Author Topic: Dialog rc To source code utility  (Read 679 times)
James Fuller
  • Senior FireFly Member
« on: January 11, 2017, 12:16:35 PM »
Dlg2Src is a Windows 64bit utility that takes a dialog resource script
as it's input and creates SDK source for a number of compiler/translators.
Supported source code generation:
bc9Basic/CWindow/TClib
bc9Basic/TCLib
bc9Basic/SDK
FreeBasic/CWindow
FreeBasic/SDK
C/C++ SDK
C++/TCLib
PowerBASIC/CWindow
PowerBASIC/SDK
Oxygen Basic/SDK
UpDate:
https://sourceforge.net/projects/bc9basic/files/Tools/Dlg2Src/Dlg2Src.zip/download
Because of some false browser malware site protection issues I have posted ResEd and it's help file to my bc9Basic github site:
http://jcfuller.github.io/bc9Basic/ResEd.zip
http://jcfuller.github.io/bc9Basic/ResEd.chm
James
« Last Edit: June 04, 2017, 04:45:09 PM by James Fuller »
Marc Pons
  • Junior FireFly Member
Re: Dialog rc To source code utility
« Reply #1 on: January 14, 2017, 06:38:12 AM »
Hi James
seems interresting but not able to test it (32bit xp)
could you create a 32bit version , or better post your code ?
thank's in advance
James Fuller
« Reply #2 on: January 14, 2017, 10:50:17 AM »
Sorry no.
It was created using my bc9Basic and the NUWEN MinGW c++ distro and it only supports 64 bit.
https://nuwen.net/mingw.html
Source is not available at this time.
James
