Author Topic: WinFBE 1.5.3 on GitHub (September 6, 2017)  (Read 644 times)
  • Master FireFly Member
« on: September 06, 2017, 06:55:19 PM »
Version 1.5.3 (September 6, 2017)
- Added: compiler set new field added for WinFBX library path.
- Changed: Modified some AfxStrRemove code when "&" character is removed would interfere with Chinese localization.
- Changed: Editor option "Confine caret to text" is now checked by default.
- Changed: Removed DShow_PlayClip example project due to potential include file conflicts.
    • Jos
Re: WinFBE 1.5.3 on GitHub (September 6, 2017)
« Reply #1 on: September 24, 2017, 07:52:18 PM »
A little suggestion: To display the total number of lines in the status bar, i.e. Ln xxx of xxxxx, Col xx.
