Pages: 1 [2] 3 4
Author Topic: WinFBX Version 1.0  (Read 4900 times)
ganlinlao
  • FireFly3 User
  • Little Newbie FireFly
Re: WinFBX Version 1.0
« Reply #15 on: December 08, 2017, 09:50:33 PM »
hi ,jose
I found the UIribbon.inc class in your winapi for powerbasic package and wondered if you plan to provide a freebasic version of the cUIribbon class.
Because from windows vista, win7-win10, the system has brought uiRibbon.dll, for some do not want to use the old menu and want to use ribbon style, the use of cUIribbon class, will bring a lot of convenience.
  Thanks!
ganlinlao
  • FireFly3 User
« Reply #16 on: December 08, 2017, 10:06:34 PM »
hi,jose
I found that there is a mistake here
  • Master FireFly Member
    • Jos
« Reply #17 on: December 09, 2017, 06:44:47 AM »
The FreeBasic GDI+ headers are a total mess. The ColorPalette structure is defined twice
In gdiplus-c.bi as:
type ColorPalette
Flags as UINT
Count as UINT
Entries(0 to 0) as ARGB
end type
and in GdiplusPixelFormats.bi as
type ColorPalette
Flags as UINT
Count as UINT
Entries(0 to 1-1) as ARGB
end type
Entries(0 to 0) as ARGB and Entries(0 to 1-1) as ARGB are the same. Anyway, I will change it to Entries(0 to 0).
    • Jos
« Reply #18 on: December 09, 2017, 07:01:50 AM »
hi ,jose
  Thanks!
I will see. Because FB doesn't have support for COM classes, with more than one implemented interface, it will be a bit more difficult. However, if I haven't done it yet it is because, although many people would like to use ribbons, the interest disappears suddenly when they realize that have to learn XAML, install a XAML compiler, etc. Absolutely nobody used it with PowerBasic.
    • Jos
« Reply #19 on: December 09, 2017, 07:27:55 AM »
Another problem is that the ribbon api uses propvariants, and although I have done some work with the CPropVar class, it have not yet thoroughly tested it. Also FB does not provide headers and libraries for the UI interfaces and propvariants.
ganlinlao
  • FireFly3 User
« Reply #20 on: December 10, 2017, 07:37:06 AM »
hi,jose
I found that there is a mistake here.
rect and rectF
    • Jos
« Reply #21 on: December 10, 2017, 09:30:47 AM »
Changed to
width
Specifies the width of a rectangle.
height
Specifies the height of a rectangle.
Also changed SIZEF to SIZE in the entry for the SIZE structure.
BTW please note that because it is declared as Rect_ in gdiplus-c.bi (to avoid conflicting with GDI's Rect) and as class in GdiPlusTypes.bi, in my headers I'm using the functions GDIP_RECT, GDIP_RECTF, GDIP_POINT, GDIP_POINTF. Otherwise, there is no way to compile the same code to 32 and 64 bit. The FB headers for GDI+ need a complete rewrite.
Thinking about it, I'm going to use the aliases in the documentation, i.e. GpPoint, GpPointF, GpRect, GpRectF, GpSize and GpSizeF.
    • Jos
« Reply #22 on: December 11, 2017, 10:00:58 AM »
I'm going to add this method to the CWSTR class.
' Resizes the string to a length of n characters.
' Parameters:
' nSize : New string length, expressed in number of characters.
' ch: Character used to fill the new character space added to the string (in case the
' string is expanded).
' If nSize is smaller than the current string length, the current value is shortened to
' its first nSize characters.
' If nSize is greater than the current string length, the current content is extended by
' inserting at the end as many characters as needed to reach a size of nSize. If ch is
' specified, the new elements are initialized as copies of ch, otherwise, spaces are added.
PRIVATE SUB CWstr.Resize (BYVAL nSize AS UINT, BYREF ch AS WSTRING = "")
   CWSTR_DP("CWSTR Resize")
   IF m_BufferLen \ 2 = nSize THEN EXIT SUB
   IF m_BufferLen \ 2 > nSize THEN
      m_BufferLen = nSize * 2
      m_Capacity = nSize * 2
      m_pBuffer[m_BufferLen] = 0
      m_pBuffer[m_BufferLen + 1] = 0
      DIM cws AS CWSTR
      DIM nChars AS UINT = ((nSize * 2) - m_BufferLen) \ 2
      IF ch <> "" THEN cws = STRING(nChars, ASC(ch, 1)) ELSE cws = SPACE(nChars)
      this.Add(cws)
ganlinlao
  • FireFly3 User
« Reply #23 on: December 14, 2017, 09:02:04 PM »
hi,jose
Thank you, this method is very good, my friend and I a few days ago, just talked about the string and custom structure types of memory self-growth and cleaning problems.
« Last Edit: December 14, 2017, 09:10:04 PM by ganlinlao »
    • Jos
« Reply #24 on: December 15, 2017, 05:02:31 AM »
Thank you. I have modified the text to
Returns a GpPoint color value initialized with the specified values for the x and y coordinates.
Returns a GpPointF color value initialized with the specified values for the x and y coordinates.
and also the return types from GpRect/F to GpPoint/F.
    • Jos
« Reply #25 on: December 15, 2017, 05:05:28 AM »
Regarding the Resize method, I have changed it to
' Parameters:
      IF LEN(ch) > 1 THEN ch = LEFT(ch, 1)
      DIM cws AS CWSTR = SPACE(nChars)
      IF ch <> "" THEN
         FOR i AS LONG = 1 TO nChars
            MID(**cws, i, 1) = ch
      this.Add(cws)
Because the FreeBasic STRING function does not work with Unicode.
Will have to also modify other functions that use STRING. Fortunately they're only three: AfxStrLset, AfxStrRSet and AfxStrCSet.
« Last Edit: December 15, 2017, 05:16:45 AM by Jose Roca »
    • Jos
« Reply #26 on: December 15, 2017, 05:31:54 AM »
Done. Changed these functions to:
' Returns a string containing a left-justified (padded) string.
' If the optional parameter wszPadCharacter not specified, the function pads the string with
' space characters to the left. Otherwise, the function pads the string with the first
' character of wszPadCharacter
' Example: DIM cws AS CWSTR = AfxStrLSet("FreeBasic", 20, "*")
PRIVATE FUNCTION AfxStrLSet (BYREF wszMainStr AS WSTRING, BYVAL nStringLength AS LONG, BYREF wszPadCharacter AS WSTRING = " ") AS CWSTR
   IF LEN(wszPadCharacter) > 1 THEN wszPadCharacter = LEFT(wszPadCharacter, 1)
   DIM cws AS CWSTR = SPACE(nStringLength)
   IF wszPadCharacter <> "" THEN
      FOR i AS LONG = 1 TO LEN(cws)
         MID(**cws, i, 1) = wszPadCharacter
   MID(**cws, 1, LEN(wszMainStr)) = wszMainStr
   RETURN cws
' Returns a string containing a right-justified (padded) string.
' character of wszPadCharacter.
' Example: DIM cws AS CWSTR = AfxStrRSet("FreeBasic", 20, "*")
PRIVATE FUNCTION AfxStrRSet (BYREF wszMainStr AS WSTRING, BYVAL nStringLength AS LONG, BYREF wszPadCharacter AS WSTRING = " ") AS CWSTR
   MID(**cws, nStringLength - LEN(wszMainStr) + 1, LEN(wszMainStr)) = wszMainStr
   RETURN cws
' Returns a string containing a centered (padded) string.
' Example: DIM cws AS CWSTR = AfxStrCSet("FreeBasic", 20, "*")
PRIVATE FUNCTION AfxStrCSet (BYREF wszMainStr AS WSTRING, BYVAL nStringLength AS LONG, BYREF wszPadCharacter AS WSTRING = " ") AS CWSTR
   MID(**cws, (nStringLength - LEN(wszMainStr)) \ 2 + 1, LEN(wszMainStr)) = wszMainStr
   RETURN cws
« Reply #27 on: December 15, 2017, 09:11:04 AM »
Hi Jose,
Just looking at the new LSet function. Seems like it can be simplified a bit because the PadCharacter will always be at least 1 character (the default if no parameter is passed is a blank character).
   RETURN cws
Agree?
    • Jos
« Reply #28 on: December 15, 2017, 09:16:13 AM »
Yes. I forgot that the default was " " instead of "".
   RETURN cws
   RETURN cws
   RETURN cws
« Last Edit: December 15, 2017, 09:32:43 AM by Jose Roca »
    • Jos
« Reply #29 on: December 19, 2017, 10:25:03 AM »
After a discussion in the PowerBasic forum, I have written the following functions to get the handle of the top level window of a web browser. I will incorporate them in AfxWin.inc
' Retrieves the handle of the top level window of the web browser.
' Parameter:
'    pwszClassName: The browser class name.
' Return value:
'    The handle of the top level window of the browser.
' Thanks to Dominic Mitchell for the information provided in this thread:
' https://forum.powerbasic.com/forum/user-to-user-discussions/powerbasic-for-windows/767812-handle-to-browser-window?p=767896#post767896
' Examples:
' DIM hwndBrowser AS HWND = AfxGetBrowserHandle("IEFrame")              ' // Internet Explorer
' DIM hwndBrowser AS HWND = AfxGetBrowserHandle("MozillaWindowClass")   ' // Firefox
' DIM hwndBrowser AS HWND = AfxGetBrowserHandle("Chrome_WidgetWin_1")   ' // Chrome
FUNCTION AfxEnumThreadWndProc (BYVAL hwnd AS HWND, BYVAL lParam AS LPARAM) AS WINBOOL
   DIM dwStyle AS DWORD = GetWindowLongPtr(hwnd, GWL_STYLE)
   IF ((dwStyle AND (WS_POPUP OR WS_CHILD)) = 0) AND ((dwStyle AND WS_VISIBLE) <> 0) THEN
      DIM phwndTop AS HWND PTR
      CAST(LPARAM, phwndTop) = lParam
      *phwndTop = hwnd
      RETURN FALSE
   RETURN CTRUE
FUNCTION AfxGetBrowserHandle (BYVAL pwszClassName AS WSTRING PTR) AS HWND
  DIM hwndBrowser AS HWND = FindWindowW(pwszClassName, NULL)
  IF hwndBrowser = NULL THEN RETURN NULL
  DIM dwThread AS DWORD = GetWindowThreadProcessId(hwndBrowser, NULL)
  IF dwThread = 0 THEN RETURN NULL
  DIM hwndTop AS HWND
  EnumThreadWindows(dwThread, @AfxEnumThreadWndProc, CAST(LPARAM, @hwndTop))
  RETURN hwndTop
' Retrieves the top level window handle of Intenet Explorer.
FUNCTION AfxGetInternetExplorerHandle () AS HWND
   RETURN AfxGetBrowserHandle("IEFrame")
' Retrieves the top level window handle of Firefox.
FUNCTION AfxGetFireFoxHandle () AS HWND
   RETURN AfxGetBrowserHandle("MozillaWindowClass")
' Retrieves the top level window handle of Google Chrome.
FUNCTION AfxGetGoogleChromeHandle () AS HWND
   RETURN AfxGetBrowserHandle("Chrome_WidgetWin_1")
Pages: 1 [2] 3 4
