Author Topic: Freebasic version of PB PowerCollection  (Read 3625 times)
Richard Kelly
« on: January 24, 2017, 02:59:52 AM »
Extract the includes to the FB folder where Jose's cWindow lives. You'll need the latest version (RC26).
This is a wrapper on Jose's excellent CWstrDic class modeled after the Powerbasic Powercollection object.
It allows key items to be any FB basic type. Over the coming month or so, I'm also planning on taking a crack at being able to store fixed arrays as well.
Maybe Paul can use this instead of SQLite for his editor project.
Test script I used is:
#Include Once "fbcoll/cPowerCollection.inc"
Dim oPowerCollection as cPowerCollection
Dim iByte            as Byte = -1
Dim iuByte           as UByte = 255
Dim iShort           as Short = -1234
Dim iuShort          as UShort = 2345
Dim iLong            as Long = 2000000000
Dim iuLong           as uLong = 345678
Dim iInteger         as Integer = 45678
Dim iuInteger        as UInteger = 56789
Dim iLLong           as LongInt  = 300000000003
Dim iLuLong          as uLongInt = 400000000004
Dim iSingle          as Single = 12.12
Dim iDouble          as Double = 1234567890.23
Dim sString          as String = "Jose"
Dim szString         as ZString * 5 = "Paul"
Dim swString         as WString * 10 = "Freebasic"
Dim uItem            as COLLECTION_DATA
Dim iIndex           as Long
Dim sItemContent     as String
Dim arItems()        as COLLECTION_DATA
' Build a collection of different data types
    oPowerCollection.Add("Byte",iByte)
    oPowerCollection.Add("UByte",iuByte)
    oPowerCollection.Add("Short",iShort)
    oPowerCollection.Add("UShort",iuShort)
    oPowerCollection.Add("Long",iLong)
    oPowerCollection.Add("ULong",iuLong)
    oPowerCollection.Add("Integer",iInteger)
    oPowerCollection.Add("UInteger",iuInteger)
    oPowerCollection.Add("LongInt",iLLong)
    oPowerCollection.Add("ULongInt",iLuLong)
    oPowerCollection.Add("Single",iSingle)
    oPowerCollection.Add("Double",iDouble)
    oPowerCollection.Add("String",sString)
' These are treated as String types
    oPowerCollection.Add("ZString",szString)
    oPowerCollection.Add("WString",swString)
' Add some items using literals
    oPowerCollection.Add("Number Literal",99.32)
    oPowerCollection.Add("Integer Literal",98765)
    oPowerCollection.Add("String Literal","cPowerCollection")
    Print Str(oPowerCollection.Count()) + " items added"
    Print ""
' Sort the list ascending
    oPowerCollection.Sort(cCollectionClass.SORT_ASCENDING)
' Cycle through the list top to bottom and show the keys and items
   For iIndex = 1 To oPowerCollection.Count()
       oPowerCollection.Index(iIndex)
       oPowerCollection.Entry(uItem)
       Select Case uItem.DataType
       Case cCollectionClass.BYTE_TYPE
          sItemContent = "Byte=" + Str(uItem.DataValue_Byte)
       Case cCollectionClass.UBYTE_TYPE
          sItemContent = "UByte=" + Str(uItem.DataValue_UByte)
       Case cCollectionClass.SHORT_TYPE
          sItemContent = "Short=" + Str(uItem.DataValue_Short)
       Case cCollectionClass.USHORT_TYPE
          sItemContent = "UShort=" + Str(uItem.DataValue_UShort)
       Case cCollectionClass.LONG_TYPE
          sItemContent = "Long=" + Str(uItem.DataValue_Long)
       Case cCollectionClass.ULONG_TYPE
          sItemContent = "ULong=" + Str(uItem.DataValue_ULong)
       Case cCollectionClass.INTEGER_TYPE
          sItemContent = "Integer=" + Str(uItem.DataValue_Integer)
       Case cCollectionClass.UINTEGER_TYPE
          sItemContent = "UInteger=" + Str(uItem.DataValue_UInteger)
       Case cCollectionClass.LONGINT_TYPE
          sItemContent = "LongInt=" + Str(uItem.DataValue_LongInt)
       Case cCollectionClass.ULONGINT_TYPE
          sItemContent = "ULongint=" + Str(uItem.DataValue_ULongint)
       Case cCollectionClass.SINGLE_TYPE
          sItemContent = "Single=" + Str(uItem.DataValue_Single)
       Case cCollectionClass.DOUBLE_TYPE
          sItemContent = "Double=" + Str(uItem.DataValue_Double)
       Case Else
          sItemContent = "String=" + uItem.DataValue_String
       Print "Key=" + uItem.DataKey + "," + sItemContent
   Next
   Print ""
' Remove key "WString"
   oPowerCollection.Remove("WString")
   If oPowerCollection.Contains("WString") = True Then
      Print "WString still in collection"
   Else
      Print "WString removed from collection"
   Print ""
' Update "ZString" from "Freebasic" to match "Byte" value of -1
   oPowerCollection.Replace("ZString",iByte)
' Resort to descending
   oPowerCollection.Sort(cCollectionClass.SORT_DESCENDING)
' Get all items and show them
   oPowerCollection.Items(arItems())
   For iIndex = LBound(arItems) To UBound(arItems)
       Select Case arItems(iIndex).DataType
          sItemContent = "Byte=" + Str(arItems(iIndex).DataValue_Byte)
          sItemContent = "UByte=" + Str(arItems(iIndex).DataValue_UByte)
          sItemContent = "Short=" + Str(arItems(iIndex).DataValue_Short)
          sItemContent = "UShort=" + Str(arItems(iIndex).DataValue_UShort)
          sItemContent = "Long=" + Str(arItems(iIndex).DataValue_Long)
          sItemContent = "ULong=" + Str(arItems(iIndex).DataValue_ULong)
          sItemContent = "Integer=" + Str(arItems(iIndex).DataValue_Integer)
          sItemContent = "UInteger=" + Str(arItems(iIndex).DataValue_UInteger)
          sItemContent = "LongInt=" + Str(arItems(iIndex).DataValue_LongInt)
          sItemContent = "ULongint=" + Str(arItems(iIndex).DataValue_ULongint)
          sItemContent = "Single=" + Str(arItems(iIndex).DataValue_Single)
          sItemContent = "Double=" + Str(arItems(iIndex).DataValue_Double)
       Case Else
          sItemContent = "String=" + arItems(iIndex).DataValue_String
       Print "Key=" + arItems(iIndex).DataKey + "," + sItemContent
   Next
   Print ""
' Clear the collection
   oPowerCollection.Clear()
   Print "All items have been removed and the count is " + Str(oPowerCollection.Count())
Re: Freebasic version of PB PowerCollection
« Reply #1 on: January 24, 2017, 10:43:20 AM »
Thanks for creating and sharing this code. Cool stuff :)
I already have a super fast hash based solution that I have implemented into the editor that I am using instead of my plan to use SQLite. It is simple, flexible, and won't have all that overhead that SQLite would have brought into the mix.
Richard Kelly
« Reply #2 on: January 24, 2017, 08:07:31 PM »
I'll take a look at it in the future. Now that I have a FB PowerCollection, LinkList and Stack should be quick wrappers base on CWStrArray.
