Pages: 1 [2]
Author Topic: font resizing  (Read 2912 times)
  • Master FireFly Member
Re: font resizing
« Reply #15 on: February 10, 2017, 04:23:24 PM »
New FireFly package uploaded with the Get/Set Font fix. I have not incremented the FF version.
http://www.planetsquires.com/firefly_freebasic.html
  • FireFly3 User
  • Junior FireFly Member
Re: font resizing
« Reply #16 on: February 11, 2017, 11:05:41 AM »
Thanks Paul. Fixed the problem I mentioned in OP.
  • FireFly3 User
Re: font resizing
« Reply #17 on: February 11, 2017, 06:11:50 PM »
If you bring up Windows Task Manager, go under the "View" menu, select "Select Columns". Tick the box for GDI Objects. Now as your application executes keep watching the count of those objects. You will see it increase and increase and increase....
Hi Paul, for the sake of completeness, gdi objects vary between 39 to 41, as I increase/decrease size of fonts (running w10) no leakage afaik.
Re: font resizing
« Reply #18 on: February 12, 2017, 11:27:43 AM »
Awesome, thanks for reporting back. That is a pretty low GDI count so certainly looks like everything is working as it should.
Pages: 1 [2]
