Author Topic: WinFBE 1.5.5 on GitHub (September 27, 2017)  (Read 1056 times)
  • Master FireFly Member
« on: September 27, 2017, 07:22:26 PM »
Version 1.5.5 (September 27, 2017)
- Changed: Updated deutsch.lang language file thanks to Joerg Buckel.
- Changed: Instances of IFF&() changed to IFF() and SPACE$() to SPACE()to allow compiling with FBC 1.06.
- Changed: WinFBE32.exe and WinFBE64.exe now compiled using FBC 1.06.
- Fixed: Error in #Define in modSciLexer.bi.
exjoburgr
  • FireFly3 User
  • Little Newbie FireFly
Re: WinFBE 1.5.5 on GitHub (September 27, 2017)
« Reply #1 on: October 19, 2017, 12:57:29 PM »
Thanks for the great Open source FB editor.
Quick question - the release notes mention FBC 1.06 - where can I get FreeBASIC 1.06?
I only see 1.05 on freebasic.net and the FB forums at freebasic.net/forum/
Sorry for only asking this now, I've been away for a few weeks.
    • Jos
James Fuller
  • Senior FireFly Member
« Reply #3 on: October 20, 2017, 06:58:38 AM »
Here: http://users.freebasic-portal.de/stw/builds/
Jose,
  How did you incorporate the 1.06 build with the 1.05 download?
Did you just use the fb.exe or ...?
James
Steven Hua
« Reply #4 on: October 20, 2017, 08:06:09 AM »
In https://sourceforge.net/projects/mingw-w64 released in August version 7.2 is a virus, do not know http://users.freebasic-portal.de compiler fbc whether to use this virus version , Because it detects a virus, see the test report.
http://users.freebasic-portal.de/stw/builds/win32/fbc_win32_mingw_0482_2017-10-19.zip This version may use the mingw-w64 7.2 version to compile it, August released mingw-w64 version 7.2 There is a virus.
recommend manually compile the FBC 1.06.0 version, using the MINGW-W64 version of 7.1 or Mingw-w64 6.4 or other older versions, compile with Msys or MSYS2, which is easy to compile.
fbc_win32_mingw_0482_2017-10-19. Zip lib library file is incomplete.
up: https://sourceforge.net/projects/mingw-w64  October 18 update,recompiled version 7.2
Good luck!
« Last Edit: October 20, 2017, 05:01:11 PM by Steven Hua »
    • Jos
« Reply #5 on: October 20, 2017, 11:56:42 AM »
Jose,
James
As you like it. The main changes are in the compiler. There may be also a few changes in the include files.
