Pages: [1] 2 3 ... 15
Author Topic: CWindow Release Candidate 31  (Read 9082 times)
  • Master FireFly Member
    • Josť Roca Software
« on: August 06, 2017, 02:51:36 PM »
Unrar the Afx folder in the "inc" folder of your compiler(s).
On-line help: http://www.jose.it-berater.org/WinFBX/WinFBX.html
GitHub: https://github.com/JoseRoca/WinFBX
Incorporates the changes discussed in the thread of the previous version.
I also have removed the deprecated classes CWstrArray, CWstrDic and CWmiCli. Use instead CSafeArray, CDicObj and CWmiDisp.
9 Aug 2017: Added RemoveStr, ReplaceStr and InStr to the CRegExp class.
14 Aug 2017: Some minor changes and a new class: CPropVar
26 Aug 2017: Added return value to several functions
3 Oct 2017 : Updated with the all changes discussed in this thread
4 Oct 2017 : Updated CVAR and CDispInvoke classes
16 Oct 2017 : Updated with new classes for Time and Ini files
19 Oct 2017 : Modified CDispInvoke
19 Oct 2017 : Removed a couple of suffixes in CPgBar3D.inc
27 Oct 2017 : Fixed a bug in the WebBrowser events; small changes in CWSTR and CVAR.
31 Oct 2017 : Small modification in AfxStr.inc
« Last Edit: November 21, 2017, 08:42:41 PM by Paul Squires »
Re: CWindow Release Candidate 31
« Reply #1 on: August 06, 2017, 03:32:57 PM »
Thanks Jose - I have downloaded and updated the WinFBE source tree with your new files. The changes will be available in the next GitHub upload.
« Reply #2 on: August 09, 2017, 01:40:03 PM »
Added new methods to the CRegExp class: RemoveStr, ReplaceStr and InStr.
They allow to do string manipulation using regular expressions.
' * Returns a copy of a string with text removed using a regular expression as the search string.
' Parameters:
' - cbsSourceString : The source string.
' - cbsPattern : The pattern to search.
' - bIgnoreCase : FALSE = case sensitive; TRUE = case insensitive.
' - bGlobal : FALSE = Delete only the first match; TRUE = delete all matches.
' - bMultiline : TRUE = Match at the start and the end of multiple lines separated by line breaks.
' Examples:
' DIM pRegExp AS CRegExp
' PRINT pRegExp.RemoveStr("abacadabra", "ab") - prints "acadra"
' PRINT pRegExp.RemoveStr("abacadabra", "[bAc]", TRUE) - prints "dr"
PRIVATE FUNCTION CRegExp.RemoveStr (BYREF cbsSourceString AS CBSTR, BYREF cbsPattern AS CBSTR, _
   BYVAL bIgnoreCase AS BOOLEAN = FALSE, BYVAL bGlobal AS BOOLEAN = TRUE, BYVAL bMultiline AS BOOLEAN = FALSE) AS CBSTR
   DIM bstrDestString AS AFX_BSTR
   IF m_pRegExp = NULL THEN this.SetResult(E_POINTER): RETURN bstrDestString
   m_pRegExp->put_IgnoreCase(bIgnoreCase)
   m_pRegExp->put_Global(bGlobal)
   m_pRegExp->put_Multiline(bMultiline)
   m_pRegExp->put_Pattern(cbsPattern)
   this.SetResult(m_pRegExp->Replace(cbsSourceString, CVAR(""), @bstrDestString))
' * Returns a copy of a string with text replaced using a regular expression as the search string.
' Parameters:
' - cvReplaceString : The replacement string.
' Examples:
' PRINT pRegExp.ReplaceStr("Hello World", "World", "Earth") - prints "Hello Earth"
' PRINT pRegExp.ReplaceStr("abacadabra", "[bac]", "*") - prints "*****d**r*"
' PRINT pRegExp.ReplaceStr("555-123-4567", "(\d{3})-(\d{3})-(\d{4})", "($1) $2-$3") - prints "(555) 123-4567"
' PRINT pRegExp.ReplaceStr("Squires, Paul", "(\S+), (\S+)", "$2 $1") - prints "Paul Squires"
' PRINT pRegExp.ReplaceStr("0000.34500044", $"\b0{1,}\.", ".") - prints ".34500044"
PRIVATE FUNCTION CRegExp.ReplaceStr (BYREF cbsSourceString AS CBSTR, BYREF cbsPattern AS CBSTR, BYREF cvReplaceString AS CVAR, _
   this.SetResult(m_pRegExp->Replace(cbsSourceString, cvReplaceString, @bstrDestString))
' Global, multiline in string function with VBScript regular expressions search patterns.
' Parameters:
' - cbsSourceString = The text to be parsed.
' - cbsPattern = The pattern to match.
' - bIgnoreCase = Ignore case.
' Return value:
' - Returns a list of comma separated "index, length" value pairs. The pairs are separated
'   by a semicolon.
' Usage Example:
'   DIM cbsText AS CBSTR = "blah blah a234 blah blah x345 blah blah"
'   DIM cbsPattern AS CBSTR = "[a-z][0-9][0-9][0-9]"
'   DIM cbsOut AS CBSTR
'   cbsOut = pRegExp.InStr(cbsText, cbsPattern)
'   PRINT cbs   - prints 11,4; 26,4
PRIVATE FUNCTION CRegExp.InStr (BYREF cbsSourceString AS CBSTR, BYREF cbsPattern AS CBSTR, _
   BYVAL bIgnoreCase AS BOOLEAN = FALSE, BYVAL bGlobal AS BOOLEAN = TRUE, BYVAL bMultiline AS BOOLEAN = TRUE) AS CBSTR
   IF m_pRegExp = NULL THEN this.SetResult(E_POINTER): RETURN ""
   DIM cbsOut AS CBSTR, pMatches AS Afx_IMatchCollection2 PTR
   this.SetResult(m_pRegExp->Execute(cbsSourceString, cast(Afx_IDispatch PTR PTR, @pMatches)))
   IF pMatches THEN
      DIM nCount AS LONG
      pMatches->get_Count(@nCount)
      FOR i AS LONG = 0 TO nCount - 1
         DIM pMatch AS Afx_IMatch2 PTR
         this.SetResult(pMatches->get_Item(i, cast(Afx_IDispatch PTR PTR, @pMatch)))
         IF pMatch THEN
            DIM nFirstIndex AS LONG
            pMatch->get_FirstIndex(@nFirstIndex)
            DIM nLen AS LONG
            pMatch->get_Length(@nLen)
            IF i < nCount - 1 THEN
               cbsOut += STR(i + 1) & "," & STR(nLen) & ";"
            AfxSafeRelease(pMatch)
      AfxSafeRelease(pMatches)
   RETURN cbsOut
« Last Edit: August 09, 2017, 01:55:40 PM by Josť Roca »
« Reply #3 on: August 12, 2017, 01:09:58 AM »
Layered window template.
2
FBGUI
.bas
CWindow: Layered window
' Microsoft Windows
' File: CW_LayeredWindow.fbtpl
' Contents: CWindow layered window example
' Copyright (c) 2017 Josť Roca. Freeware. Use at your own risk.
#define UNICODE
USING Afx
' // Forward declaration
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Creates the main window
   DIM pWindow AS CWindow
   DIM hwnd AS HWND = pWindow.Create(NULL, "CWindow - Layered window", @WndProc)
   ' // Make the window layered
   AfxAddWindowExStyle(hwnd, WS_EX_LAYERED)
   ' // Make this window 70% alpha
   SetLayeredWindowAttributes(hwnd, 0, (255 * 70) / 100, LWA_ALPHA)
   ' // Centers the window
   pWindow.Center
   ' // Adds a button
   pWindow.AddControl("Button", , IDCANCEL, "&Close", 350, 250, 75, 23)
' Main window procedure
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_SIZE
         ' // Optional resizing code
            ' // Move the position of the button
            IF pWindow THEN pWindow->MoveWindow GetDlgItem(hwnd, IDCANCEL), _
               pWindow->ClientWidth - 120, pWindow->ClientHeight - 50, 75, 23, CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
« Reply #4 on: August 12, 2017, 06:14:50 AM »
Using the WinFBE editor with the UTF-8 (BOM) encoding, and using CWSTR, CBSTR, CVAR or WSTRING as the data types, international users can now work with unicode transparently.
'DIM cws AS CWSTR = "ドミートリイ・ショスタコーヴィチ"   ' Chinese
DIM cws AS CWSTR = "Дми́трий Шостако́вич"   ' Russian
SetWindowTextW hCtl, cws
DIM cbs AS CBSTR = "Дми́трий Шостако́вич"   ' Russian
SetWindowTextW hCtl, cbs
DIM cv AS CVAR = "Дми́трий Шостако́вич"   ' Russian
SetWindowTextW hCtl, cv.wstr
DIM cws2 AS CWSTR = "دمیتری دمیتری‌یویچ شوستاکوویچ"    ' Arab
SetWindowTextW hCtl, cws2
Finally we can use unicode transparently with languages like Chinese, Russian, Arab, etc., even mixed.
All the other past attempts (charsets, code pages) must fall into the oblivion. This one seems to work perfectly and no conversions are needed since the characters are stored in the data types as unicode, not utf8.
Hope our international members will bother to test...
« Last Edit: August 12, 2017, 06:51:59 AM by Josť Roca »
« Reply #5 on: August 12, 2017, 06:56:57 AM »
@Paul,
Maybe changing the file encoding should require confirmation. Too easy to click the status bar by accident and mess the code.
« Reply #6 on: August 12, 2017, 10:01:08 AM »
@Paul,
Hi Jose, instead of an intrusive confirmation messagebox, I'll have a context menu popup allowing to choose between the 3 file types. This will be similar to the way that the panel next to it works when wanting to switch between NORMAL, MODULE, MAIN, etc...
« Reply #7 on: August 12, 2017, 10:12:11 AM »
@Paul,
This is now done and will be in the next update.
« Reply #8 on: August 14, 2017, 08:25:07 AM »
Updated the framework with some minor changes and a new class: CPropVar.
CPropVar implements a new data type, PROPVARIANT, that is needed to use some COM technologies.
I think that we already have all the Windows data types.
« Last Edit: August 14, 2017, 08:26:58 AM by Josť Roca »
« Reply #9 on: August 14, 2017, 04:15:38 PM »
Help file in .chm format.
Johan Klassen
  • Little Newbie FireFly
« Reply #10 on: August 14, 2017, 04:44:57 PM »
thank you Josť Roca for the help file  :)
« Reply #11 on: August 14, 2017, 06:21:56 PM »
Is there anything in PowerBasic that we still can't do using FreeBasic?  (maybe working with, or interfacing to, DLL's is easier in PB)
Jose's library makes it so easy to program Windows in 32 and 64 bit.
« Reply #12 on: August 15, 2017, 12:43:14 AM »
There is not much left. And the alternatives offered by the framework are superior.
I'm going to add this small class:
' CComPtr class
TYPE CComPtr
   m_pUnk AS IUnknown PTR
   DECLARE CONSTRUCTOR (BYVAL pUnk AS ANY PTR, BYVAL fAddRef AS BOOLEAN = FALSE)
   DECLARE DESTRUCTOR
   DECLARE OPERATOR Let (BYVAL pUnk AS ANY PTR)
END TYPE
PRIVATE CONSTRUCTOR CComPtr (BYVAL pUnk AS ANY PTR, BYVAL fAddRef AS BOOLEAN = FALSE)
   m_pUnk = pUnk
   IF fAddRef THEN AfxSafeAddRef(m_pUnk)
END CONSTRUCTOR
PRIVATE DESTRUCTOR CComPtr
   AfxSafeRelease(m_pUnk)
END DESTRUCTOR
PRIVATE OPERATOR CComPtr.Let (BYVAL pUnk AS ANY PTR)
   m_pUnk= pUnk
END OPERATOR
PRIVATE OPERATOR * (BYREF _ccomptr AS CComPtr) AS ANY PTR
   OPERATOR = _ccomptr.m_pUnk
END OPERATOR
When working with COM we can assign COM pointers to instances of this class and we no longer have to worry about releasing them.
« Last Edit: August 15, 2017, 01:11:32 AM by Josť Roca »
James Fuller
  • Senior FireFly Member
« Reply #13 on: August 15, 2017, 06:44:33 AM »
One of the big selling points of PowerBASIC in my opinion is the ease to create COM servers.
James
aloberr
  • FireFly3 User
« Reply #14 on: August 15, 2017, 08:36:42 AM »
COM servers can be easy with the use of the virtual classes, that will be more with the concepts of interface or/and  multiples inheritance that FB do not have yet.
