Pages: [1] 2 3 4
Author Topic: WinFBE 1.4.1 on GitHub (August 3, 2017)  (Read 1955 times)
  • Master FireFly Member
« on: August 02, 2017, 04:43:54 PM »
This is a pretty major update to the editor especially with the new build configuration system. Please try it out and post your comments below. I will fix any issues and then make a post over on the FreeBasic site that v1.4.0 is available.
- Added: Major change. New Build Configuration system.
- Added: Quick Run (added to Compile menu and Toolbar).
- Added: Option (Environment Options :: General Options) for "Ask before exiting the editor".
- Added: Check added to catch whether a loaded file has been *deleted* by something external. Message now displays asking whether to keep file open or close it.
- Change: The "Run Executable" functionality now runs the currently active source code file should the EXE exist. Previously would always run the most recently executed exe.
« Last Edit: August 03, 2017, 07:27:52 PM by TechSupport »
    • Josť Roca Software
Re: WinFBE 1.4.0 on GitHub (August 2, 2017)
« Reply #1 on: August 02, 2017, 06:26:16 PM »
When clicking Delete configuration, I would ask if I'm sure? Too easy to click the button by accident.
« Reply #2 on: August 02, 2017, 06:35:13 PM »
After selecting a different configuration, the change it's not immediately displayed in the status bar.
« Reply #3 on: August 02, 2017, 06:53:10 PM »
Weird. Sometimes, when I click F5 to compile, instead of compiling it activates the Explorer window.
« Reply #4 on: August 02, 2017, 07:11:38 PM »
Thanks! Done. Easily fixed. Will be in next upload.
« Reply #5 on: August 02, 2017, 07:21:39 PM »
Done. Change will be in the next upload.
« Reply #6 on: August 02, 2017, 07:24:25 PM »
Hmmm... can't say that I've ever experienced that. F9 would activate the Explorer window. I just checked the code and everything seems to be mapped to the correct places.
« Reply #7 on: August 02, 2017, 07:27:21 PM »
New EXE's uploaded to GitHub. You would also need to download the .lang language files because I added a string for the "confirm delete build configuration".
« Reply #8 on: August 02, 2017, 07:35:26 PM »
I don't mean the explorer of the editor, but Windows Explorer.
« Reply #9 on: August 02, 2017, 07:54:04 PM »
Well, that seems even weirder!  :)  ;)  :)
« Reply #10 on: August 02, 2017, 07:58:48 PM »
Just some points to consider:
You will notice that if you load multiple source files into the editor (not in a project), that you can designate a different build configuration for each one.
Also, in the Build Configuration dialog you can set one (or none) build to be the "default". If a default build is selected then any file loaded into the editor will use that default build. If no default is specified then the file being opened will use whatever build happens to be selected at that time. Projects save whatever build is assigned to them.
The builds are each assigned a GUID string when they are created. This allows you to add new builds, delete builds, move builds around, and the loaded editor files will always reference the correct build. It does not rely on the listbox index of the build.
« Reply #11 on: August 02, 2017, 08:13:27 PM »
It has happened to me several times, but can't repeat it at will. I'm working in a new class, and I run the test code many times, sometimes letting the editor to save the changes before compiling and sometimes saving it before compiling, just to see if not saving the code had something to do with iy, but it has happened to me in both cases.
« Reply #12 on: August 02, 2017, 08:36:21 PM »
Always activates Windows Explorer with the My Documents folder selected.
« Reply #13 on: August 02, 2017, 09:36:25 PM »
I have been scouring Google trying to find some reference to Explorer getting invoked by F5..... haven't found anything. Every article just talks about F5 as invoking a refresh. I wonder do you have any programs in the background that may be stealing focus from the editor just before you press F5 to compile. I think you have have stumbled onto one of the great mysteries of the universe :)
« Reply #14 on: August 02, 2017, 10:02:53 PM »
No, I don't, and it only has happened when using this last version.
Pages: [1] 2 3 4
