Passing different pointer types
Started by jermy, October 02, 2016, 03:58:31 PM
jermy
Hello all,
The FB Compiler tells me;
warning 3(1): Passing different pointer types, at parameter 1 of GETCURSORPOS()
Type Point_Api
  X as Long
  Y as Long
End Type
                         Dim lngRetVal            as Long
                         Dim ptScreenCursorPos    as Point_Api
                             lngRetVal = GetCursorPos(@ptScreenCursorPos)
I can't figure it out why the Compiler keeps whining.
Jermy
It complains because you're passing a pointer to a Point_Api structure to a function that expects a pointer to a POINT structure.
Either use
Dim ptScreenCursorPos as POINT
or cast your type variable to the expected type:
lngRetVal = GetCursorPos(cast(POINT PTR, @ptScreenCursorPos))
jermy
