WinFBE using CWindow #7
Started by Paul Squires, June 19, 2016, 09:12:37 PM
Latest source and binaries are attached.
#1
Support for PB-like templates:
In modToolbar.inc change
   Toolbar_AddButton hToolBar, i, IDM_FILENEW, 0, TBSTYLE_DROPDOWN
to add a dropdown arrow to the New File item.
In frmMain_OnNotify add the following code to process the dropdown notification:
   SELECT CASE pNMHDR->idFrom
      CASE IDC_FRMMAIN_TOOLBAR
         DIM ptbn AS TBNOTIFY PTR = CAST(TBNOTIFY PTR, pNMHDR)
         IF ptbn->hdr.code = TBN_DROPDOWN THEN
            SELECT CASE ptbn->iItem
               ' // Dropdown new file menu
               CASE IDM_FILENEW
                  DIM rc AS RECT
                  SendMessageW(ptbn->hdr.hwndFrom, TB_GETRECT, cast(WPARAM, IDC_FRMMAIN_TOOLBAR), CAST(LPARAM, @rc))
                  MapWindowPoints(ptbn->hdr.hwndFrom, HWND_DESKTOP, CAST(POINT PTR, @rc), 2)
                  frmTemplates_Show(hwnd, rc.Left, rc.Bottom)
Module for templates loading:
CONST IDC_TEMPLATES_LISTBOX = 101
' Templates popup dialog
FUNCTION frmTemplates_Show (BYVAL hParent AS HWND, BYVAL x AS LONG, BYVAL y AS LONG) AS LONG
   DIM pWindow AS CWindow
   pWindow.DPI = AfxCWindowPtr(hParent)->DPI
   pWindow.Create(hParent, "Templates", @frmTemplates_WndProc, x + 5, y + 5, 432, 422, _
      WS_VISIBLE OR WS_CAPTION OR WS_POPUPWINDOW OR WS_THICKFRAME, WS_EX_WINDOWEDGE)
   ' // Add a listbox
   DIM hListBox AS HWND = pWindow.AddControl("ListBox", , IDC_TEMPLATES_LISTBOX, "", _
      WS_CHILD OR WS_VISIBLE OR WS_HSCROLL OR WS_VSCROLL OR WS_BORDER OR WS_TABSTOP OR _
      LBS_STANDARD OR LBS_HASSTRINGS OR LBS_SORT OR LBS_NOTIFY OR LBS_NOINTEGRALHEIGHT, WS_EX_CLIENTEDGE)
   pWindow.SetWindowPos hListBox, NULL, 8, 8, 400, 337, SWP_NOZORDER
   SendMessageW hListBox, LB_SETHORIZONTALEXTENT, cast(WPARAM, 600 * pWindow.rxRatio), 0
   ' // Add the buttons
   pWindow.AddControl("Button", , IDOK, "&Ok", 245, 353, 75, 23, WS_CHILD OR WS_VISIBLE OR WS_TABSTOP OR BS_FLAT OR BS_DEFPUSHBUTTON, WS_EX_NOPARENTNOTIFY)
   pWindow.AddControl("Button", , IDCANCEL, "&Cancel", 333, 353, 75, 23, WS_CHILD OR WS_VISIBLE OR WS_TABSTOP OR BS_FLAT, WS_EX_NOPARENTNOTIFY)
   ' // Search templates
   DIM hSearch as HANDLE, WFD AS WIN32_FIND_DATAW, FileNo AS LONG, nType AS LONG, nItem AS LONG
   DIM wszPath AS WSTRING * MAX_PATH, wszCurPath AS WSTRING * MAX_PATH, wszText AS WSTRING * 260
   DIM wszFullPath AS WSTRING * MAX_PATH * 2, idx AS LONG, nLin AS LONG
   wszPath = ExePath & "\Templates\"
   wszCurPath = wszPath & "*.fbtpl"
   ' // Count the number of files and dimension the array
   ' // REDIM PRESERVE causes problems
   DIM nCount AS LONG
   hSearch = FindFirstFileW(wszCurPath, @WFD)
   IF hSearch <> INVALID_HANDLE_VALUE THEN
      DO
         IF (WFD.dwFileAttributes AND FILE_ATTRIBUTE_DIRECTORY) <> FILE_ATTRIBUTE_DIRECTORY THEN
            nCount +=1
      LOOP WHILE FindNextFileW(hSearch, @WFD)
      FindClose(hSearch)
   ' // Dimension the array
   IF nCount = 0 THEN EXIT FUNCTION
   DIM rgwszPaths(nCount - 1) AS WSTRING * MAX_PATH
   idx = 0
   ' // Find the files
      DO
            wszFullPath = wszPath & WFD.cFileName
            ' // Get the description
            FileNo = FREEFILE
            OPEN wszFullPath FOR INPUT AS #FileNo
            IF ERR = 0 THEN
               nLin = 0
               DO UNTIL EOF(FileNo)
                  LINE INPUT #FileNo, wszText
                  nLin += 1
                  IF nLin = 1 THEN nType = VAL(wszText)
                  IF nType < 1 OR nType > 2 THEN EXIT DO
                  IF nType = 1 AND nLin = 3 THEN EXIT DO
                  IF nType = 2 AND nLin = 4 THEN EXIT DO
               LOOP
               CLOSE FileNo
               ' // Display the description in the listbox
               nItem = SendMessageW(hListBox, LB_ADDSTRING, 0, cast(LPARAM, @wszText))
               ' // Store the full path in the array
               rgwszPaths(idx) = wszFullPath
               ' // Store a pointer to the element of the array in the listbox item
               SendMessageW hListBox, LB_SETITEMDATA, nItem, cast(LPARAM, VARPTR(rgwszPaths(idx)))
               idx += 1
               IF idx > UBOUND(rgwszPaths) THEN EXIT DO
      FindClose(hSearch)
   ' / Process Windows messages
   FUNCTION = pWindow.DoEvents
' Templates window procedure
FUNCTION frmTemplates_WndProc (BYVAL hwnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
   SELECT CASE uMsg
      CASE WM_CREATE
         ' Disable parent window to make popup window modal
         EnableWindow GetParent(hwnd), FALSE
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
            CASE IDOK
                  ' // Let the IDC_TEMPLATES_LISTBOX message to process it
                  SendMessageW hwnd, WM_COMMAND, MAKELONG(IDC_TEMPLATES_LISTBOX, LBN_DBLCLK), 0
            CASE IDC_TEMPLATES_LISTBOX
               SELECT CASE HIWORD(wParam)
                  CASE LBN_DBLCLK
                     ' // Get the handle of the Listbox
                     DIM hListBox AS HWND = GetDlgItem(hwnd, IDC_TEMPLATES_LISTBOX)
                     ' // Get the current selection
                     DIM curSel AS LONG = SendMessageW(hListBox, LB_GETCURSEL, 0, 0)
                     IF curSel = LB_ERR THEN EXIT FUNCTION
                     ' // Get the stored index
                     DIM pwszPath AS WSTRING PTR = cast(WSTRING PTR, SendMessageW(hListBox, LB_GETITEMDATA, cast(WPARAM, curSel), 0))
                     IF pwszPath = LB_ERR THEN EXIT FUNCTION
                     ' // Open the template
                     IF pwszPath THEN
                        ' // TODO: Create a new Scintilla control
                        ' // TODO: Load the file
                        ' // TODO: Search for "|", replace it with "" and position the caret in that place
                        ' // Replace the marker with an empty space
                        ' SCIP_FindReplace(pSci, "|", "")
                        ' // Set the state of the document as unmodified
                        ' SCIP_SetSavePoint(pSci)
                        ' // The SCIP_xxx functions are located in the SciCtrl.inc file of the PowerBASIC headers
                     ' // Close the dialog
      CASE WM_CLOSE
         ' // Enables parent window keeping parent's zorder
         EnableWindow GetParent(hwnd), CTRUE
         ' // Don't exit; let DefWindowProcW perform the default action
    CASE WM_DESTROY
         PostQuitMessage(0)
The attached file contains many templates.
This is the TODO part:
                     IF pwszPath THEN
This is how will look, more or less.
Note: Load the template as Untitled<number>.bas.
Thanks Jose :)   I have most of the code implemented now. Only had to do some changes in order to make it fit within the style I'm using (message crackers, etc). I also had to make the following small change. You used the toolbar identifier instead of the toolbar button identifier.
Instead of:
   SendMessageW(ptbn->hdr.hwndFrom, TB_GETRECT, Cast(WPARAM, IDC_FRMMAIN_TOOLBAR), Cast(LPARAM, @rc))
Use:
    SendMessageW(ptbn->hdr.hwndFrom, TB_GETRECT, IDM_FILENEW, Cast(LPARAM, @rc))
I also removed the WS_THICKFRAME style from the Templates window.
#6
I coded it as a separate test without a toolbar and part of the code was theoretical. My major concern was to build the array of paths. With REDIM PRESERVE apparently the memory changed and some of the pointers stored in the listbox where no longer valid. This is why I first get the number of files to dimension the array.
Sounds good. I was wondering why you did that with the array. Better safe than sorry if REDIM PRESERVE is causing a problem.
The only other difference I coded was to NOT set the save point after loading the template file. This keeps the file buffer dirty (and displays the "*" indicator) so that the user can either save the file as the default "UNTITLED1.BAS", "UNTITLED2.BAS", "UNTITLED3.BAS", etc.. or Save As a different name.
The templating system you have made is pretty cool.
#8
This is because my editor allows to compile and run code that does not use resources without saving it first. The editor saves it to a temporary file before compiling it. If I don't set the save point, the editor will ask me to save the file. It is very useful when doing small tests.
The number 2 indicates the number of lines before the description:
FBGUI
.bas
FBGUI means that it is a gui program, and FBCON that it is a console program. I use it to know if I have to call the compiler with the gui or console switch.
The .bas line is to indicate the type of program: .bas for basic code, .xml for manifests, etc.
