Pages: 1 ... 13 14 [15]
Author Topic: CWindow Release Candidate 31  (Read 15876 times)
  • Master FireFly Member
    • Jos
Re: CWindow Release Candidate 31
« Reply #210 on: November 14, 2017, 12:24:49 PM »
I have finished the work. ColeCon and CWebBrowser are now history, having been replaced by CAxHost and CWebCtx. I have also have modified the examples and templates.
I think that it is time to leave the release candidate versions and post the first version of the WinFBX framework. WinFBX means Windows FreeBasic Extensions and it has been chosen to highlight its ties with the WinFBE editor. It can be used with other editors, but WinFBE makes its use easier.
« Reply #211 on: November 14, 2017, 04:12:11 PM »
That's great news Jose! Congratulations on making it to Version 1, although with everything that's in this package it feels more like version 10!  :)
ganlinlao
  • FireFly3 User
  • Little Newbie FireFly
« Reply #212 on: November 15, 2017, 12:22:19 AM »
wow , Jose,thank you very much! :)
ganlinlao
  • FireFly3 User
« Reply #213 on: November 19, 2017, 03:16:06 AM »
hi, jose
Error in compiling example mothviews. There is an error in axhost.inc
    • Jos
« Reply #214 on: November 19, 2017, 07:51:05 AM »
In fact it is a bug in the version 1.05 of the compiler. You can download version 1.06 at http://users.freebasic-portal.de/stw/builds/ or change pAxHost->m_bInPlaceActive = FALSE to CLNG(pAxHost->m_bInPlaceActive) = FALSE.
The other error is caused by a change in Put from a function to a property. Use this code:
' Microsoft Windows
' Contents: Embedded MonthView Calendar OCX
#define UNICODE
#INCLUDE ONCE "Afx/CAxHost/CAxHost.inc"
#INCLUDE ONCE "Afx/CDispInvoke.inc"
#INCLUDE ONCE "Afx/AfxCOM.inc"
USING Afx
CONST IDC_MONTHVIEW = 1001
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Creates the main window
   DIM pWindow AS CWindow
   DIM hwndMain AS HWND = pWindow.Create(NULL, "CAxHost - Embedded MonthView Calendar OCX", @WndProc)
   pWindow.SetClientSize(580, 360)
   ' // Centers the window
   pWindow.Center
   DIM wszLibName AS WSTRING * 260 = ExePath & "\MSCOMCT2.OCX"
   DIM CLSID_MSComCtl2_MonthView AS CLSID = (&h232E456A, &h87C3, &h11D1, {&h8B, &hE3,&h00, &h00, &hF8, &h75, &h4D, &hA1})
   DIM IID_MSComCtl2_MonthView AS CLSID = (&h232E4565, &h87C3, &h11D1, {&h8B, &hE3,&h00, &h00, &hF8, &h75, &h4D, &hA1})
   DIM RTLKEY_MSCOMCT2 AS WSTRING * 260 = "651A8940-87C5-11d1-8BE3-0000F8754DA1"
   DIM pHost AS CAxHost = CAxHost(@pWindow, IDC_MONTHVIEW, wszLibName, CLSID_MSComCtl2_MonthView, _
       IID_MSComCtl2_MonthView, RTLKEY_MSCOMCT2, 0, 0, pWindow.ClientWidth, pWindow.ClientHeight)
   DIM hCtl AS HWND = GetDlgItem(pWindow.hWindow, IDC_MONTHVIEW)
'   SetFocus pHost.hWindow
   DIM pdisp AS CDispInvoke = pHost.OcxDispObj
   pdisp.Put("Year") = 1985
   pdisp.Put("Month") = 1
   pdisp.Put("Day") = 21
   ' // Display the window
   ShowWindow(hwndMain, nCmdShow)
   UpdateWindow(hwndMain)
   DIM uMsg AS MSG
   WHILE (GetMessageW(@uMsg, NULL, 0, 0) <> FALSE)
      IF AfxCAxHostForwardMessage(GetFocus, @uMsg) = FALSE THEN
         IF IsDialogMessageW(hwndMain, @uMsg) = 0 THEN
            TranslateMessage(@uMsg)
            DispatchMessageW(@uMsg)
   WEND
   FUNCTION = uMsg.wParam
' Main window procedure
   SELECT CASE uMsg
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
      CASE WM_SIZE
         ' // Optional resizing code
            ' // Move the position of the button
            IF pWindow THEN pWindow->MoveWindow GetDlgItem(hwnd, IDC_MONTHVIEW), _
               0, 0, pWindow->ClientWidth, pWindow->ClientHeight, CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
« Last Edit: November 19, 2017, 08:03:28 AM by Jose Roca »
    • Jos
« Reply #215 on: November 19, 2017, 08:04:34 AM »
If you're going to try the old VB6 OCXs, here is an example for the masked edit control.
' Microsoft Windows
' Contents: Embedded Microsoft Masked Edit Control
' Copyright (c) 2017 Jose Roca. Freeware. Use at your own risk.
#define UNICODE
USING Afx
CONST IDC_MSMASK1 = 1001
CONST IDC_MSMASK2 = 1002
' Main
   DIM hwndMain AS HWND = pWindow.Create(NULL, "Masked Edit Control", @WndProc)
   pWindow.SetClientSize(200, 80)
   pWindow.Center
   DIM wszLibName AS WSTRING * 260 = ExePath & "\MSMASK32.OCX"
   DIM CLSID_MaskEdBox AS CLSID = (&hC932BA85, &h4374, &h101B, {&hA5, &h6C, &h00, &hAA, &h00, &h36, &h68, &hDC})
   DIM IID_IMSMask AS IID = (&h4D6CC9A0, &hDF77, &h11CF, {&h8E, &h74, &h00, &hA0, &hC9, &h0F, &h26, &hF8})
   DIM RTLKEY_MaskEdBox AS WSTRING * 260 = "BC96F860-9928-11cf-8AFA-00AA00C00905"
   DIM pHost AS CAxHost = CAxHost(@pWindow, IDC_MSMASK1, wszLibName, CLSID_MaskEdBox, _
       IID_IMSMask, RTLKEY_MaskEdBox, 10, 10, pWindow.ClientWidth - 20, 22)
   DIM pHost2 AS CAxHost = CAxHost(@pWindow, IDC_MSMASK2, wszLibName, CLSID_MaskEdBox, _
       IID_IMSMask, RTLKEY_MaskEdBox, 10, 45, pWindow.ClientWidth - 20, 22)
   ' Set the fore and back colors
   pdisp.Put("ForeColor") = BGR(0, 0, 255)
   ' Set the mask
   pdisp.Put("Mask") = "(###) - ### - ####"
   DIM pdisp2 AS CDispInvoke = pHost2.OcxDispObj
   pdisp2.Put("ForeColor") = BGR(255, 0, 0)
   pdisp2.Put("BackColor") = BGR(255, 255, 0)
   ' Set the mask
   pdisp2.Put("Mask") = "(###) - ### - ####"
   DIM uMsg AS MSG
   WEND
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_SIZE
            ' // Move the position of the controls
            IF pWindow THEN pWindow->MoveWindow GetDlgItem(hwnd, IDC_MSMASK1), _
               10, 10, pWindow->ClientWidth - 20, 22, CTRUE
            IF pWindow THEN pWindow->MoveWindow GetDlgItem(hwnd, IDC_MSMASK2), _
               10, 45, pWindow->ClientWidth - 20, 22, CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
Please note that these examples are for testing purposes and use the a registration free technique (I don't have any of them registered). If they are registered and licensed, you can use the constructor that accepts a ProgID. As with my previous OLE containers, some will work a some won't. VB6 used the form as an OLE container and implemented interfaces (some not standard) to build complex controls that contain other controls, and even arrays of controls. These are outside the purpose of my modest OLE container. I wanted to use ATL.DLL, but it works very badly.
« Last Edit: November 19, 2017, 08:23:57 AM by Jose Roca »
    • Jos
« Reply #216 on: November 19, 2017, 10:24:58 AM »
CDispInvoke.inc
I have changed Put and PutRef to a properties, but as FreeBasic doesn't accept more than a parameter in properties, I also have added the Set and SetRef functions with up to two index parameters (I think that two are enough; we could add more if needed).
But whereas Put and PutRef will allow this syntax:
pdisp.Put ("property name") = value
being a function, with Set and SetRef you will have to use
pdisp.Set ("property name", index[es], value)
« Last Edit: November 19, 2017, 10:54:33 AM by Jose Roca »
    • Jos
« Reply #217 on: November 19, 2017, 01:02:09 PM »
I have added another overloaded PutRef property. Only when testing you find the convenience of additions to ease its use.
PRIVATE PROPERTY CDispInvoke.PutRef (BYVAL dispID AS DISPID, BYVAL pv AS ANY PTR)
   CDISPINVOKE_DP("CDISPINVOKE DispInvoke.PutRef - DISPID - ANY PTR")
   DIM cvArg AS CVAR = CVAR(CAST(IUnknown PTR, pv), TRUE)
   SetResult(this.DispInvoke(DISPATCH_PROPERTYPUTREF, dispID, cvArg, 1, m_lcid))
END PROPERTY
PRIVATE PROPERTY CDispInvoke.PutRef (BYVAL pwszName AS WSTRING PTR, BYVAL pv AS ANY PTR)
   CDISPINVOKE_DP("CDISPINVOKE DispInvoke.PutRef - Name - ANY PTR")
   SetResult(this.DispInvoke(DISPATCH_PROPERTYPUTREF, pwszName, cvArg, 1, m_lcid))
END PROPERTY
Preparing the test for the Microsoft Hierarchical Control (see below) I needed it to set a pointer to the data source.
« Last Edit: November 19, 2017, 01:49:18 PM by Jose Roca »
    • Jos
« Reply #218 on: November 19, 2017, 01:08:23 PM »
Two of the Microsoft grid controls, the Flex Grid and the Hierarchical Flex Grid work well with my OLE container, and because they use twips, they're DPI aware. It is a pity that they are only 32 bit. Maybe I will write classes to ease its use and add events.
Test for the Microsoft Hierarchical Grid Control:
' Microsoft Windows
' Contents: Embedded Microsoft Hierarchical Grid Control
#define UNICODE
#INCLUDE ONCE "Afx/CADODB/CADODB.inc"
USING Afx
CONST IDC_GRID = 1001
' Main
   DIM hwndMain AS HWND = pWindow.Create(NULL, "Microsoft Hierarchical Flex Grid", @WndProc)
   pWindow.SetClientSize(800, 450)
   pWindow.Center
   DIM wszLibName AS WSTRING * 260 = ExePath & "\MSHFLXGD.OCX"
   DIM CLSID_MSHFlexGrid AS CLSID = (&h0ECD9B64, &h23AA, &h11D0, {&hB3, &h51, &h00, &hA0, &hC9, &h05, &h5D, &h8E})
   DIM IID_IMSHFlexGrid AS IID = (&h0ECD9B62, &h23AA, &h11D0, {&hB3, &h51, &h00, &hA0, &hC9, &h05, &h5D, &h8E})
   DIM RTLKEY_MSHFlexGrid AS WSTRING * 260 = "1F3D5522-3F42-11d1-B2FA-00A0C908FB55"
   DIM pHost AS CAxHost = CAxHost(@pWindow, IDC_GRID, wszLibName, CLSID_MSHFlexGrid, _
       IID_IMSHFlexGrid, RTLKEY_MSHFlexGrid, 0, 0, pWindow.ClientWidth, pWindow.ClientHeight)
   DIM pGrid AS CDispInvoke = pHost.OcxDispObj
   ' Change the width of the columns (measures are in twips)
   ' The first parameter is the grid's pointer reference,
   ' the second the column index, and the third the col width.
   pGrid.Set("ColWidth", 0, 0, 300)
   pGrid.Set("ColWidth", 1, 0, 1100)
   pGrid.Set("ColWidth", 2, 0, 3000)
   pGrid.Set("ColWidth", 3, 0, 2000)
   pGrid.Set("ColWidth", 4, 0, 2000)
   pGrid.Set("ColWidth", 5, 0, 3000)
   pGrid.Set("ColWidth", 6, 0, 1500)
   pGrid.Set("ColWidth", 7, 0, 700)
   pGrid.Set("ColWidth", 8, 0, 1200)
   pGrid.Set("ColWidth", 9, 0, 1200)
   pGrid.Set("ColWidth", 10, 0, 1500)
   pGrid.Set("ColWidth", 11, 0, 1500)
   ' Change the foreground and background colors
   pGrid.Put("ForeColor") = BGR(0, 0, 0)
   pGrid.Put("BackColor") = BGR(255,255,235)
   ' Open an ADO connection
   DIM pConnection AS CAdoConnection PTR = NEW CAdoConnection
   pConnection->ConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & ExePath & $"\nwind.mdb"
   pConnection->Open
   ' Open a recordset
   DIM pRecordset AS CAdoRecordset PTR = NEW CAdoRecordset
   DIM cvSource AS CVAR = "SELECT * FROM Customers"
   pRecordset->Open(cvSource, pConnection, adOpenKeyset, adLockOptimistic, adCmdText)
   ' Set the Datasource property of the recordset
   pGrid.PutRef("DataSource") = pRecordset->DataSource
   ' Close the recordset
   pRecordset->Close
   ' Close the connection
   pConnection->Close
   ' // Delete the recordset
   Delete pRecordset
   ' // Delete the connection
   Delete pConnection
   DIM uMsg AS MSG
   WEND
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_SIZE
            IF pWindow THEN pWindow->MoveWindow GetDlgItem(hwnd, IDC_GRID), _
    CASE WM_DESTROY
         PostQuitMessage(0)
« Last Edit: November 19, 2017, 02:51:50 PM by Jose Roca »
    • Jos
« Reply #219 on: November 19, 2017, 01:50:13 PM »
Test for the Microsoft Flex Grid Control:
' Microsoft Windows
' Contents: Embedded Microsoft Flex Grid Control
#define UNICODE
USING Afx
' Main
   DIM hwndMain AS HWND = pWindow.Create(NULL, "Microsoft Flex Grid", @WndProc)
   pWindow.Center
   DIM wszLibName AS WSTRING * 260 = ExePath & "\Msflxgrd.ocx"
   DIM CLSID_MSFlexGrid AS CLSID = (&h6262D3A0, &h531B, &h11CF, {&h91, &hF6, &hC2, &h86, &h3C, &h38, &h5E, &h30})
   DIM IID_IMSFlexGrid AS IID = (&h5F4DF280, &h531B, &h11CF, {&h91, &hF6, &hC2, &h86, &h3C, &h38, &h5E, &h30})
   DIM RTLKEY_MSFlexGrid AS WSTRING * 260 = "72E67120-5959-11cf-91F6-C2863C385E30"
   DIM pHost AS CAxHost = CAxHost(@pWindow, IDC_GRID, wszLibName, CLSID_MSFlexGrid, _
       IID_IMSFlexGrid, RTLKEY_MSFlexGrid, 0, 0, pWindow.ClientWidth, pWindow.ClientHeight)
   pConnection->Open
   ' Open a recordset
   ' Move to the last record
   pRecordset->MoveLast
   ' Set the number of grid rows and columns
   pGrid.Put("Rows") = pRecordset->RecordCount + 1
   pGrid.Put("Cols") = 12
   ' Set the headers
   pGrid.Set("TextMatrix", 0,  1, "Customer ID")
   pGrid.Set("TextMatrix", 0,  2, "Company Name")
   pGrid.Set("TextMatrix", 0,  3, "Contact Name")
   pGrid.Set("TextMatrix", 0,  4, "Contact Title")
   pGrid.Set("TextMatrix", 0,  5, "Address")
   pGrid.Set("TextMatrix", 0,  6, "City")
   pGrid.Set("TextMatrix", 0,  7, "Region")
   pGrid.Set("TextMatrix", 0,  8, "Postal Code")
   pGrid.Set("TextMatrix", 0,  9, "Country")
   pGrid.Set("TextMatrix", 0,  10, "Phone")
   pGrid.Set("TextMatrix", 0,  11, "Fax")
   pGrid.Set("ColWidth", 0, 300)
   pGrid.Set("ColWidth", 1, 1100)
   pGrid.Set("ColWidth", 2, 3000)
   pGrid.Set("ColWidth", 3, 2000)
   pGrid.Set("ColWidth", 4, 2000)
   pGrid.Set("ColWidth", 5, 3000)
   pGrid.Set("ColWidth", 6, 1500)
   pGrid.Set("ColWidth", 7, 700)
   pGrid.Set("ColWidth", 8, 1200)
   pGrid.Set("ColWidth", 9, 1200)
   pGrid.Set("ColWidth", 10, 1500)
   pGrid.Set("ColWidth", 11, 1500)
   ' Allow to resize columns
   pGrid.Put("AllowUserResizing") = 1   ' flexResizeColumns
   ' Move to the first record
   pRecordset->MoveFirst
   ' Parse the recordset and fill the grid
   DIM row AS LONG = 1
   WHILE NOT pRecordset->EOF
      'Select the row
      pGrid.Put("Row") = row
      ' Set the content of cell 1
      pGrid.Put("Col") = 1
      pGrid.Put("CellAlignment") = 1   ' flexAlignLeftCenter
      pGrid.Put("Text") = pRecordset->Collect("CustomerID")
      ' Set the content of cell 2
      pGrid.Put("Col") = 2
      pGrid.Put("Text") = pRecordset->Collect("CompanyName")
      ' Set the content of cell 3
      pGrid.Put("Col") = 3
      pGrid.Put("Text") = pRecordset->Collect("ContactName")
      ' Set the content of cell 4
      pGrid.Put("Col") = 4
      pGrid.Put("Text") = pRecordset->Collect("ContactTitle")
      ' Set the content of cell 5
      pGrid.Put("Col") = 5
      pGrid.Put("Text") = pRecordset->Collect("Address")
      ' Set the content of cell 6
      pGrid.Put("Col") = 6
      pGrid.Put("Text") = pRecordset->Collect("City")
      ' Set the content of cell 7
      pGrid.Put("Col") = 7
      pGrid.Put("Text") = pRecordset->Collect("Region")
      ' Set the content of cell 8
      pGrid.Put("Col") = 8
      pGrid.Put("Text") = pRecordset->Collect("PostalCode")
      ' Set the content of cell 9
      pGrid.Put("Col") = 9
      pGrid.Put("Text") = pRecordset->Collect("Country")
      ' Set the content of cell 10
      pGrid.Put("Col") = 10
      pGrid.Put("Text") = pRecordset->Collect("Phone")
      ' Set the content of cell 11
      pGrid.Put("Col") = 11
      pGrid.Put("Text") = pRecordset->Collect("Fax")
      ' Fetch the next row
      pRecordset->MoveNext
      ' Increment the counter
      row += 1
   WEND
   ' Select the first cell
   pGrid.Put("Row") = 1
   pRecordset->Close
   pConnection->Close
   Delete pRecordset
   Delete pConnection
   DIM uMsg AS MSG
   WEND
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_SIZE
    CASE WM_DESTROY
         PostQuitMessage(0)
I thik that CDispInvoke has become easier to use than DispHelper, and without having to use a third party C++ DLL.
« Last Edit: November 19, 2017, 01:57:37 PM by Jose Roca »
    • Jos
« Reply #220 on: November 19, 2017, 05:14:02 PM »
Test for the Microsoft DataList Control
' Microsoft Windows
' Contents: Microsoft Data List Control
#define UNICODE
USING Afx
CONST IDC_DATALIST = 1001
' Main
   DIM hwndMain AS HWND = pWindow.Create(NULL, "Microsoft Data List Control", @WndProc)
   pWindow.SetClientSize(300, 350)
   pWindow.Center
   DIM wszLibName AS WSTRING * 260 = ExePath & "\MSDATLST.OCX"
   DIM CLSID_DataList AS CLSID = (&hF0D2F219, &hCCB0, &h11D0, {&hA3, &h16, &h00, &hAA, &h00, &h68, &h8B, &h10})
   DIM IID_IDataList AS IID = (&hF0D2F217, &hCCB0, &h11D0, {&hA3, &h16, &h00, &hAA, &h00, &h68, &h8B, &h10})
   DIM RTLKEY_DATALIST AS WSTRING * 260 = "A133F000-CCB0-11d0-A316-00AA00688B10"
   DIM pHost AS CAxHost = CAxHost(@pWindow, IDC_DATALIST, wszLibName, CLSID_DataList, _
       IID_IDataList, RTLKEY_DATALIST, 0, 0, pWindow.ClientWidth, pWindow.ClientHeight)
   ' Get a reference to the DataList object
   DIM pDataList AS CDispInvoke = pHost.OcxDispObj
   pDataList.Put("ForeColor") = BGR(0, 0, 0)
   pDataList.Put("BackColor") = BGR(255,255,235)
   pConnection->ConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & ExePath & $"\Biblio.mdb"
   pConnection->Open
   ' Open a recordset
   DIM cvSource AS CVAR = "SELECT * FROM Publishers ORDER BY Name"
   ' Set the recordset to the control
   pDataList.PutRef("RowSource") = pRecordset->DataSource
   pDataList.Put("ListField") = "Name"
   DIM uMsg AS MSG
   WEND
   pRecordset->Close
   pConnection->Close
   Delete pRecordset
   Delete pConnection
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_SIZE
            IF pWindow THEN pWindow->MoveWindow GetDlgItem(hwnd, IDC_DATALIST), _
    CASE WM_DESTROY
         PostQuitMessage(0)
    • Jos
« Reply #221 on: November 19, 2017, 05:26:09 PM »
Test for the Microsoft Data Combo Control
' Microsoft Windows
' Contents: Microsoft Data Combo Control
#define UNICODE
USING Afx
CONST IDC_DATACOMBO = 1001
' Main
   DIM hwndMain AS HWND = pWindow.Create(NULL, "Microsoft Data Combo Control", @WndProc)
   pWindow.SetClientSize(300, 200)
   pWindow.Center
   DIM CLSID_DataCombo AS CLSID = (&hF0D2F21C, &hCCB0, &h11D0, {&hA3, &h16, &h00, &hAA, &h00, &h68, &h8B, &h10})
   DIM IID_IDataCombo AS IID = (&hF0D2F21A, &hCCB0, &h11D0, {&hA3, &h16, &h00, &hAA, &h00, &h68, &h8B, &h10})
   DIM RTLKEY_DATACOMBO AS WSTRING * 260 = "A133F000-CCB0-11d0-A316-00AA00688B10"
   DIM pHost AS CAxHost = CAxHost(@pWindow, IDC_DATACOMBO, wszLibName, CLSID_DataCombo, _
       IID_IDataCombo, RTLKEY_DATACOMBO, 0, 0, pWindow.ClientWidth, pWindow.ClientHeight)
   pConnection->Open
   ' Open a recordset
   DIM uMsg AS MSG
   WEND
   pRecordset->Close
   pConnection->Close
   Delete pRecordset
   Delete pConnection
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_SIZE
            IF pWindow THEN pWindow->MoveWindow GetDlgItem(hwnd, IDC_DATACOMBO), _
    CASE WM_DESTROY
         PostQuitMessage(0)
ganlinlao
  • FireFly3 User
« Reply #222 on: November 20, 2017, 04:03:52 AM »
hi,jose
I downloaded and used the fbc1.0.6 compiler and downloaded your latest idispinvoke.inc.
Using the latest example code from above. In the mothview example, there is still an error.
Code:
   pdisp.Put ("Year", 2017)
   pdisp.Put ("Month", 12)
   pdisp.Put ("Day", 25)
Will show the same type of mismatch error.
 pdisp.Put ("Year", cVar (2017))
This will not be a problem.
I really like idispatch.put ("") = value like this style, thank you very much. I am very  looking forward to your ways to provide easier-to-handle "events".
    • Jos
« Reply #223 on: November 20, 2017, 11:29:48 AM »
Works fine here. Maybe you're using an outdated CVAR.inc.
