Author Topic: Firelines  (Read 1618 times)
  • Senior FireFly Member
Firelines
« on: February 21, 2017, 12:43:45 PM »
Hi All
I have used the Firelines tool of Paul in a project just to create a visible divider between a few controls.
Interestingly, when say another Form opens over it, then its fine, but some pop-ups like message-boxes will delete a portion of the line.
That looks quite awkward on a form having a divider line with missing bits and pieces.
Any ideas?
  • Master FireFly Member
    • Jos
Re: Firelines
« Reply #1 on: February 21, 2017, 02:27:52 PM »
Redraw the form.
Re: Firelines
« Reply #2 on: February 21, 2017, 05:12:38 PM »
Ok, but how do i know when this happens, because it only happens while the program runs.
On what occasion/trigger/event will one do that?
Re: Firelines
« Reply #3 on: February 21, 2017, 05:19:22 PM »
This actually only happens during the event where two different TEXTBOXES that were set to NUMBERS ONLY receives an invalid key.
The windows pop-up appears about the invalid character.
Then it deletes the FIRELINE in different sizes and places.
This is annoying.
Image 1 shows the form while running correctly.
Image 2 Shows textbox1 (PO Box numbers) and textbox 7 (Cell numbers). Both these are set to NUMBERS ONLY
Image 3 shows what happens to the line if there was an invalid character warning in any of the two textboxes. The lie is deleted in various lengths.
« Last Edit: February 21, 2017, 05:25:27 PM by Petrus Vorster »
Re: Firelines
« Reply #4 on: February 21, 2017, 05:38:57 PM »
How about in the WM_PAINT handler for the FORM, you make a call to FF_CONTROL_REDRAW( FireLinesHandle ) and see what happens?
Re: Firelines
« Reply #5 on: February 22, 2017, 02:50:47 PM »
It works, but i had to put it three places.
In the wm_paint, and killfocus of the two textboxes.
You can still clearly see the deletion of the line, but at least it repaints it afterwards.
Perhaps i should just changes the textboxes and prevent the characters with code iso the setting?
Re: Firelines
« Reply #6 on: February 22, 2017, 02:58:33 PM »
Yes, that work so much easier....
Where is the corner i have to go stand again? LOL
