Author Topic: WinFBE 1.5.0 on GitHub (September 3, 2017)  (Read 440 times)
  • Master FireFly Member
« on: September 03, 2017, 03:24:01 PM »
Version 1.5.0 (September 3, 2017)
- Added: Theme support. Create user defined color themes.
- Added: Default Theme and Visual Studio Code (Dark) theme.
- Added: "User selected" option when choosing colors allows user to select any color rather than just the predefined ones.
- Added: Environment option to show/hide main window Toolbar and Statusbar.
- Fixed: Screen artifacts on code window when Explorer resized.
(Note: You will lose any color settings that you have defined in previous versions of WinFBE. WinFBE now uses a theme system so you will have to create your own theme and define and save your custom color settings there).
    • Jos
Re: WinFBE 1.5.0 on GitHub (September 3, 2017)
« Reply #1 on: September 03, 2017, 03:40:58 PM »
There is a problem with the designer. If I make the form bigger than the visible area of the editor and then I scroll it, the bottom isn't displayed.
    • Jos
« Reply #2 on: September 03, 2017, 04:03:38 PM »
New Spanish language file.
« Reply #3 on: September 03, 2017, 04:09:51 PM »
Hi Jose, thanks for the language file. I am re-uploading to 1.5.1. The visual designer code was not supposed to be included in the 1.5.0 release.  :)
« Reply #4 on: September 03, 2017, 04:13:14 PM »
Version 1.5.1 (September 3, 2017)
- Fixed: Accidentally included unfinished visual designer code in v1.5.0 release.
