Pages: [1] 2
Author Topic: Freebasic Thread Pool  (Read 2521 times)
Richard Kelly
  • Senior FireFly Member
« on: May 24, 2017, 03:53:36 PM »
Does anybody have any experience using the windows thread pool api's?
1. CreateThreadpool
2. SetThreadpoolThreadMaximum
3. SetThreadpoolThreadMinimum
4. CreateThreadpoolWork
5. SubmitThreadpoolWork
6. CloseThreadpoolWork
7. CloseThreadPool
  • Master FireFly Member
Re: Freebasic Thread Pool
« Reply #1 on: May 24, 2017, 04:48:06 PM »
Nope. Sorry. Wish I could help you on this one but threading is not my specialty. :)
Richard Kelly
« Reply #2 on: May 24, 2017, 04:53:51 PM »
Thank you, I'm not sure here, and, the only thing to do is to test, test, test. And, then test some more. For this to work as I'm thinking, I'll also have to have a stack object to push TCP sockets into and have the thread pop 'em off. As long as I'm spending a big chunk of time to get the SQLite client/server stuff going, I might as well as investigate all the stuff MS offers and build a race car version.
Rick
Eddy Van Esch
    • DevOTechS
« Reply #3 on: May 24, 2017, 05:26:17 PM »
What exactly is the purpose of a thread pool? To avoid the overhead of creating and terminating thread functions by having a pool of threads 'standing by' waiting for you to give them something to do? Something like that?
Eddy
Richard Kelly
« Reply #4 on: May 24, 2017, 05:33:48 PM »
Yes
Pierre Bellisle
  • FireFly3 User
  • Junior FireFly Member
« Reply #5 on: May 24, 2017, 10:05:36 PM »
Richard Kelly
« Reply #6 on: May 25, 2017, 09:59:41 AM »
Pierre Bellisle
  • FireFly3 User
« Reply #7 on: May 25, 2017, 12:27:02 PM »
Hey Richard,
Also, the link point to a code demo: Using the Thread Pool Functions
Looks pretty interesting...
Pierre
Richard Kelly
« Reply #8 on: May 25, 2017, 12:53:34 PM »
Hey Richard,
Pierre
I'll use that as a guide.
What got me thinking about a thread pool is trying to decide the ideal number of threads taking into consideration different computers with varying number of cores to exploit maximum system performance. I also know that creating and destroying threads is a relatively expensive process. From my reading on thread pools, the concept is I shouldn't really care how many threads it has. Just submit work to the pool and let Windows determine how to optimally execute each work request. I plan on using this in a multithreading TCP/UDP environment. To be safe, I think I'll "shadow" the TCP socket value using FB Allocate as my pAny as Any Ptr and have the thread get a local copy and then Deallocate. Since I think during program shutdown, it is best to let all outstanding threads complete, I'll also have to come up with a way to determine if there are any outstanding threads still running.
Rick
« Reply #9 on: May 25, 2017, 03:32:01 PM »
....don't make it too complicated, simple people like myself need to be able to follow and understand the code.   :)
Richard Kelly
« Reply #10 on: May 25, 2017, 04:05:02 PM »
Believe me Paul, if I can understand it, you will breeze right through it. In this case, I have to let go of "knowing" everything under the hood and just accept that when I press the gas pedal, the darn car moves. I'm in new territory here....
Rick
Eddy Van Esch
    • DevOTechS
« Reply #11 on: May 25, 2017, 05:14:30 PM »
How about creating your own thread pool system?
You launch a number of threads, as many as you like, and you have them waiting for something to do.
Then you feed them work ..
Doesn't seem impossible to do .. The heart of this is a good system to communicate with the threads. Also to have the threads use no system resources (CPU capacity) when they are waiting .. (WaitForSingleObject ..?) ...
Eddy
Richard Kelly
« Reply #12 on: May 25, 2017, 06:25:22 PM »
Well....this is exactly what the windows thread pool api's do.....
Richard Kelly
« Reply #13 on: May 26, 2017, 12:10:26 AM »
Well Paul, this chunk of code seems to work. I created a private thread pool, submitted three work/thread requests and they ran.
const _WIN32_WINNT = &h0602
#INCLUDE ONCE "windows.bi"
declare sub myThread (byval Instance as PTP_CALLBACK_INSTANCE, byval Context as PVOID, byval Work as PTP_WORK)
dim shared lpCriticalSection as CRITICAL_SECTION
dim iError            as long
dim ptpp              as PTP_POOL
dim reserved          as PVOID
dim ucbe              as TP_CALLBACK_ENVIRON
dim cbe               as PTP_CALLBACK_ENVIRON
dim Work              as PTP_WORK
dim iIndex            as integer
cbe = cast(PTP_CALLBACK_ENVIRON,varptr(ucbe))
InitializeCriticalSection(ByVal VarPtr(lpCriticalSection))
ptpp = CreateThreadpool(reserved)
iError = GetLastError()
if ptpp = 0 THEN
print "CreateThreadPool failed,error=" + str(iError)
      Print "press q to quit"
Do
     Sleep 1, 1
Loop Until Inkey = "q"
      END
print "CreateThreadPool successful..."
TpInitializeCallbackEnviron(cbe)
TpSetCallbackLongFunction(cbe)
for iIndex = 1 to 3
Work = CreateThreadpoolWork(cast(PTP_WORK_CALLBACK,@myThread),cast(PVOID,iIndex),cbe)
SubmitThreadpoolWork(Work)
CloseThreadpoolWork(Work)
sleep 1000,1
TpDestroyCallbackEnviron(cbe)
CloseThreadpool(ptpp)
DeleteCriticalSection(ByVal VarPtr(lpCriticalSection))
Do
     Sleep 1, 1
end
EnterCriticalSection(ByVal VarPtr(lpCriticalSection))
print "Thread started,Instance=" + str(Instance) + ",Context=" + str(Context)
LeaveCriticalSection(ByVal VarPtr(lpCriticalSection))
See if it works for you (an anybody else that wants to give it a shot). I ran with both 32 and 64 bit compiles.
Rick
Pierre Bellisle
  • FireFly3 User
« Reply #14 on: May 26, 2017, 12:13:59 AM »
Jose, I did not find CloseThreadpoolCleanupGroupMembers() in your includes?
Here is a litteral Console-PowerBASIC translation of the MSDN example, using Josee's include.
Code need to be tested... ;-)
Pierre
'https://msdn.microsoft.com/en-us/library/windows/desktop/ms686980(v=vs.85).aspx
'Thread Pools
'A thread pool is a collection of worker threads that efficiently execute asynchronous
'callbacks on behalf of the application. The thread pool is primarily used to reduce
'the number of application threads and provide management of the worker threads.
'Applications can queue work items, associate work with waitable handles,
'automatically queue based on a timer, and bind with I/O.
'The thread pool architecture consists of the following:
'Worker threads that execute the callback functions
'Waiter threads that wait on multiple wait handles
'A work queue
'A default thread pool for each process
'A worker factory that manages the worker threads
'Using Jose Roca include files
'Windows API Headers III v. 1.07 PBWIN 10 or PBCC 6 http://www.jose.it-berater.org/smfforum/index.php?topic=5061.0
'Windows API Headers     v. 1.19 PBWIN  9 or PBCC 5 http://www.jose.it-berater.org/smfforum/index.php?topic=4136.0
#COMPILE EXE '#CC 5.07(D:\Basic\Bas\Jose Roca\Forum\Jose\Windows API Headers\1.19 (PB9.x)\uz)#
#REGISTER NONE
#DIM ALL
#INCLUDE "Win32Api.inc"
#INCLUDE "WinBase.inc"
MACRO TP_POOL               = DWORD 'PTP_POOL is an opaque pointer.
MACRO PTP_WAIT              = DWORD
MACRO TP_WAIT_RESULT        = DWORD
MACRO PTP_WORK              = DWORD
MACRO PTP_TIMER             = DWORD
MACRO PTP_POOL              = DWORD
MACRO PTP_WORK_CALLBACK     = DWORD
MACRO PTP_CALLBACK_INSTANCE = DWORD
MACRO PTP_TIMER_CALLBACK    = DWORD
MACRO PTP_CLEANUP_GROUP     = DWORD
DECLARE FUNCTION CreateThreadpool LIB "Kernel32.dll" ALIAS "CreateThreadpool" _
(BYVAL Reserved AS DWORD) AS DWORD
DECLARE FUNCTION CloseThreadpoolCleanupGroupMembers LIB "Kernel32.dll" ALIAS "CloseThreadpoolCleanupGroupMembers" _
(ptpcg AS PTP_CLEANUP_GROUP,  BYVAL fCancelPendingCallbacks AS LONG, pvCleanupContext AS LONG) AS DWORD
FUNCTION MyWaitCallback(Instance_ AS PTP_CALLBACK_INSTANCE, Parameter AS LONG, Wait AS PTP_WAIT, WaitResult AS TP_WAIT_RESULT) AS DWORD
 'Do something when the wait is over.
 PRINT "MyWaitCallback: wait is over."
FUNCTION MyTimerCallback(Instance_ AS PTP_CALLBACK_INSTANCE, Parameter AS LONG, Timer_ AS PTP_TIMER) AS LONG
 'Do something when the timer fires.
 PRINT "MyTimerCallback: timer has fired."
FUNCTION MyWorkCallback(Instance_ AS PTP_CALLBACK_INSTANCE, Parameter AS LONG, Work AS PTP_WORK) AS LONG
 'Do something when the work callback is invoked.
 PRINT "MyWorkCallback: Task performed."
SUB DemoCleanupPersistentWorkTimer()
 LOCAL CallBackEnviron AS TP_CALLBACK_ENVIRON 'MACRO TP_CALLBACK_ENVIRON = TP_CALLBACK_ENVIRON_V3
 LOCAL WorkCallback    AS PTP_WORK_CALLBACK
 LOCAL TimerCallback   AS PTP_TIMER_CALLBACK
 LOCAL CleanupGroup    AS PTP_CLEANUP_GROUP
 LOCAL Work            AS PTP_WORK
 LOCAL timer_          AS PTP_TIMER
 LOCAL pool            AS PTP_POOL
 LOCAL FileDueTime     AS FILETIME
 LOCAL ulDueTime       AS QUAD
 LOCAL rollback        AS DWORD
 LOCAL bRet            AS LONG
 WorkCallback  = CODEPTR(MyWorkCallback)
 TimerCallback = CODEPTR(MyTimerCallback)
 InitializeThreadpoolEnvironment(CallBackEnviron)
 'Create a custom, dedicated thread pool.
 pool = CreateThreadpool(%NULL)
 IF pool = 0 THEN
   PRINT "CreateThreadpool failed. LastError:" & STR$(GetLastError())
   GOTO main_cleanup
 rollback = 1 'pool creation succeeded
 'The thread pool is made persistent simply by setting
 'both the minimum and maximum threads to 1.
 SetThreadpoolThreadMaximum(BYVAL pool, 1)
 bRet = SetThreadpoolThreadMinimum(BYVAL pool, 1)
 IF bRet = 0 THEN
   PRINT "SetThreadpoolThreadMinimum failed. LastError:" & STR$(GetLastError())
   GOTO main_cleanup
'Create a cleanup group for this thread pool.
 CleanupGroup = CreateThreadpoolCleanupGroup()
 IF CleanupGroup = 0 THEN
   PRINT "CreateThreadpoolCleanupGroup failed. LastError:" & STR$(GetLastError())
   GOTO main_cleanup
 rollback = 2 'Cleanup group creation succeeded
 'Associate the callback environment with our thread pool.
 CallbackEnviron.Pool = Pool
 'Associate the cleanup group with our thread pool.
 'Objects created with the same callback environment
 'as the cleanup group become members of the cleanup group.
 CallbackEnviron.CleanupGroup = CleanupGroup
 'Create work with the callback environment.
 Work = CreateThreadpoolWork(WorkCallback, BYVAL %NULL, CallBackEnviron)
 IF Work = 0 THEN
   PRINT "CreateThreadpoolWork failed. LastError:" & STR$(GetLastError())
   GOTO main_cleanup
 END  IF
 rollback = 3 'Creation of work succeeded
 'Submit the work to the pool. Because this was a pre-allocated
 'work item (using CreateThreadpoolWork), it is guaranteed to execute.
 SubmitThreadpoolWork(BYVAL Work)
 'Create a timer with the same callback environment.
 timer_ = CreateThreadpoolTimer(TimerCallback, BYVAL %NULL, CallBackEnviron)
 IF timer_ = 0 THEN
   PRINT "CreateThreadpoolTimer failed. LastError:" & STR$(GetLastError())
   GOTO main_cleanup
 rollback = 4 'Timer creation succeeded
 'Set the timer to fire in one second.
 ulDueTime = -(1 * 10 * 1000 * 1000)
 FileDueTime.dwHighDateTime = HI(DWORD, ulDueTime)
 FileDueTime.dwLowDateTime  = LO(DWORD, ulDueTime)
 SetThreadpoolTimer(BYVAL timer_, FileDueTime, 0, 0)
 'Delay for the timer to be fired
 Sleep(1500)
 'Wait for all callbacks to finish.
 'CloseThreadpoolCleanupGroupMembers also releases objects
 'that are members of the cleanup group, so it is not necessary
 'to call close functions on individual objects
 'after calling CloseThreadpoolCleanupGroupMembers.
 CloseThreadpoolCleanupGroupMembers(BYVAL CleanupGroup, %FALSE, %NULL)
 'Already cleaned up the work item with the
 'CloseThreadpoolCleanupGroupMembers, so set rollback to 2.
 rollback = 2
 GOTO main_cleanup
 main_cleanup:
 'Clean up any individual pieces manually
 'Notice the fall-through structure of the switch.
 'Clean up in reverse order.
 SELECT CASE rollback
   CASE 4:
   CASE 3: 'Clean up the cleanup group members.
   CASE 2: 'Clean up the cleanup group.
           CloseThreadpoolCleanupGroup(BYVAL CleanupGroup)
   CASE 1: 'Clean up the pool.
           CloseThreadpool(BYVAL pool)
   CASE ELSE
SUB DemoNewRegisterWait()
 LOCAL Wait              AS PTP_WAIT
 LOCAL waitcallback      AS DWORD
 LOCAL PTP_WAIT_CALLBACK AS DWORD
 LOCAL hEvent            AS DWORD
 LOCAL rollback          AS WORD
 LOCAL i                 AS WORD
 waitcallback = CODEPTR(MyWaitCallback)
 'Create an auto-reset event.
 hEvent = CreateEvent("", %FALSE, %FALSE, "")
 IF hEvent = 0 THEN
   PRINT "Error Handling"
   EXIT SUB
 END  IF
 rollback = 1 'CreateEvent succeeded
 Wait = CreateThreadpoolWait(waitcallback, BYVAL %NULL, "")
 IF Wait = 0 THEN
   PRINT "CreateThreadpoolWait failed. LastError:" & STR$(GetLastError())
   GOTO new_wait_cleanup
 rollback = 2 'CreateThreadpoolWait succeeded
 'Need to re-register the event with the wait object
 'each time before signaling the event to trigger the wait callback.
 FOR i = 0 TO 4
   SetThreadpoolWait(BYVAL Wait, BYVAL hEvent, BYVAL %NULL)
   SetEvent(hEvent)
   'Delay for the waiter thread to act if necessary.
   SLEEP(500)
   'Block here until the callback function is done executing.
   WaitForThreadpoolWaitCallbacks(BYVAL Wait, %FALSE)
 new_wait_cleanup:
   CASE 2 'Unregister the wait by setting the event to NULL.
     SetThreadpoolWait(BYVAL Wait, %NULL, "")
     'Close the wait.
     CloseThreadpoolWait(BYVAL Wait)
   CASE 1
     'Close the event.
     CloseHandle(hEvent)
   CASE ELSE
FUNCTION PBMAIN() AS LONG
 PRINT : PRINT "Type or click..." : MOUSE ON : MOUSE 3, UP : WAITKEY$
'______________________________________________________________________________
« Last Edit: May 31, 2017, 02:47:48 PM by Pierre Bellisle »
Pages: [1] 2
