM_SETROWHEIGHT, 12, MAKEWPARAM(height, 0))
End Sub
Function WndProc (Byval hWnd As HWND, Byval uMsg As UINT, Byval wParam As WPARAM, Byval lParam As LPARAM) As LRESULT
    Select Case uMsg
        Case WM_CREATE
        Case WM_NOTIFY
            Dim As NMHDR Ptr hdr = Cast(NMHDR Ptr,lParam)
            If hdr->idFrom = IDC_GRID AND hdr->code = MC_GN_ENDLABELEDIT Then
                '/* Accept the new text when user edits a cell label. Application
                ' * should implement this notification whenever it created the
                ' * grid control with the style MC_GS_EDITLABELS. */
                Return TRUE
            EndIf
        Case WM_SIZE
            '/* Resize the grid control so it takes all space of the top
            ' * level window */
            If CBWPARAM = SIZE_RESTORED OR CBWPARAM = SIZE_MAXIMIZED Then
                SetWindowPos(ghwndGrid, NULL, 5, 5, LOWORD(lParam)-10, HIWORD(lParam)-10, SWP_NOZORDER)
            EndIf
        Case WM_SETFONT
            Dim As MC_GGEOMETRY geom
            SendMessage(ghwndGrid, WM_SETFONT, wParam, lParam)
            '/* Reset grid's geometry to defaults according to the font. */
            SendMessage(ghwndGrid, MC_GM_SETGEOMETRY, 0, 0)
            '/* Make it to use a bit more space. */
            geom.fMask = MC_GGF_ROWHEADERWIDTH OR MC_GGF_DEFCOLUMNWIDTH
            SendMessage ghwndGrid, MC_GM_GETGEOMETRY, 0, Cast(LPARAM,@geom)
            geom.wRowHeaderWidth = 50
            geom.wDefColumnWidth += geom.wDefColumnWidth / 2
            SendMessage ghwndGrid, MC_GM_SETGEOMETRY, 0, Cast(LPARAM,@geom)
            Return FALSE
        Case WM_SETFOCUS
            SetFocus ghwndGrid
            Return FALSE
        Case WM_DESTROY
            PostQuitMessage(0)
            Exit Function
    Function = DefWindowProc(hWnd, uMsg, wParam, lParam)
    Dim As Boolean retval
    If mcGrid_Initialize() = FALSE Then
        AfxMsg("NO")
        Exit Function
    EndIf
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   Dim As CWindow pWindow
   pWindow.Create(NULL, "Edit controls", @WndProc)
   pWindow.SetClientSize 600, 440
   pWindow.AddControl(MC_WC_GRID,,IDC_GRID,"",0,0,0,0, _
                       WS_CHILD OR WS_VISIBLE OR WS_TABSTOP OR _
                    MC_GS_COLUMNHEADERALPHABETIC OR MC_GS_ROWHEADERNORMAL OR _
                    MC_GS_RESIZABLECOLUMNS OR MC_GS_RESIZABLEROWS OR _
                    MC_GS_FOCUSEDCELL OR MC_GS_COMPLEXSEL OR MC_GS_SHOWSELALWAYS OR _
                    MC_GS_EDITLABELS,WS_EX_CLIENTEDGE)
   pWindow.Center
   ghwndGrid = pWindow.ControlHandle(IDC_GRID)
   LoadGrid()
   Function = pWindow.DoEvents(nCmdShow)
   mcGrid_Terminate()
  • Master FireFly Member
    • Josť Roca Software
Re: mCtrl grid example
« Reply #1 on: June 14, 2016, 09:04:41 PM »
Yet another control that is not DPI aware.
The programmer should implement a message to pass the DPI and do scaling.
e.g. SendMessage hCtrl, <message>, rxRatio, ryRatio
« Last Edit: June 14, 2016, 09:07:59 PM by Josť Roca »
« Reply #2 on: June 14, 2016, 09:15:58 PM »
Hi Jose,
I am curious as to how my grid looks on your system. It has been a while since I worked on the source code because I have been focusing on your CWindow and WinFBE.
The demo attached may look a little strange because I was playing with different cell coloring options.
Does it display okay on your system?
Edit: Attachment removed. See later post with fixed exe attachment.
« Last Edit: June 15, 2016, 06:30:26 PM by TechSupport »
« Reply #3 on: June 14, 2016, 09:21:26 PM »
Yes, but because the test is not DPI aware and runs virtualized (=fuzzy fonts).
But if I disable virtualization then... (see capture).
« Reply #4 on: June 14, 2016, 09:25:34 PM »
IMO the control should not calculate the scaling ratios, but allow the user to pass them. If the user does not do it, then calculate the ratios according the DPI, but always give the user the opportunity to set the values.
CWindow calculates the scaling, but allows you to use different scaling ratios just by setting the DPI property before calling the Create method, e.g. pWindow.DPI = 96, disables scaling; any other value, zooms in or out.
« Last Edit: June 15, 2016, 08:29:01 AM by Josť Roca »
« Reply #5 on: June 14, 2016, 09:30:10 PM »
Thanks Jose, I thought that I was correctly building scaling into the control (I must have screwed up there somewhere along the way). I will check the source code again and build it along the lines of your thinking (allow the user to pass the scaling ratios). I will build the sample program using CWindow and then call the grid control using CWindow determined scaling ratios.
« Reply #6 on: June 14, 2016, 09:51:09 PM »
If you aren't using a high dpi, you can simulate it, e.g.
   DIM pWindow AS CWindow
   pWindow.DPI = 192
James Fuller
« Reply #7 on: June 15, 2016, 07:23:19 AM »
Josť,
  The mCtrl author was very receptive to issues:
http://forum.pellesc.de/index.php?topic=6966.0
Maybe you can post at his git site or send him an email?
https://github.com/mity/mctrl/issues
James
« Reply #8 on: June 15, 2016, 08:38:16 AM »
Don't know yet if I'm going to use it or not. I expect to have the same kind of problems with the other controls.
I don't know why they do so much work to write the controls and don't pay any attention to the High DPI issue.
Lots of applications with dialogs that are bigger than the height of my monitor (try to click a button that it is not visible), blurriness, artifacts, clipped text, drag and drop problems between a virtualized application and a DPI aware one), etc.
What are you doing, guys? Do you have the monitor under your nose? I have my monitor at 1.5 meters of distance and I can't read anything if I use 96 DPI (I'm using 192 DPI).
What will happen when 4k monitors will become the norm?
« Last Edit: June 15, 2016, 09:18:58 AM by Josť Roca »
James Fuller
« Reply #9 on: June 15, 2016, 10:12:35 AM »
Josť,
  1.5 meters?? Wow thats almost 5 feet isn't it? You must have extremely long arms :).
My desktop monitor is ~ 2 feet and my laptops are ~ 1.5 feet. Text is small but lots of real-estate even though I do need reading glasses .
James
« Reply #10 on: June 15, 2016, 10:29:34 AM »
I don't touch the screen. I only use the mouse and the keyboard.
« Reply #11 on: June 15, 2016, 10:37:37 AM »
If I put it at that distance and use a high dpi value, I can read it without glasses. If I put it close to mi nose, I need to use reading glasses. So the first option is more comfortable to me.
James Fuller
« Reply #12 on: June 15, 2016, 10:44:37 AM »
Josť,
You are correct that add-on controls SHOULD be dpi aware even though most apps are not.
I sent the author an email with your attached image.
James
« Reply #13 on: June 15, 2016, 04:51:42 PM »
Thanks Jose - I have changed my code to allow the user to pass the scaling ratios to the control, I have also changed the code so that font handles are passed to the control rather than have the control create them. The user is now responsible for creating the font, passing it to the control, and then destroying it when no longer needed. This should make it a lot easier to use scaled CWindow fonts with the grid. I tried the changes on my computer with the DPI changed and it looks much better than before.
Edit: Updated. Forgot to take out my 96 DPI testing line!
« Last Edit: June 16, 2016, 07:46:32 AM by TechSupport »
« Reply #14 on: June 27, 2016, 03:04:36 PM »
Still some work to do.
After understanding DPI, the next step is understanding DIPs (device-independent pixels).
A DIP is defined as 1/96th of a logical inch.
DPI setting   DIP size
96           1 pixel
120           1.25 pixels
144           1.5 pixels
192               2 pixels
If we pass the values to functions or methods that do not do automatic scaling, we have to multiply the pixels by the scaling ratio, because a pixel is a pixel only at 96 DPI.
Pages: [1] 2
