Pages: 1 2 [3]
Author Topic: WinFBE on GitHub  (Read 4357 times)
  • Master FireFly Member
Re: WinFBE on GitHub
« Reply #30 on: August 31, 2017, 11:57:18 AM »
Yes, I used Unicode and it works okay with Unicode. I just had to ensure that I was sending the proper length of the string to WM_COPYDATA. Basically, 2x the LEN of the string.
Richard Kelly
  • Senior FireFly Member
« Reply #31 on: August 31, 2017, 03:49:26 PM »
I know it's early in the visual designer stuff. Just wondering if you plan on supporting opacity as a form attribute? There are times, like splash screens, where I like to fade in and out.
Rick
« Reply #32 on: August 31, 2017, 05:11:36 PM »
Rick
Everything is on the table at this point. Long ways to go before we get to the code generation stage.
Richard Kelly
« Reply #33 on: December 05, 2017, 10:34:30 PM »
Downloaded the latest version. Being a bit careful, I ran all my cCalendar work both 32/64 bit with FB 1.05 and FB 1.06 with no issues. Loaded my SQLite Client/Server work in progress with no issues.
Compiled the piano example and that was nice.
After a few hours, no crashes, rock solid.
When you get the designer going, I have code for a GUI cCalendar I'll port over, test, and, let you know the results.
Rick Kelly
 8)
« Last Edit: December 05, 2017, 10:36:06 PM by Richard Kelly »
Pages: 1 2 [3]
