Pages: 1 [2] 3 4
Author Topic: WinFBE 1.4.1 on GitHub (August 3, 2017)  (Read 3161 times)
  • Master FireFly Member
Re: WinFBE 1.4.0 on GitHub (August 2, 2017)
« Reply #15 on: August 02, 2017, 10:11:22 PM »
I wonder does it happen when the "Run compiled programs using command window" option is set in Compiler Setup? That option generates a batch file during compile so maybe it somehow triggers something in Windows 7.
    • Jos
« Reply #16 on: August 02, 2017, 10:26:13 PM »
I have this option unchecked. Didn't even know that it existed.
    • Jos
« Reply #17 on: August 02, 2017, 10:31:58 PM »
The way to launch Windows Explorer is using ShellExecute. Check your code if you're using this function.
« Reply #18 on: August 02, 2017, 10:34:10 PM »
I added it a few days ago for fxm so that runtime error messages could be caught/viewed when compiling and running a program using -exx compiler option. Originally I tried to catch the STDERR output through a pipe but it did not work cleanly because unfortunately the compiler was designed to output error messages to STDOUT.
« Reply #19 on: August 02, 2017, 10:35:33 PM »
...yes, I am using ShellExecuteEx in a few places within the code_Compile.inc source file.
I use it to execute the batch file that does the actual compiling and I also use it again in the RunExe function that executes and runs the compiled program.
« Last Edit: August 02, 2017, 10:40:06 PM by TechSupport »
    • Jos
« Reply #20 on: August 02, 2017, 11:10:00 PM »
Maybe it is failing sometimes and launching Windows Explorer as a side effect.
Pierre Bellisle
  • FireFly3 User
  • Junior FireFly Member
« Reply #21 on: August 02, 2017, 11:43:11 PM »
On my side it append every time I press or click F5.
Win7-pro
Explorer in C:\Users\Pierre\Documents
64bit WinFBE
Pierre Bellisle
  • FireFly3 User
« Reply #22 on: August 03, 2017, 01:13:02 AM »
If I REMout RunEXE( gCompile.OutputFilename, gApp.Projects(idx).ProjectCommandLine)
in modCompile.inc, I got no Explorer nor exe running
Something append to gCompile.OutputFilename...
Now all is fine, no more Explorer and program is executed,
problem is I don't know what I did?
I will restart from unzipping the source...
« Last Edit: August 03, 2017, 01:20:11 AM by Pierre Bellisle »
Pierre Bellisle
  • FireFly3 User
« Reply #23 on: August 03, 2017, 01:43:23 AM »
OK, seems that gCompile.OutputFilename is erased somewhere between
If i Then gCompile.OutputFilename = AfxStrRemove(Left(wszTemp, i), wDQ)
and
Just after
Function code_Compile( ByVal wID As Long ) As BOOLEAN
I did add
DIM wOutputFilename AS wSTRING * MAX_PATH
as a backup for gCompile.OutputFilename
After
I did add
IF gCompile.OutputFilename <> "" THEN wOutputFilename = gCompile.OutputFilename
and I did add
gCompile.OutputFilename = wOutputFilename
just before
and all run fine now.
Not a final solution of course, but this should give you a starting point.
Pierre
(See you tomorrow...)
« Last Edit: August 03, 2017, 01:55:27 AM by Pierre Bellisle »
« Reply #24 on: August 03, 2017, 08:17:32 AM »
Thanks Pierre, I am investigating this today.... I have a good idea where the problem may be.
« Reply #25 on: August 03, 2017, 11:16:43 AM »
I have changed the compile code back to the way it was before the last upload. These changes should undo the ill effect that you guys are experiencing. I will re-upload to GitHub in a few hours (I need to recompile the 64 bit version but I am only on 32 bit machine until then).
« Reply #26 on: August 03, 2017, 04:35:14 PM »
New files and binaries uploaded to GitHub.
The release is numbered 1.4.1
Hopefully this fixes that issue of invoking Windows Explorer.
Pierre Bellisle
  • FireFly3 User
« Reply #27 on: August 03, 2017, 05:36:02 PM »
Tested. So far, so good...
« Reply #28 on: August 03, 2017, 05:39:14 PM »
Thanks Pierre, hopefully no more issues. I was pretty confident I knew the reason for the problem so I think I was able to eliminate the issue. Hopefully Jose has similar good results.
    • Jos
« Reply #29 on: August 03, 2017, 06:02:26 PM »
Seems to work fine now.
Pages: 1 [2] 3 4
