Author Topic: How to reduce screen flicker in a ListView  (Read 1268 times)
Jean-pierre Leroy
  • Senior FireFly Member
« on: October 11, 2016, 12:25:00 PM »
I saw recently your reply on the PowerBASIC forum about "How to reduce screen flicker in a ListView":
https://forum.powerbasic.com/forum/user-to-user-discussions/programming/751841-how-to-reduce-screen-flicker-in-a-listview?p=751855#post751855
Is-it possible to enable double buffering extending style (%LVS_EX_DOUBLEBUFFER) for a ListView control with FireFly ? this option doesn't seem to be available in the visual designer.
Jean-Pierre
  • Master FireFly Member
Re: How to reduce screen flicker in a ListView
« Reply #1 on: October 11, 2016, 08:22:21 PM »
Hi Jean-Pierre,
You would need to add code to WM_CREATE to set the style for the Listview. Here is some FB code that I am using in my editor project to set some extended styles for the Listview.
   ' Add some extended styles
   Dim dwExStyle As DWORD
   dwExStyle = ListView_GetExtendedListViewStyle(hLV)
   dwExStyle = dwExStyle Or LVS_EX_FULLROWSELECT Or LVS_EX_GRIDLINES Or LVS_EX_DOUBLEBUFFER Or LVS_EX_FLATSB
   ListView_SetExtendedListViewStyle(hLV, dwExStyle)
Jean-pierre Leroy
« Reply #2 on: October 12, 2016, 06:26:47 AM »
Thanks Paul.
I will follow your advice.
Regards,
Jean-Pierre
