Author Topic: CCbColor.inc issue  (Read 1105 times)
James Fuller
CCbColor.inc issue
« on: August 30, 2016, 05:47:22 PM »
Jose,
  In your CCbColor.inc CCbColorProc, Set user color, and Get user color, are both get user color.
James
      ' // Set user color
      CASE CBCOL_SETUSERCOLOR
         pCbColor = CAST(CCbColor PTR, .GetPropW(hwnd, "CBCOLORPTR"))
         IF pCbColor = NULL THEN EXIT FUNCTION
         FUNCTION = pCbColor->m_UserColor
      ' // Get user color
      CASE CBCOL_GETUSERCOLOR
  • Master Member
    • Jos
Re: CCbColor.inc issue
« Reply #1 on: August 30, 2016, 10:01:37 PM »
Yes. Change it to pCbColor->m_UserColor = wParam. I have changed it in both CCbColor and CCbColorEx for the bext release.
Thanks very much.
