Author Topic: CWindow Release Candidate 28  (Read 982 times)
  • Master FireFly Member
    • Josť Roca Software
« on: June 03, 2017, 01:58:23 PM »
New classes:
CCDAudio: Plays an audio CD
CDSAudio: Plays audio files using Direct Show
CCDOMessage: Sends emails using CDO
CMemBmp: Creates memory bitmaps
CWmiCli: WMI wrapper class to easily do WMI queries
New dialog:
AfxInputBox: Input box dialog.
Re: CWindow Release Candidate 28
« Reply #1 on: June 04, 2017, 05:46:42 PM »
Added an overloaded DrawBitmap method to the CMemBmp and CGraphCtx classes to accept a pointer to a GDI+ bitmap as input.
Fixed a bug in the default constuctor of the CMemBmp class that caused FillRect to fail and the background color was unchanged.
« Reply #2 on: June 05, 2017, 10:16:55 PM »
Modified the AfxGetWindowText function, that was returning an ending null.
' Gets the text of a window. This function can also be used to retrieve the text of buttons,
' and edit and static controls.
' Remarks: The function uses the WM_GETTEXT message because GetWindowText cannot retrieve
' the text of a window in another application.
' Example: DIM cws AS CWSTR = AfxGetWindowText(hwnd)
PRIVATE FUNCTION AfxGetWindowText (BYVAL hwnd AS HWND) AS CWSTR
   DIM nLen AS LONG = SendMessageW(hwnd, WM_GETTEXTLENGTH, 0, 0)
   DIM cwsText AS CWSTR = SPACE(nLen + 1)
   SendMessageW(hwnd, WM_GETTEXT, nLen + 1, cast(LPARAM, *cwsText))
   RETURN LEFT(**cwsText, LEN(cwsText) - 1)
« Last Edit: June 06, 2017, 11:28:27 AM by Josť Roca »
James Klutho
  • Senior FireFly Member
« Reply #3 on: June 06, 2017, 11:16:09 AM »
Thanks for your cMemBitmap class.  I already found a use for it.  Jim
« Reply #4 on: June 29, 2017, 04:36:24 PM »
On line documentation for the CWindow Framework
http://www.jose.it-berater.org/CWindow/CWindowFramework.html
Andrew Lindsay
  • Junior FireFly Member
« Reply #5 on: June 29, 2017, 08:46:07 PM »
Jose,
That's brilliant.  Thanks for all the help and support you are giving to the community.
« Reply #6 on: June 30, 2017, 09:35:46 AM »
A new class, CRegExp, VB Script regular expressions.
Some usage examples:
Execute method:
#define UNICODE
#INCLUDE ONCE "Afx/CRegExp.inc"
USING Afx
DIM pRegExp AS CRegExp = CRegExp("is.", TRUE, TRUE)
IF pRegExp.Execute("IS1 is2 IS3 is4") = FALSE THEN
   print "No match found"
   DIM nCount AS LONG = pRegExp.MatchCount
   FOR i AS LONG = 0 TO nCount - 1
      print "Value: ", pRegExp.MatchValue(i)
      print "Position: ", pRegExp.MatchPos(i)
      print "Length: ", pRegExp.MatchLen(i)
      print
#define UNICODE
USING Afx
pRegExp.Pattern = "is."
pRegExp.IgnoreCase = TRUE
pRegExp.Global = TRUE
      print
Test method:
#define UNICODE
USING Afx
IF pRegExp.Test("IS1 is2 IS3 is4") THEN
   print "One or more matches were found"
Replace method:
#define UNICODE
USING Afx
pRegExp.Pattern = "fox"
DIM cwsText AS CWSTR = "The quick brown fox jumped over the lazy dog."
' Make replacement
DIM cwsRes AS CWSTR = pRegExp.Replace(cwsText, "cat")
print cwsRes
Sub matches:
pRegExp.Pattern = "(\w+)@(\w+)\.(\w+)"
DIM cwsText AS CWSTR = "Please send mail to dragon@xyzzy.com. Thanks!"
IF pRegExp.Execute(cwsText) = FALSE THEN
   ' Get the number of submatches
   DIM nCount AS LONG = pRegExp.SubMatchCount(0)
   print "Sub matches: ", nCount
      print pRegExp.SubMatchValue(0, i)
« Reply #7 on: June 30, 2017, 06:11:19 PM »
New classes to create shortcuts: CShortcut and CURLShortcut.
Usage example (CShortcut):
' Creates a shortcut programatically (if it already exists, opens it)
DIM pShortcut AS CShortcut = ExePath & "\Test.lnk"   ' --> change me
' Sets various properties and saves them to disk
pShortcut.Description = "Hello world"   ' --> change me
pShortcut.WorkingDirectory = ExePath & "\"   ' --> change me
pShortcut.Arguments = "/c"   ' --> change me
pShortcut.HotKey = "Ctrl+Alt+e"   ' --> change me
pShortcut.IconLocation = ExePath & "\Program.ico,0"   ' --> change me
pShortcut.RelativePath = ExePath & "\"   ' --> change me
pShortcut.TargetPath = ExePath & $"\HelloWord.exe"   ' --> change me
pShortcut.WindowStyle = WshNormalFocus
pShortcut.Save
Usage example (CURLShortcut):
DIM pURLShortcut AS CURLShortcut = ExePath & "\Microsoft Web Site.url"   ' --> change me
pURLShortcut.TargetPath = "http://www.microsoft.com"   ' --> change me
pURLShortcut.Save
James Fuller
« Reply #8 on: June 30, 2017, 07:16:32 PM »
Josť,
  Good stuff!!!! but....
  In CWindow AddControl "LABEL" you set dwExStyle to zero regardless of the value passed in.
I often use a value of one to give a raised border.
James
« Reply #9 on: June 30, 2017, 08:05:40 PM »
Ok. I will remove all the dwExStyle = 0.
« Last Edit: June 30, 2017, 08:20:33 PM by Josť Roca »
James Fuller
« Reply #10 on: July 01, 2017, 07:08:23 AM »
Josť,
  In my translation I added:
If dwExStyle = -1 Then
    dwExStyle = 0
To all the items that just assigned a zero.
James
« Reply #11 on: July 01, 2017, 07:36:17 AM »
I'm lazier and use
   ' // Don't allow negative values for the styles
   IF dwStyle = -1 THEN dwStyle = 0
   IF dwExStyle = -1 THEN dwExStyle = 0
   ' // Make sure that the control has the WS_CHILD style
   dwStyle = dwStyle OR WS_CHILD
   ' // Create the control
   hCtl = .CreateWindowExW(dwExStyle, wsClassName, wszTitle, dwStyle, x * m_rx, y * m_ry, nWidth * m_rx, nHeight * m_ry, _
          hParent, CAST(HMENU, CAST(LONG_PTR, cID)), m_hInstance, CAST(LPVOID, lpParam))
just before calling CreateWindowExW.
« Reply #12 on: July 01, 2017, 02:52:29 PM »
Using the CWebBrowser class to display pictures.
' Microsoft Windows
' File: CW_WB_DisplayPicture.fbtpl
' Contents: WebBrowser - Display picture
' Copyright (c) 2017 Josť Roca. Freeware. Use at your own risk.
#define UNICODE
#INCLUDE ONCE "Afx/CWebBrowser/CWebBrowser.inc"
USING Afx
CONST IDC_WEBBROWSER = 1001
' // Forward declaration
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Creates the main window
   DIM pWindow AS CWindow
   DIM hwndMain AS HWND = pWindow.Create(NULL, "WebBrowser - Display picture", @WndProc)
   pWindow.SetClientSize(600, 350)
   ' // Centers the window
   pWindow.Center
   ' // Add a WebBrowser control
   DIM pwb AS CWebBrowser = CWebBrowser(@pWindow, IDC_WEBBROWSER, 0, 0, pWindow.ClientWidth, pWindow.ClientHeight)
   ' // Set the IDocHostUIHandler interface
   pwb.SetUIHandler
'   ' // Script to display the picture (fit to width)
'   DIM cws AS CWSTR = "<body scroll='auto' style='margin: 0px 0px 0px 0px'>"
'   cws += "<img src='http://www.kenrockwell.com/trips/2016-05-yosemite/RX300658-green-falls.jpg' border='0' width='100%'></img>"
'   cws += "</body>"
'   ' // Script to display the picture (fit to height)
'   cws += "<img src='http://www.kenrockwell.com/trips/2016-05-yosemite/RX300658-green-falls.jpg' border='0' height='100%'></img>"
'   cws += "</body>"
   ' // Script to display the picture (zoom width by 20%)
   cws += "<img src='http://www.kenrockwell.com/trips/2016-05-yosemite/RX300658-green-falls.jpg' border='0' width='120%'></img>"
   cws += "</body>"
   ' // Script to display the picture (fit to height, center)
'   cws += "<center>"
'   cws += "<img src='https://upload.wikimedia.org/wikipedia/commons/2/28/Nicole_Kidman_Cannes_2017_2.jpg' border='0' height='100%'></img>"
'   cws += "<center>"
'   cws += "</body>"
'   // To display from files stored in the computer
'   bstrHTML += "<img src='file://C:\Users\Pepe\FreeBasic64\MyExamples\ImageCtx\VEGA_PAZ_01.jpg' border='0' width='100%'></img>"
'   bstrHTML += "<img src='file://C:\Users\Pepe\FreeBasic64\MyExamples\ImageCtx\VEGA_PAZ_01.jpg' border='0'></img>"
   ' // Write the HTML code in the web page
   pwb.WriteHtml(cws)
' Main window procedure
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_SIZE
         ' // Optional resizing code
            ' // Move the position of the control
            IF pWindow THEN pWindow->MoveWindow GetDlgItem(hwnd, IDC_WEBBROWSER), _
               0, 0, pWindow->ClientWidth, pWindow->ClientHeight, CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
