Pages: 1 [2]
Author Topic: WinFBE 1.4.4 on GitHub (August 18, 2017)  (Read 1328 times)
  • Master FireFly Member
Re: WinFBE 1.4.4 on GitHub (August 18, 2017)
« Reply #15 on: August 18, 2017, 10:08:17 PM »
Yes, maybe I should switch over to the XPButton. Here are the things that I would need it to do:
- Be flat with no edges (or gradient)
- Allow me to draw a blue box around the edges to indicate a selected state (eg. the Match Case button).
- Allow hot tracking so when the mouse is over the button then the background color will change.
- Allow tooltips of course.
Also, a button control may look out of place in this situation because the pressing animation when the button is pressed down may not look right. Not sure.
« Last Edit: August 18, 2017, 10:12:22 PM by TechSupport »
« Reply #16 on: August 18, 2017, 10:13:22 PM »
Maybe I just need to steal the drawing code from the xp button to see if I am doing anything wrong that could help the sharpness of the image.
    • Jos
« Reply #17 on: August 18, 2017, 10:41:37 PM »
This can be achieved using the BS_FLAT style and disabling theming:
DIM pXpButton1 AS CXpButton = CXpButton(@pWindow, IDC_BUTTON1, "", 50, 20, 26, 26, _
       WS_VISIBLE OR WS_TABSTOP OR BS_PUSHBUTTON OR BS_CENTER OR BS_VCENTER OR BS_FLAT)
pXpButton1.DisableTheming
You can set an hot image and the control will do hot tracking.
No problem.
This will require some changes in the drawing code. Maybe setting a new flag.
    • Jos
« Reply #18 on: August 18, 2017, 11:03:22 PM »
Anyway, although the replace icon looks sharp, the case.ico does not, but this is because the original icon image is very poor.
    • Jos
« Reply #19 on: August 18, 2017, 11:18:50 PM »
The attached icons must look better.
    • Jos
« Reply #20 on: August 19, 2017, 02:38:49 AM »
See if changing
   ' Combobox to switch amongst the different build options
   ' Get the last button's rect and position the combobox immediately the right
'   HWND_FRMMAIN_COMBOBUILDS = _
'   pWindow->AddControl("COMBOBOX", hToolBar, IDC_FRMMAIN_COMBOBUILDS, "", _
'        pWindow->UnScaleX(rc.right) + 10, iif(pWindow->DPI = 96, 8, 2), 200, 20, _
'        WS_CHILD OR WS_VISIBLE OR WS_VSCROLL OR WS_BORDER OR WS_TABSTOP OR CBS_DROPDOWNLIST OR CBS_HASSTRINGS, _
'        WS_EX_LEFT Or WS_EX_LTRREADING Or WS_EX_RIGHTSCROLLBAR)
        pWindow->UnScaleX(rc.right + 10), pWindow->UnScaleX(10), 200, 20, _
looks right at 96 DPI.
iif(pWindow->DPI = 96, 8, 2) is not correct because the value must be the same. What happens is that you must be trying it simulating 144 DPI with pWindow->DPI = 144, but that trick is not perfect because the window caption and the menu aren't scaled.
« Last Edit: August 19, 2017, 02:42:18 AM by Jose Roca »
« Reply #21 on: August 19, 2017, 10:30:54 AM »
Thanks Jose, I made the change but I have used 8 instead of 10 because it seems to centre better in the toolbar. I also corrected a scaling error with the toolbar itself. I was using parenthesis around the scaling ratio calculation.
   Dim cx As Long = 24 * (pWindow->DPI \ 96)
To:
   Dim cx As Long = 24 * pWindow->DPI \ 96
        pWindow->UnScaleX(rc.right + 10), pWindow->UnScaleY(8), 200, 20, _
I have uploaded the new EXE's to GitHub.
« Reply #22 on: August 22, 2017, 04:21:34 PM »
Working on the visual designer portion of WinFBE now.
Richard Kelly
  • Senior FireFly Member
« Reply #23 on: August 22, 2017, 07:58:07 PM »
I have small project in mind to test the designer out.
Rick
« Reply #24 on: August 22, 2017, 08:01:02 PM »
...does it involve SQLite :)
« Last Edit: August 22, 2017, 08:56:39 PM by TechSupport »
Richard Kelly
« Reply #25 on: August 23, 2017, 08:55:58 AM »
SQLite will be part of two efforts. One is to put a GUI on my calendaring class.
Rick
Pages: 1 [2]
