Author Topic: Request for Access *.mb files  (Read 1809 times)
  • Master FireFly Member
    • José Roca Software
« on: August 07, 2016, 03:19:15 AM »
I would like to write a class to wrap ODBC, but I only can test it in 32 bit because I don't have versions of biblio.mdb and northwind.mdb in 64 bit. Anybody has Access 32 and 64 bit *.mdb files to test?
« Last Edit: August 07, 2016, 02:00:05 PM by José Roca »
Re: Request for Access *.mb files
« Reply #1 on: August 07, 2016, 05:31:02 AM »
An small test:
'#define unicode
'#define _CODBC_DEBUG_ 1
#include once "Afx/COdbc/COdbc.inc"
USING Afx
' // Connect with the database
DIM wszConStr AS WSTRING * 260 = "DRIVER={Microsoft Access Driver (*.mdb)};DBQ=biblio.mdb"
DIM pDbc AS CODBC = wszConStr
' // Allocate an statement object
DIM pStmt AS COdbcStmt PTR = NEW COdbcStmt(@pDbc)
IF pStmt THEN
   ' // Generate a result set
   pStmt->ExecDirect ("SELECT TOP 20 * FROM Authors ORDER BY Author")
   ' // Parse the result set
   DIM cwsOutput AS CWSTR
   DO
      ' // Fetch the record
      IF pStmt->Fetch = FALSE THEN EXIT DO
      ' // Get the values of the columns and display them
      cwsOutput = ""
      cwsOutput += pStmt->GetData(1) & " "
      cwsOutput += pStmt->GetData(2) & " "
      cwsOutput += pStmt->GetData(3)
      PRINT cwsOutput
   LOOP
   Delete pStmt
PRINT
PRINT "Press any key..."
SLEEP
« Last Edit: August 07, 2016, 11:11:55 PM by José Roca »
Knuth Konrad
  • Junior FireFly Member
« Reply #2 on: October 07, 2016, 10:29:08 AM »
A bit late, but nontheless: I'm pretty sure there isn't a difference of a *.mdb file created with a 32 or 64 bit version of Access.
There is however a new Access file format: *.accdb. Never used that one, though.
BTW, MDB Viewer is a versatile free tool for dealing with Access files. And contrary to its name ("Viewer"), it let's you create MDB files also.
David Warner
« Reply #3 on: February 10, 2017, 10:02:09 AM »
Hi José,
I'm just taking a look at your ODBC class and my first impression is... Wow, that's amazing!
Thank you.
Cheers,
David
« Reply #4 on: February 10, 2017, 12:13:47 PM »
Hi José,
Thank you.
Cheers,
David
I agree 100%. The work that José has done with the FB classes is incredible. Only last weekend I was having trouble with some file input/output so I switched to using José's CTextStream class and it worked perfectly (and it is syntactically more pleasing to deal with).
David Warner
« Reply #5 on: February 10, 2017, 12:33:30 PM »
Jose’s CWindow framework truly is an amazing coding resource containing lots of interesting and useful items. There is a great deal of information to take in and I think we are fortunate indeed to have received such a generously given gift.
« Reply #6 on: February 10, 2017, 12:51:42 PM »
Thanks very much.
@Paul,
If you're using CTextStream, I have modified two of the methods: Read and ReadLine.
' Reads a specified number of characters from a TextStream file and returns the resulting string.
' After a file is initially opened and before anything is written, Line is equal to 1.
PRIVATE FUNCTION CTextStream.Read (BYVAL numChars AS LONG) AS CWSTR
   DIM bstrText AS AFX_BSTR
   IF m_pTxtStm THEN SetResult(m_pTxtStm->Read(numChars, @bstrText))
   DIM cwsText AS CWSTR = *bstrText
   SysFreeString bstrText
   RETURN cwsText
' Reads an entire line (up to, but not including, the newline character) from a TextStream
' file and returns the resulting string.
PRIVATE FUNCTION CTextStream.ReadLine () AS CWSTR
   IF m_pTxtStm THEN SetResult(m_pTxtStm->ReadLine(@bstrText))
   RETURN cwsText
Previously the code used was:
DIM cwsText AS CWSTR = SysallocString(*bstrText)
Instead of
[(code]
Because the original version returned a CBSTR instead of a CWSTR.
« Last Edit: February 10, 2017, 06:24:54 PM by José Roca »
« Reply #7 on: February 10, 2017, 01:10:54 PM »
Unfortunately, the lack of native support for BSTRrings forces to have to make copies of the data.
« Reply #8 on: February 10, 2017, 04:26:10 PM »
Thanks José, I only used the class to write/output files. I didn't need to read them at the time. Thanks for letting me know that you've change the code.
