Pages: [1] 2
Author Topic: PB PowerCollection  (Read 4011 times)
Richard Kelly
PB PowerCollection
« on: October 23, 2016, 06:12:22 PM »
I'm looking at creating a drop-in replacement for the PB PowerCollection/Stack objects using Jose's objects. Is the SafeArrary with variant types the best way to go?
  • Master Member
    • Jos
Re: PB PowerCollection
« Reply #1 on: October 23, 2016, 06:27:33 PM »
For the collection, the best way is the Dictionary object. Earlier versions of my framework included the file CDicObj.inc.
Richard Kelly
« Reply #2 on: October 23, 2016, 08:00:29 PM »
Nice...I found the include file and will put a wrapper that maps to the PB equivalent.
ganlinlao
  • FireFly3 User
  • Little Newbie FireFly
« Reply #3 on: October 24, 2016, 12:08:53 AM »
Maybe we need a freebasic JSON parsing library, the JSON string or file parsing into collection. JSON files can be used as a program configuration or other kinds of occasions to use json.
Richard Kelly
« Reply #4 on: January 14, 2017, 01:09:00 PM »
RC 26 has CWstrDic.inc. Is that the way to go with the current cWindows status?
  • Master Member
    • Jos
« Reply #5 on: January 14, 2017, 02:34:54 PM »
CWstrDic is a collection, but only supports unicode strings, not variants. I was not fully satisfied with the implementation of the BSTRings and VARIANTs classes and, therefore, I stopped using them.
« Last Edit: January 14, 2017, 06:20:35 PM by Jose Roca »
Richard Kelly
« Reply #6 on: January 14, 2017, 05:28:15 PM »
CWstrDic is a collection, but only supports unicode strings, not variants. I was not fully satisfed with the implementation of the BSTRings and VARIANTs classes and, therefore, I stopped using them.
Thanks...more thinking to do on a FB implementation of ILinkListCollection...maybe a safearray....or B24 encode everything for CWstrDic...
Rick
« Last Edit: January 14, 2017, 05:31:40 PM by Richard Kelly »
Richard Kelly
« Reply #7 on: January 15, 2017, 01:07:18 PM »
Thought I'd float this by my more learned colleagues.
Let's wrap Jose's CWstrDic object with a class that takes a unsigned ubyte pointer, length, and maybe type. B24 encode that (non string types) and use the resulting string as input. It would seem that anything that you can get a pointer to with a fixed size could then be stored in CWstrDic. That would be the PB PowerCollection. Wrapping that one could also emulate the other collections such as LinkListCollection, QueueCollection, and, StackCollection.
Thoughts?
  • Master Member
    • Jos
« Reply #8 on: January 15, 2017, 03:27:51 PM »
Sorry, but I don't follow you. CWstrDic has been designed as an associative array for CWSTRings. Internally, they are stored as VT_BSTR variants and the wrapper methods do the conversions. For linked lists, I think that Paul wrote a class some time ago.
Richard Kelly
« Reply #9 on: January 15, 2017, 04:20:02 PM »
I'm probably not following the examples properly.
Instead of:
pDic.Add "a", "Athens"
I wanted to do:
DIM nAny as Long
pDic.Add "a", nAny
or even a UDT...and get back what the associated value in the same type as it was originally.
Rick
  • Master Member
    • Jos
« Reply #10 on: January 15, 2017, 05:15:44 PM »
You can't do that with CWstrDic, that is only for unicode strings. A way to store any kind of data, although not in the way you want to, is to use variants, but I still don't have a satisfactory implementation of a variant class.
Richard Kelly
« Reply #11 on: January 15, 2017, 06:10:17 PM »
This was my understanding of your work. I thought a way around it all without using variants was to take a byte ptr and length and B24 encode it to a string that was passed to CWstrDic class and reverse it on the way out.
Rick
  • Master Member
    • Jos
« Reply #12 on: January 15, 2017, 06:28:06 PM »
Well, you can store unicode strings. What you do with its content is up to you.
Richard Kelly
« Reply #13 on: January 17, 2017, 12:43:55 AM »
I'll give it a shot. I know that the function below is the heart of it all...take something and B64 encode it. B64 encoding only gets used on non string types.
#Pragma Once
#Include "win/wincrypt.bi"
#IncLib "Crypt32"
Function cmBin2B64(ByVal pbBinary as Const UByte Ptr, _
                               ByVal cbBinary as DWORD) as String
Dim iB64Size      as DWORD
Dim sB64          as String
    If cbBinary > 0 Then
' Get encoded string size
       CryptBinaryToStringA(pbBinary, _
                           cbBinary, _
                           CRYPT_STRING_BASE64 + CRYPT_STRING_NOCRLF, _
                           Null, _
                           VarPtr(iB64Size))
       sB64 = Space$(iB64Size)
                           cbBinary, _
                           StrPtr(sB64), _
                           VarPtr(iB64Size))
       Function = Left$(sB64,iB64Size)
    Else
       Function = ""
I think that CWsrDic will work for PB PowerCollection directly, and, with some work PB LinkList, Queue, and Stack classes (Maybe using WStrArray).
« Last Edit: January 17, 2017, 02:29:28 AM by Richard Kelly »
Richard Kelly
« Reply #14 on: January 22, 2017, 06:59:48 PM »
Jose:
If I retrieve the keys and items separately using pDic.Keys and pDic.Items, is Index 1 in the Items array always associated with index 1 in the Keys array?
Pages: [1] 2
