Author Topic: -w pedantic  (Read 1152 times)
  • Master Member
-w pedantic
« on: November 28, 2016, 10:50:00 PM »
Hi Jose,
Over in the FB forum, Lothar Schirm mentioned about compiling with the compiler switches  -2 pedantic. I did so and noticed that there are several areas in the CWindow and associated classes where BYVAL and/or BYREF are not explicitly specified. Probably wouldn't hurt for you to add them?
  • Master Member
    • Jos
Re: -w pedantic
« Reply #1 on: November 28, 2016, 10:53:41 PM »
Thanks, Paul. I already have done it. I will post a new version tomorrow.
