Author Topic: AfxNls issue  (Read 842 times)
James Fuller
  • Senior FireFly Member
AfxNls issue
« on: March 27, 2017, 03:01:05 PM »
Jose,
  No display for positive.
#Include "Afx/AfxNls.inc"
Function fbMain() As Long
? "Hello"
? AfxGetLocaleNegativeSign()
? AfxGetLocalePositiveSign()
sleep
Function = 0
End fbMain()
  • Master FireFly Member
    • Jos
Re: AfxNls issue
« Reply #1 on: March 27, 2017, 03:27:43 PM »
We don't use a sign for positive numbers in the Western world. No sign in a number means positive; "-", negative.
James Fuller
Re: AfxNls issue
« Reply #2 on: March 27, 2017, 03:37:28 PM »
Jose,
Ok. I was going by your comment for the function:
' String value for the positive sign, for example, "+" for the English (United States)
' locale. The maximum number of characters allowed for this string is five, including a
' terminating null character.
James
    • Jos
Re: AfxNls issue
« Reply #3 on: March 27, 2017, 03:47:02 PM »
It is a comment from the Microsoft documentation. Don't know if there was a local setting for it in older versions of Windows, but the current versions only show a setting for the negative sign.
