Pages: [1] 2
Author Topic: FreeBASIC's equivalent to PowerBASIC's DIM AT syntax  (Read 3368 times)
  • Master FireFly Member
« on: February 12, 2017, 11:31:00 AM »
I stumbled across this post today that discusses FB's for NEW (Placement) syntax. It appears to be essentially PB's DIM AT.
http://freebasic.net/forum/viewtopic.php?f=3&t=25429#p229070
I didn't think FB had an equivalent to DIM AT.... looks like I was wrong. I used DIM AT a fair bit on some programs so this is a welcomed find.
Patrice Terrier
  • Junior FireFly Member
Re: FreeBASIC's equivalent to PowerBASIC's DIM AT syntax
« Reply #1 on: February 14, 2017, 09:58:17 AM »
Paul--
DIM AT is easy to duplicate with a simple call to the low API RtlMoveMemory or RtlCopyMemory.
Pierre Bellisle
  • FireFly3 User
« Reply #2 on: February 14, 2017, 09:49:57 PM »
How about using a simple pointer...
Pierre
Type SomeType
  dw As DWORD
  w  As WORD
  d  As Double
 End Type
 Dim SomeTypeArray(0 TO 49) As SomeType
 SomeTypeArray(33).w = 123
 Dim As SomeType Pointer pSomeTypeArray = VarPtr(SomeTypeArray(0))
 Print pSomeTypeArray[33].w 'Will show 123
Pierre Bellisle
  • FireFly3 User
« Reply #3 on: February 15, 2017, 01:30:18 PM »
Hey,
Here is a "maybe" more explicit example of what I mean.
If you feel like it, Paul and Patrice, could you give a short code example that demonstrate what you are referring to.
Pierre
#define CompilerExe "<D:\Free\64\fbc.exe>"
#define CompilerCmd "<-s console "D:\Free\bas\~~Default.rc">"
#Lang "fb"
#Define Unicode
#Include Once "Windows.bi"
 Dim As String sDoubleWord = MKL(123) & MKL(234) & MKL(345) & MKL(456) & MKL(567) & MKL(789) & MKL(0)
 Dim AS DWord Pointer pDoubleWord = Cast(Any Pointer, StrPtr(sDoubleWord))
 Print "pDoubleWord[2] = " & pDoubleWord[2] 'Will show 345
 Print : Print "Press a key or click to end"
 Dim buttons As Long : Do : GetMouse(0, 0, 0, Buttons) : IF buttons Or Len(InKey) Then Exit Do : End If : Sleep 50 : Loop
« Reply #4 on: February 15, 2017, 03:09:36 PM »
hmmm.... now that I've played with it for a bit, I can see that FB's ability to use dynamic arrays within TYPE structures is pretty powerful. The use of NEW basically simulates the dynamic array functionality only just in a slightly different way. Both call the newly allocated TYPE's constructors and destructors which is pretty powerful.
type EMPLOYEE
   EmpName    as string
   EmpAddress as STRING
   EmpSalary  as double
   declare constructor
   declare destructor
END TYPE
constructor EMPLOYEE
   print "Initialize EMPLOYEE type"
end constructor
DEStructor EMPLOYEE
   print "Destroy EMPLOYEE type"
end DEStructor
type APPLICATION
   pEmp as EMPLOYEE ptr
   declare constructor
   declare destructor
end type
constructor APPLICATION
   print "Initialize APPLICATION type"
   this.pEmp = new EMPLOYEE[10]
   with this.pEmp[1]
      .EmpName    = "Paul"
      .EmpAddress = "Canada"
      .EmpSalary  = 1000.00
   end with
end constructor
DEStructor APPLICATION
   print "Destroy APPLICATION type"
   delete[] this.pEmp
end DEStructor
''  MAIN
dim shared gApp as APPLICATION
for i as long = 0 to 9
   print i, gApp.pEmp[i].EmpName, gApp.pEmp[i].EmpAddress, gApp.pEmp[i].EmpSalary
print "Done. Press any key."
sleep
' gApp's destructor will be called here as the global goes out of scope
« Reply #5 on: February 15, 2017, 03:16:15 PM »
Just using a plain CALLOCATE with a typed pointer results in the constructors and destructors NOT being called.
type EMPLOYEE
   EmpName    as string
   EmpSalary  as double
   declare constructor
   declare destructor
END TYPE
end constructor
DEStructor EMPLOYEE
end DEStructor
''  MAIN
dim pEmp as EMPLOYEE Ptr = CALLOCATE(10, len(EMPLOYEE))
with pEmp[1]
   .EmpName = "Paul"
end with
   print i, pEmp[i].EmpName, pEmp[i].EmpAddress, pEmp[i].EmpSalary
DEALLOCATE pEmp
sleep
« Reply #6 on: February 15, 2017, 03:20:09 PM »
...and lastly, here is the straight forward dynamic ARRAY version. As you can see, constructors and destructors do get called.
type EMPLOYEE
   EmpName    as string
   EmpSalary  as double
   declare constructor
   declare destructor
END TYPE
end constructor
DEStructor EMPLOYEE
end DEStructor
type APPLICATION
   arrEmp(any) as EMPLOYEE
   declare constructor
   declare destructor
end type
   REDIM this.arrEmp(10)
   with this.arrEmp(1)
      .EmpName    = "Paul"
   end with
end constructor
end DEStructor
''  MAIN
   print i, gApp.arrEmp(i).EmpName, gApp.arrEmp(i).EmpAddress, gApp.arrEmp(i).EmpSalary
sleep
« Reply #7 on: February 15, 2017, 03:25:55 PM »
This is probably closer to DIM AT. Pretty simple really given FB's ability to use ANY PTR and then convert it to a typed pointer.
I use array indexing in my code because I find it easier to visualize then incrementing memory addresses.
type EMPLOYEE
   EmpName    as string
   EmpSalary  as double
END TYPE
''  MAIN
dim pMem as any ptr = CALLOCATE(1024)
dim pEmp as EMPLOYEE Ptr = CPtr(EMPLOYEE Ptr, pMem)
with pEmp[1]
   .EmpName    = "Paul"
end with
DEALLOCATE pMem
sleep
Pierre Bellisle
  • FireFly3 User
« Reply #8 on: February 15, 2017, 03:28:36 PM »
Agreed, looks pretty powerful...
Good stuff to read and learn.
Many thanks for those examples Paul.
Pierre
Patrice Terrier
« Reply #9 on: February 15, 2017, 03:46:45 PM »
They borrowed this direct from C++  :)
« Reply #10 on: February 15, 2017, 03:51:37 PM »
They borrowed A LOT from C++   :)
Pierre Bellisle
  • FireFly3 User
« Reply #11 on: February 15, 2017, 05:42:44 PM »
Also what I think, they borrowed a lot from C++, and did a great job at it, I like...  :-)
    • Jos
« Reply #12 on: February 15, 2017, 06:24:03 PM »
As long as they don't borrow the semi-colons and curly braces... :)
« Reply #13 on: February 16, 2017, 06:06:45 PM »
Well, I totally got the DIM AT syntax a little wrong. Here is how it relates most closely to the PB DIM AT functionality.
The New (placement) operator allows to construct object(s) (no allocate memory) at an existing memory location:
New(address) datatype[ count ]
TYPE EMPLOYEE
   empName    AS STRING
   empAddress AS STRING
   empSalary  AS DOUBLE
END TYPE
' Create a generic block of memory
dim pMem as any ptr = CALLOCATE( 1024)
' Here is the DIM AT syntax. Notice the NEW(pMem) part.
' Basically 10 new employee TYPE's are overlaid on the
' existing pMem area.
DIM pEmp AS EMPLOYEE Ptr = NEW(pMem) EMPLOYEE[10]
' Assign data to our employee
pEmp->empName = "Paul"
pEmp->empAddress = "Canada"
pEmp->empSalary = 1000.00
' Deallocate our memory
DEALLOCATE(pMem)
Pierre Bellisle
  • FireFly3 User
« Reply #14 on: February 16, 2017, 09:09:37 PM »
I got to read about this "New" (placement) operator...
I the mean time, what advantage do you see over the following...
#Include Once "string.bi" 'For format
TYPE Employee
  FirstName AS STRING
  Country   AS STRING
  Salary    AS DOUBLE
END TYPE
Dim pEmployeeArray As Employee Pointer = cAllocate(2048) 'Allocate memory
pEmployeeArray[0].FirstName = "Paul"
pEmployeeArray[0].Country   = "Canada"
pEmployeeArray[0].Salary    = 10000.00
pEmployeeArray[1].FirstName = "Jos" & CHR(130)
pEmployeeArray[1].Country   = "Spain"
pEmployeeArray[1].Salary    = 10000.00
Print "> " & pEmployeeArray[0].FirstName
Print "> " & pEmployeeArray[0].Country
Print "> " & Format(pEmployeeArray[0].Salary, "0,")
Print
Print "> " & pEmployeeArray[1].FirstName
Print "> " & pEmployeeArray[1].Country
Print "> " & Format(pEmployeeArray[1].Salary, "0,")
Deallocate(pEmployeeArray) 'Deallocate memory
Sleep
« Last Edit: February 17, 2017, 01:09:32 AM by Pierre Bellisle »
Pages: [1] 2
