This is a port of Borje Hagsten PBVlist to Freebasic. I love this little control for the program simplicity. You attach an array of strings and it is part of a list box. It complies to both 32 and 64 bits and can use dynamic ANSI string or fixed length wide strings. I use this control in my apps all the time. It is in the form of an include file like GRD and EZP. I stayed away from dynamic wide strings here to keep this straight forward. Hopefully it is clear how to switch between ANSI and Unicode.
I plan to expand this control to make a virtual tree control (like I have done in Powerbasic). The windows tree control bogs down after about 10,000 items which is not enough room for me.
The only thing I have left to due (besides the tree control) before rewriting my petroleum app in FreeBasic is to write a wrapper to toggle between Jose's SQlite and ODBC classes. The SQlite is for local databases and the ODBC is for multi-user heavy iron server databases. My hope is that with disciplined queries I can seamlessly toggle which between the two. We will see.
I plan to use Jose's framework for my app. Thank you again Jose.
