Author Topic: lstrcpy syntax?  (Read 788 times)
jermy
  • FireFly3 User
  • Little Newbie FireFly
lstrcpy syntax?
« on: June 23, 2017, 11:20:19 AM »
Hello,
I'm translating a program from vb6 to freebasic, I'm stuck with this piece of code.
the compiler telles me 'Argument count mismatch' ?
' Declare Function lstrcpyA Lib "kernel32" (ByVal RetVal As String, ByVal Potr As Long) As Long     'vb6 syntax
Function GetString(ByVal lpszA as Long) as String
  ' GetString = String$(lstrlenA(ByVal lpszA), 0)    'vb6 syntax
  GetString = String$(Len(lpszA), 0)
  ' Call lstrcpyA(ByVal GetString, ByVal lpszA)      'vb6 syntax
  lstrcpy(ByVal GetString, ByVal Cast(String, lpszA))
What am I doing wrong?
  • Master FireFly Member
    • Josť Roca Software
Re: lstrcpy syntax?
« Reply #1 on: June 23, 2017, 11:51:08 AM »
Everything, beginning with trying to use a VB syntax with FB.
Can we know what are you passing in the lpszA parameter? Maybe a pointer to a null terminated string? I strongly doubt that with FB you will need to use lstrcpy to simply copy a string.
Pierre Bellisle
  • FireFly3 User
  • Junior FireFly Member
Re: lstrcpy syntax?
« Reply #2 on: June 23, 2017, 08:49:54 PM »
Hi Jermy,
I guess you think of something like this... Is that it?
Pierre
Function GetString(ByVal lpSZA as LPTSTR) as String  'Convert a ZSTRING to a Dynamic string
 'One way... Dim As String sGetString = String$(lstrlenA(Cast(LPTSTR ,lpSZA)), 0) 'Build a big enough dynamic string
 'One way... Dim As LPTSTR pString = StrPtr(sGetString) 'Get the pointer of the dynamic string
 'One way... lStrCpyA(pString, Cast(LPTSTR, lpSZA)) 'Copy the ZSTRING to the dynamic string
 'One way... FUNCTION = *pString 'Set the dynamic string content to the function
 FUNCTION = *lpSZA 'Set the dynamic string content to the function
Dim As ZString * 50 zs = "123"
? GetString(@zs)
jermy
  • FireFly3 User
Re: lstrcpy syntax?
« Reply #3 on: June 24, 2017, 06:52:17 AM »
lpszA = Long Pointer String z? ansi
Now i see it, its a ugly vb6 work around.
Declare Function lstrlenA Lib "kernel32" (ByVal lpString as Long) as Long  ''' Determines the length of the specified string (not including the terminating null character)
Declare Function inet_ntoa Lib "wsock32.dll" (ByVal addr as Long) as Long  ''' The inet_ntoa function converts an (Ipv4) Internet network address into an ASCII string in Internet standard dotted-decimal format.
' If no error occurs, inet_ntoa returns a character pointer to a static buffer containing the text address in standard ".'' notation. Otherwise, it returns NULL.
Function GetInetAddrStr(Address as Long) as String
  GetInetAddrStr = GetString(inet_ntoa(Address))
  ' GetString = String$(Len(lpszA), 0)
'  lstrcpyA(ByVal GetString, ByVal Cast(String, lpszA))
most vb6 programs i can copy and paste to freebasic, this one got some ugly work around, its better to start all over again.  ;D
« Last Edit: June 24, 2017, 06:56:05 AM by jermy »
Pierre Bellisle
  • FireFly3 User
Re: lstrcpy syntax?
« Reply #4 on: June 24, 2017, 04:29:57 PM »
Another way...
Pierre
'\64\fbc.exe -s console -w pedantic
#Lang "fb"
#Define Unicode
#Include once "windows.bi"
#Include once "win\winsock2.bi"
Function GetString(ByVal lpSZA as zString Pointer) as String  'Convert a ZSTRING to a Dynamic string
 'One way... Dim As String sGetString = String$(lstrlenA(Cast(LPTSTR ,lpSZA)), 0) 'Build a big enought dynamic string
Function GetInetAddrStr01(ByVal Address as DWORD) as String 'Pointer
 Dim inAddr As in_addr
 inAddr.S_addr = Address
 Function = GetString(inet_ntoa(inAddr))
Function GetInetAddrStr02(ByVal Address as DWORD) as String
 Function = *inet_ntoa(inAddr)
Print GetInetAddrStr01(&h04030201)
Print GetInetAddrStr02(&h01020304)
Print
Print "Press a key or click to end" : Dim buttons As Long
Do : GetMouse(0, 0, 0, Buttons) : IF buttons Or Len(InKey) Then Exit Do : End If : Sleep 200 : Loop
jermy
  • FireFly3 User
Re: lstrcpy syntax?
« Reply #5 on: June 30, 2017, 04:12:08 PM »
Thanks Pierre, It pointed me to the right direction  :)
