Author Topic: WinFBE 1.4.9 on GitHub (August 31, 2017)  (Read 1087 times)
  • Master Member
« on: August 31, 2017, 06:16:45 PM »
Version 1.4.9 (August 31, 2017)
- Changed: If "Allow multiple instances" is unchecked, then subsequent file opens will open in the current active editor instance.
- Changed: Filters for "Save As", "Save Declares File", "Open', "Insert File" and "Select Compiler".
- Fixed: Explorer Treeview filenames immediately resorted when filename changed (new file or save as).
  • Master Member
    • Jos
Re: WinFBE 1.4.9 on GitHub (August 31, 2017)
« Reply #1 on: August 31, 2017, 07:01:52 PM »
Excellent, but looks like you have forget to remove a message box that appears before the file is loaded.
  • Master Member
« Reply #2 on: August 31, 2017, 07:08:34 PM »
Shoot! Arrrgh! Yes that was a debug. I will remove it and re-upload.
  • Master Member
    • Jos
« Reply #3 on: August 31, 2017, 07:13:28 PM »
You have also ignored the part of my code that deals with the line number. It is important when using a file search utility to not only load the file but also to display the line in which the searched text has been found and position the cursor on it.
  • Master Member
« Reply #4 on: August 31, 2017, 07:14:02 PM »
Uploaded 1.4.9.1 as an update (I kept the About dialog version as 1.4.9)
  • Master Member
« Reply #5 on: August 31, 2017, 07:18:10 PM »
Yes, that was on purpose because I have not decided yet how I want to parse that from the command line. Currently, the command line is iterated for multiple filenames or projects. I need to determine how to differentiate between filenames and line numbers, etc.  The command line is not as simple as a filename followed by a line number.
