Author Topic: selection of open forms  (Read 3201 times)
  • FireFly3 User
« on: March 07, 2017, 10:10:21 AM »
I have a form (A), with a button, which opens another different style of form (B). I can open a number of forms (B), by pressing the button on (A). However, when these (B) forms are open, I can only select the last one opened (or form (A)), I can't even shuffle the forms around the screen, I can only move the last one opened. I thought there would be a windows 'CLassStyle' setting for this within the ff 'workspace' when the form is designed, or do I have to write code to enable any form to be selected?
Eddy Van Esch
    • DevOTechS
Re: selection of open forms
« Reply #1 on: March 07, 2017, 10:15:29 AM »
You are probably creating 'modal' forms, and you seem to be needing 'modeless' forms.
Can't remember how to define this in FF though ...  :(
[added later]
No, I think I am wrong. In the case of modal forms, you wouldn't be able to click the button on the main form to open a new B form ...
[/added later]
« Last Edit: March 07, 2017, 10:17:06 AM by Eddy Van Esch »
Eddy
Eddy Van Esch
    • DevOTechS
« Reply #2 on: March 07, 2017, 10:19:37 AM »
I just tried what you described in one of my existing programs.
I can open multiple 'B forms' and move any one of them around as I please ....
Eddy
  • Master Member
« Reply #3 on: March 07, 2017, 11:25:55 AM »
You need to show us the code you are using to initiate the opening of the popup forms. Probably a modal/non-modal issue or you are not specifying the correct parent form handle?
  • FireFly3 User
« Reply #4 on: March 07, 2017, 02:09:10 PM »
Button press on the A form
resistor_show(hwnd_resistor,true)
B form creation
Function RESISTOR_WM_CREATE ( _
                            hWndForm as HWnd, _          ' handle of Form
                            ByVal UserData as Integer _  ' optional user defined value
                            ) as Long
                         rtagnumber = rtagnumber +1
                 FF_Control_SetTag( hwndform, Str(rtagnumber) )
                 FF_TextBox_SetText(hwnd_resistor_text1(0),"R" + Str(rtagnumber ))
rtagnumber is shared, set initially to 0, and each B form is displayed and correctly named in 'Text1(0)' as R1, R2, R3 etc. when Button pressed on the A form
Is that the code you wanted to see, or is there more?
I'm trying to replicate something I wrote about 20 years ago, then using IBM Visual Age for Smalltalk for OS2   ::)
« Last Edit: March 07, 2017, 02:10:47 PM by raymw »
Eddy Van Esch
    • DevOTechS
« Reply #5 on: March 07, 2017, 05:07:20 PM »
Ray,
The syntax of the _Show command is:
MyForm_Show(hwndParent, ShowModalFlag, Optional UserData)The handle 'hwndParent' should be the handle of the parent form (The A form, mentioned in your first post). Is that the case in your code?
The parameter name seems to suggest that the form uses its own handle as 'parent'. But I could be wrong.
Furthermore, try using %False for parameter 'ShowModalFlag' to create a non-modal (or 'modeless') form.
That's what I most often use in my programs (unless the newly shown form really has to be modal).
B form creation
                            ) as Long
« Last Edit: March 07, 2017, 05:12:02 PM by Eddy Van Esch »
Eddy
  • FireFly3 User
« Reply #6 on: March 07, 2017, 05:43:49 PM »
Thanks. setting the resistor_show to
resistor_show(hwnd_resistor, false) was all that was needed...
I can now struggle with the rest of what I'm trying to do.
  • FireFly3 User
« Reply #7 on: March 08, 2017, 12:27:51 PM »
OK, I can open a number of forms, and have given each one a unique tag, (and a reference in a textbox) but how do I programmatically select them to carry out calculations on the values I've entered in the textboxes? Whatever I do, it only seems I can access the last form opened. I need something along the lines of 'get textbox values from form with tag number 5'.
Jean-pierre Leroy
« Reply #8 on: March 08, 2017, 01:49:30 PM »
When you have multiple forms, don't use a direct reference to the texbox like
FF_TextBox_GetText(HWND_FORM1_TEXTBOX1)
Instead use
FF_TextBox_GetText(GetDlgItem(hWndForm, IDC_FORM1_TEXTBOX1))
That should work.
  • FireFly3 User
« Reply #9 on: March 08, 2017, 05:41:07 PM »
Thanks for the reply. My problem lies, initially, in selecting the forms programmatically. I can manually move the curser to any form, and enter values in its textboxes. I then want the program to iterate over each form and do some calculations. I have assigned a unique tag to each form, I am wanting to be able to select a specific form by its tag number, to carry out the calculation, based on the entries made in the form's textboxes, but I am always only able to programmatically access the last form opened.
  • Master Member
« Reply #10 on: March 08, 2017, 08:53:42 PM »
An easy way to track your open modeless forms would be to track the HWND that is returned from your:
You could create a global/shared array of HWND's that you can resize every time you create a new form.
(off the top of my head)
SHARED gFormHandles(ANY) AS HWND
i = UBOUND(gFormHandles)
REDIM PRESERVE gFormHandles(i+1)
gFormHandles(i+1) = resistor_show(hwnd_resistor, false)
You can then easily iterate over all your forms:
FOR i AS LONG = LBOUND(gFormHandles) TO UBOUND(gFormHandles)
   ' Get the info from your textboxes
   sText = AfxGetWindowText( GetDlgItem(gFormHandles(i), IDC_FORM1_TEXTBOX1) )
  • Master Member
« Reply #11 on: March 08, 2017, 08:56:54 PM »
Another approach could be to use the EnumWindows api approach and test each found form for a TAG or classname or some other identifier. Using the HWND returned in the callback function you could do your calculations.
https://msdn.microsoft.com/en-us/library/windows/desktop/ms633497(v=vs.85).aspx
  • FireFly3 User
« Reply #12 on: March 09, 2017, 10:00:51 AM »
A bit of a struggle, but managed to get there, having gone down a number of wrong turns, so thanks for pointing in a suitable direction.
I broke it down into single steps, printing values as I went.
When creating the resistor form, I copied the form hwnd's as suggested, into an array. I then could get to an individual text box in any resistor form, in the following manner
Dim rr as String
    Dim ahwin as HWnd
    For i as Long = LBound(gFormHandles) To UBound(gFormHandles)
        Print gformhandles(i) ,"form handle"
            ahwin =  GetDlgItem(gformhandles(i),idc_resistor_text1(0))
                  Print ahwin, "ahwin text1(0) handle"
                  rr=FF_TextBox_GetText(ahwin)
                  Print rr ,"rr thats what I want"
Next
I will remove the prints, and maybe compress the code a bit, but most likely I'll keep it simple, and put it in a function.
