Author Topic: WinFBE 1.3.8 on GitHub (July 22, 2017)  (Read 1007 times)
  • Master FireFly Member
« on: July 22, 2017, 04:37:27 PM »
Version 1.3.8 (July 22, 2017)
- Added: Runtime errors are trapped and reported in WinFBE if any of the -e error checking is enabled.
- Changed: Comment Blocking no longer comments lines containing just spaces.
« Last Edit: July 22, 2017, 06:41:45 PM by TechSupport »
    • Jos
Re: WinFBE 1.3.8 on GitHub (July 22, 2017)
« Reply #1 on: July 24, 2017, 09:38:53 PM »
You could add the option "Ask before exiting the editor?"
« Reply #2 on: July 25, 2017, 10:51:33 PM »
Thanks, I have it on my list now. Should be there in the next update.
« Reply #3 on: July 29, 2017, 07:07:40 PM »
This option has now been implemented.
Now working on a Build Configuration system (see attachment for screenshot of the dialog).
« Reply #4 on: July 30, 2017, 05:34:23 PM »
Current dialog now looks like the attached and is now fully functional. Next step is to build the combobox in the toolbar and also modify the Project Options dialog to handle selecting any of these pre-configured builds (in addition to allowing additional compiler options specific to the project). Finally, I will need to cleanse the editor of the various areas where you can toggle between 32/64 bit and gui/console because these will now be handled by the build configurations.
Getting there... slowly but surely/
Also need to build in the "Quick Run" functionality before uploading a new release.
    • Jos
« Reply #5 on: July 30, 2017, 06:16:53 PM »
Looks good. Maybe you should add a shortcut key for easy access (probably you already thought about it, but just in case).
« Reply #6 on: July 31, 2017, 12:26:48 PM »
No problem at all. I have assigned the F7 key as the shortcut.
    • Jos
« Reply #7 on: July 31, 2017, 02:32:55 PM »
After loading and closing a project, if I load a bas file it loads it as if it was a module.
« Reply #8 on: July 31, 2017, 06:22:53 PM »
That's odd. i haven't been able to replicate the problem yet.
    • Jos
« Reply #9 on: July 31, 2017, 07:33:48 PM »
I neither can reproduce it at will, but it has happened to me some times and the only solution is to restart the editor.
« Reply #10 on: July 31, 2017, 09:44:09 PM »
I just had it happen as well.
