Author Topic: Question about focus  (Read 947 times)
Wilko Verweij
  • Junior FireFly Member
  • PB10 - FF3.7 User; Win 10
    • CHEAQS
« on: June 13, 2017, 06:27:58 PM »
Hi all,
I have a question about focus in Firefly freebasic. I had a problem that I did not understand. To make it easier, I made a very simple test program which has the same problem as my real-world-program. Just one small window, two buttons, both 'push buttons', no 'default button', one of the has the 'cancel'-property set. Both have ws_tabstop property set. First button is on top of tab order. No additional code written by me. Compiles fine. When I start the program, it looks like in P1.png. Does not look strange so far, but when I press tab, the cancel-button (which then receives the focus) looks quite different. And if I press tab again, focus goes back to first button but then looks like picture P2. What I would like is that the initial view is like the P2 picture. How can I do that? Any help is appreciated...
Wilko
  • Master FireFly Member
    • Jos
Re: Question about focus
« Reply #1 on: June 13, 2017, 09:46:52 PM »
Sey the focus in the OK button.
Wilko Verweij
    • CHEAQS
« Reply #2 on: June 14, 2017, 04:39:32 AM »
Sorry, I forgot to mention that I tried SetFocus, in the FORM1_WM_CREATE Function. So apparently that's not the right place. Where should I put it?
    • Jos
« Reply #3 on: June 14, 2017, 12:50:56 PM »
Post a custom message, e.g.
PostMessage hWnd, %WM_USER + 999, hButton, 0
and then set the focus when processing that message
CASE %WM_USER + 999
   IF wParam THEN SetFocus wParam
James Fuller
  • Senior FireFly Member
« Reply #4 on: June 14, 2017, 01:08:31 PM »
    • Jos
« Reply #5 on: June 14, 2017, 01:25:42 PM »
Why not? The only requisite is that it must be unique.
« Last Edit: June 14, 2017, 01:27:46 PM by Jose Roca »
Pierre Bellisle
  • FireFly3 User
« Reply #6 on: June 14, 2017, 02:02:34 PM »
Hey,
For me SetFocus() work with or without a PostMessage() if I do not use CommonControl6 via a manifest.
If I use a CommonControl6 then SetFocus() won't do it alone. I got to add
 SendMessage(hWnd, WM_CHANGEUISTATE, MakeLong(UIS_CLEAR, UISF_HIDEFOCUS), 0)
But to really mimic the behavior I think Wilko want, I got to use this not so clean method to simulate a TAB and a SHIFT-TAB
 SetFocus(handleOfMyButton)
 KeyBd_Event VK_TAB, 0, 0, 0
 KeyBd_Event VK_TAB, 0, KEYEVENTF_KEYUP, 0
 KeyBd_Event VK_SHIFT, 0, 0, 0
 KeyBd_Event VK_SHIFT, 0, KEYEVENTF_KEYUP, 0
Pierre
« Last Edit: June 14, 2017, 02:04:50 PM by Pierre Bellisle »
Wilko Verweij
    • CHEAQS
« Reply #7 on: June 14, 2017, 02:17:45 PM »
OK, thank you all for your suggestions. I am going to test them later this week.
    • Jos
« Reply #8 on: June 14, 2017, 02:26:59 PM »
Posting a message and setting the focus when processing that message has always worked for me.
Anyway, since using CWindow, I no longer need to use it because I add the controls after the main window has been created, not in WM_CREATE.
Pierre Bellisle
  • FireFly3 User
« Reply #9 on: June 14, 2017, 05:20:01 PM »
Hola Jose,
I think that Wilco is interested not only in the focus but also in the look his button have.
Meaning the focus dotted line and the highlighted button edge.
I did some quick test on Windows 7 and 10, with Common control 6.0 and 5.82,
And SetFocus/KeyBd_Event, SetFocus/WM_CHANGEUISTATE, PostMessage/SetFocus.
Results are in the code, in the "Select Case" section. :-)
Pierre
#Define JumpCompiler "<D:\Free\64\fbc.exe>"
#Define JumpCompilerCmd "<-s gui "D:\Free\bas\~~Default.rc">"
#define unicode
#Include Once "windows.bi"
#Include Once "win\shellapi.bi" 'ExtractIcon()
ENUM
  ButtonOk  = 101
  ButtonEsc
END ENUM
#Define AppName "Focus"
Dim Shared As HINSTANCE hInstance : hInstance = GetModuleHandle(NULL)
'______________________________________________________________________________
Function WndProc(hWnd As HWND, uMsg As UINT, wParam As WPARAM, lParam As LPARAM) As Integer
 Static hButtonOk    As HWND
 Dim    hButtonEsc   As HWND
 Static hFont        As HFONT
 Select Case (uMsg)
   Case WM_CREATE
     Function = False
     hFont = GetStockObject(DEFAULT_GUI_FONT)
     hButtonOk = CreateWindowEx(0, "Button", "&OK", _
                                WS_CHILD Or WS_VISIBLE Or WS_TABSTOP Or WS_GROUP Or _
                                BS_CENTER Or BS_VCENTER, _
                                25, 15, 80, 30, _
                                hWnd, Cast(HMENU, ButtonOk), _
                                hInstance, NULL)
     SendMessage(hButtonOk, WM_SETFONT, Cast(UInteger, hFont), TRUE)
     hButtonEsc = CreateWindowEx(0, "Button", "&Cancel", _
                                 WS_CHILD Or WS_VISIBLE Or BS_CENTER Or WS_TABSTOP Or _
                                 BS_NOTIFY Or BS_TEXT Or BS_VCENTER, _
                                 135, 15, 80, 30, _
                                 hWnd, Cast(HMENU, ButtonEsc), _
                                 hInstance, NULL)
     SendMessage(hButtonEsc, WM_SETFONT, Cast(UInteger, hFont), TRUE)
     Dim As Long TryOption = 1 '+ 1 + 1
     Select Case TryOption
       Case 1
         'Button "OK" start with dotted line and highlighted  edge if CommonControl 6.0   (Win 10 and Win 7)
         'Button "OK" start with dotted line and no highlight edge if CommonControl 5.82  (Win 10 and Win 7)
         SetFocus(hButtonOk)
       Case 2
         'Button "OK" start with dotted line and no highlighted edge if CommonControl 6.0  (Win 10 and Win 7)
         'Button "OK" start with dotted line and no highlighted edge if CommonControl 5.82 (Win 10 and Win 7)
         SetFocus(hButtonOk) 'SetFocus alone is ok if no CommControl6
       Case 3
         'Button "OK" start with no dotted line and no highlight edge if CommonControl 6.0  (Win 10 and Win 7)
         PostMessage(hWnd, WM_APP, 0, 0)
   Case WM_APP
     SetFocus(hButtonOk)
   Case WM_CHANGEUISTATE
   Case WM_COMMAND
     Select Case LoWord(wParam)
       Case ButtonOk
         If HiWord(wParam) = BN_CLICKED Then
           _Beep(1500, 100)
         EndIf
       Case ButtonEsc, IDCANCEL
           PostMessage(hWnd, WM_CLOSE, 0, 0)
           Exit Function
         EndIf
   Case WM_DESTROY
     DeleteObject(hFont)
     PostQuitMessage(0)
     Exit Function
 Function = DefWindowProc(hWnd, uMsg, wParam, lParam)
Function WinMain(hInstance As HINSTANCE, hPrevInst As HINSTANCE, _
                 CmdLine As WString Ptr, CmdShow As Integer) As UINT
 Dim WinClass   As WNDCLASS
 Dim wMsg       As MSG
 Dim hWnd       As HWND
 Dim hIco       As HICON
 Dim WindowSize As SIZEL
 Dim wsAppName  As WSTRING * 128
 wsAppName              = AppName & " - " & SizeOf(UInteger) * 8
 WindowSize.cx          = 245
 WindowSize.cy          = 90
 hIco                   = ExtractIcon(hInstance, "%SystemRoot%\System32\PowrPrOf.dll", 1)
 WinClass.style         = CS_HREDRAW Or CS_VREDRAW
 WinClass.lpfnWndProc   = ProcPtr(WndProc)
 WinClass.cbClsExtra    = 0
 WinClass.cbWndExtra    = 0
 WinClass.hInstance     = hInstance
 WinClass.hIcon         = hIco
 WinClass.hCursor       = LoadCursor(NULL, IDC_ARROW)
 WinClass.hbrBackground = Cast(HGDIOBJ, COLOR_BTNFACE + 1) 'Default color
 WinClass.lpszMenuName  = NULL
 WinClass.lpszClassName = @wsAppName
 If (RegisterClass(@WinClass)) Then
   hWnd = CreateWindowEx(WS_EX_WINDOWEDGE, _
                         wsAppName, wsAppName, _
                         WS_OVERLAPPED OR WS_CLIPCHILDREN Or WS_DLGFRAME Or WS_BORDER Or WS_VISIBLE Or WS_CAPTION Or _
                         WS_MAXIMIZEBOX Or WS_MINIMIZEBOX Or WS_SYSMENU , _
                         (GetSystemMetrics(SM_CXSCREEN) - WindowSize.cx) / 2, _ 'PosH
                         (GetSystemMetrics(SM_CYSCREEN) - WindowSize.cy) / 2, _ 'PosV
                         WindowSize.cx, WindowSize.cy, _ 'Width, height
                         NULL, NULL, hInstance, NULL)
   ShowWindow(hWnd, SW_SHOW)
   UpdateWindow(hWnd)
   While GetMessage(@wMsg, ByVal NULL, 0, 0) > 0
     If IsDialogMessage(hWnd, @wMsg) = 0 Then
         TranslateMessage(@wMsg)
         DispatchMessage(@wMsg)
   Wend
  DestroyIcon(hIco)
  Function = wMsg.message
End WinMain(hInstance, NULL, Command(), SW_NORMAL) 'Call main() and return the error code to the OS
    • Jos
« Reply #10 on: June 14, 2017, 06:13:30 PM »
I see. I didn't pay enough attention to the pictures.
BTW I advice you to specify BYVAL or BYREF in the parameters of your functions, e.g.
Function WinMain(BYVAL hInstance As HINSTANCE, BYVAL hPrevInst As HINSTANCE, _
                 BYVAL CmdLine As WString Ptr, BYVAL CmdShow As Integer) As UINT
Otherwise you will get errors if compiled using the "pedantic" option.
Wilko Verweij
    • CHEAQS
« Reply #11 on: June 17, 2017, 06:14:59 PM »
Thank you guys. This really helps.
Wilko
