Author Topic: WinFBE 1.3.6 on GitHub (July 21, 2017)  (Read 246 times)
  • Master FireFly Member
« on: July 21, 2017, 05:02:37 PM »
Version 1.3.6 (July 21, 2017)
- Fixed: Regression 1.3.4 #CONSOLE ON|OFF incorrectly overriding GUI/CONSOLE setting in some cases.
    • Josť Roca Software
Re: WinFBE 1.3.6 on GitHub (July 21, 2017)
« Reply #1 on: July 22, 2017, 04:46:43 AM »
> #CONSOLE ON|OFF
How to use it?
BTW the editor no longer rems blank lines, but still rems lines that only have spaces.
« Reply #2 on: July 22, 2017, 09:47:47 AM »
> #CONSOLE ON|OFF
How to use it?
Simply put it in the main bas file that you are compiling. It is part of a comment line.
' #CONSOLE ON
or
' #CONSOLE OFF
Ok, I'll also check for only space lines. That will be in the next update.
