Author Topic: Passing Parameters  (Read 1098 times)
Klaas Holland
Passing Parameters
« on: June 19, 2017, 11:43:56 AM »
In CDbl and CLng you can pass both a String expression or a Numeric expression.
Is it possible to create a Function with these possibilities?
If so, how do you do it?
  • Master Member
    • Jos
Re: Passing Parameters
« Reply #1 on: June 19, 2017, 02:31:23 PM »
Yes.
FUNCTION Foo OVERLOAD (BYVAL x AS DOUBLE) AS LONG
FUNCTION Foo OVERLOAD (BYREF x AS STRING) AS LONG
Klaas Holland
« Reply #2 on: June 19, 2017, 06:21:04 PM »
Sorry, but how do I implement this here?
Function EFormat (ByVal nValue as Long) as String
    Dim as String v = Format (nValue/100, "#.00")
    Function = v
  • Master Member
    • Jos
« Reply #3 on: June 19, 2017, 06:34:19 PM »
Function EFormat Overload (ByVal nValue as Long) as String
    Function = v
Function EFormat Overload (ByRef strValue as String) as String
    Dim as String v = Format (Val(strValue)/100, "#.00")
    Function = v
Usage:
print EFormat(1234)
print EFormat("1234")
« Last Edit: June 19, 2017, 06:37:04 PM by Jose Roca »
Klaas Holland
« Reply #4 on: June 20, 2017, 07:14:54 AM »
Thanks Jose,
You are a genius.
