Author Topic: Colors & Fonts - Color items background colors display differently than selected  (Read 650 times)
Bruce Huber
  • FireFly3 User
  • Little Newbie FireFly
WinFBE (ver. 1.5.6 64-bit)
Windows 10 64-bit
Tried to modify the Visual Studio Code (Dark) theme colors...
In Colors & Fonts I've set the Window background to 0,34,64 and then I set the background of most of the items with background colors to the same value and all of the values look good in the dialog when I go back in to it.  But all of those items display with a 0,34,0 background color instead.
I've created a new theme "Bruce (Dark)" with the same color parameters - but it displays the same problem.
Could someone point me to where the theme record's color layout and format is in the code - (or where it's documented)?
I thought I would try to manually change it in the WinFBE.ini file and see if that would stick, but it is not obvious where (and what) the color settings are in the theme record.
Bruce
  • Master Member
Hi Bruce, if the code is broken then I'll certainly fix it. Here is how colors are saved... WinFBE saves the collection of colors as a "Theme". The theme is saved to the WinFBI.ini file in the section called "[Themes]". The code that saves the data to disk is found in clsConfig.inc in the SaveToFile function (around line 450).
   Print #f, ""
   print #f, "[Themes]"
   print #f, "SelectedTheme="; this.SelectedTheme
   for i as long = lbound(this.Themes) to ubound(this.Themes)
      print #f, "THEME_"; Right("00" & Str(i), 2); "=";
      print #f, this.Themes(i).id; ",";
      print #f, AfxStrReplaceAny(this.Themes(i).wszDescription, ",|", "_");
      for ii as long = CLR_CARET to CLR_WINDOW
         print #f, "|"; this.Themes(i).colors(ii).nFg; ","; _
                        this.Themes(i).colors(ii).nBg; ","; _
                        this.Themes(i).colors(ii).bUseDefaultBg; ","; _
                        this.Themes(i).colors(ii).bFontBold; ","; _
                        this.Themes(i).colors(ii).bFontItalic; ","; _
                        this.Themes(i).colors(ii).bFontUnderline;
      print #f, ""
I have bUseDefaultBg (Boolean) defined for each color but it currently has no effect.
Here is the sequence of colors:
' Colors
enum
   ' Start the enum at 2 because when theme is saved to file the first parse is the
   ' theme id and theme description. The colors start at parse 2.
   CLR_CARET = 2
   CLR_COMMENTS
   CLR_HIGHLIGHTED
   CLR_KEYWORD
   CLR_FOLDMARGIN
   CLR_FOLDSYMBOL
   CLR_LINENUMBERS
   CLR_BOOKMARKS
   CLR_OPERATORS
   CLR_INDENTGUIDES
   CLR_PREPROCESSOR
   CLR_SELECTION
   CLR_STRINGS
   CLR_TEXT
   CLR_WINAPI
   CLR_WINDOW
end enum
Bruce Huber
  • FireFly3 User
Nothing looked really off to me, between code and themes in the INI... so, I started from scratch with the Default theme - created "Bruce (Default-based)" - and everything worked fine.
So, I'm good - but if it needs troubleshooting...
It is only when I try modifying the "Visual Studio (Dark)" theme - into "Bruce (Dark)" - that I run into the problem.
See if anything looks odd to you here...
Note: I don't see any embedded nulls anywhere.
The four themes from my INI file:
[Themes]
SelectedTheme={9AB98F76-4CAB-4DD0-B0D6-B9091F6B4CE4}
THEME_00={D0BE71A4-A835-4E64-AA5C-E9CEA5511A8F},Default Theme|0,4294967295, 0, 0, 0, 0|32768,16777215, 0, 0, 0, 0|65535,4294967295, 0, 0, 0, 0|16711680,16777215, 0, 0, 0, 0|15461613,4294967295, 0, 0, 0, 0|16777215,0, 0, 0, 0, 0|0,13421772, 0, 0, 0, 0|0,16711680, 0, 0, 0, 0|196,16777215, 0, 0, 0, 0|16777215,0, 0, 0, 0, 0|196,16777215, 0, 0, 0, 0|16777215,7884582, 0, 0, 0, 0|11337901,16777215, 0, 0, 0, 0|0,16777215, 0, 0, 0, 0|16711680,16777215, 0, 0, 0, 0|16777215,4294967295, 0, 0, 0, 0
THEME_01={C8DC7927-89E0-48D8-A35A-F11CEE5BAE23},Visual Studio Code (Dark)|13421772,4294967295, 0, 0, 0, 0|8421504,4282393088, 0, 0, 0, 0|0,4294967295, 0, 0, 0, 0|15780500,4282393088, 0, 0, 0, 0|1973790,4294967295, 0, 0, 0, 0|1973790,4282393088, 0, 0, 0, 0|5921370,0, 0, 0, 0, 0|5921370,4282393088, 0, 0, 0, 0|196,4282393088, 0, 1, 0, 0|1973790,13421772, 0, 0, 0, 0|11896485,4282393088, 0, 0, 0, 0|13421772,7884582, 0, 0, 0, 0|5278147,4203008, 0, 0, 0, 0|13421772,4282393088, 0, 0, 0, 0|13421772,4282393088, 0, 0, 0, 0|4203008,4294967295, 0, 0, 0, 0
THEME_02={1B50F380-B8DA-4334-8E8B-5E1421925CA6},Bruce (Dark)|13421772,4294967295, 0, 0, 0, 0|8421504,4282393088, 0, 0, 0, 0|0,4294967295, 0, 0, 0, 0|15780500,4282393088, 0, 0, 0, 0|1973790,4294967295, 0, 0, 0, 0|1973790,4282393088, 0, 0, 0, 0|5921370,0, 0, 0, 0, 0|5921370,4282393088, 0, 0, 0, 0|196,4282393088, 0, 1, 0, 0|1973790,13421772, 0, 0, 0, 0|11896485,4282393088, 0, 0, 0, 0|13421772,7884582, 0, 0, 0, 0|5278147,4203008, 0, 0, 0, 0|13421772,4282393088, 0, 0, 0, 0|13421772,4282393088, 0, 0, 0, 0|4203008,4294967295, 0, 0, 0, 0
THEME_03={9AB98F76-4CAB-4DD0-B0D6-B9091F6B4CE4},Bruce (Default-based)|16776960,4294967295, 0, 0, 0, 0|8421504,4203008, 0, 0, 0, 0|0,4294967295, 0, 0, 0, 0|52479,4203008, 0, 0, 0, 0|4203008,4294967295, 0, 0, 0, 0|8421504,4282393088, 0, 0, 0, 0|8421504,0, 0, 0, 0, 0|16777215,0, 0, 0, 0, 0|255,4203008, 0, 1, 0, 0|4203008,0, 0, 0, 0, 0|8978431,4203008, 0, 0, 0, 0|16777215,7884582, 0, 0, 0, 0|65280,4203008, 0, 0, 0, 0|15461613,4203008, 0, 0, 0, 0|16776960,4203008, 0, 0, 0, 0|4203008,4294967295, 0, 0, 0, 0
And the same themes rolled out in a CSV file for easy, comparative viewing in something like the NirSoft CSV Viewer, or Excel. (column headers included):
THEME,CARET-FG,BG,dfltBg,bold,ital,uline,COMMENTS-FG,BG,dfltBg,bold,ital,uline,HIGHLITE-FG,BG,dfltBg,bold,ital,uline,KEYWORD-FG,BG,dfltBg,bold,ital,uline,FOLDMARG-FG,BG,dfltBg,bold,ital,uline,FOLDSYM-FG,BG,dfltBg,bold,ital,uline,LINENUM-FG,BG,dfltBg,bold,ital,uline,BOOKMARK-FG,BG,dfltBg,bold,ital,uline,OPERATOR-FG,BG,dfltBg,bold,ital,uline,INDENT-FG,BG,dfltBg,bold,ital,uline,PREPROC-FG,BG,dfltBg,bold,ital,uline,SELECT-FG,BG,dfltBg,bold,ital,uline,STRINGS-FG,BG,dfltBg,bold,ital,uline,TEXT-FG,BG,dfltBg,bold,ital,uline,WINAPI-FG,BG,dfltBg,bold,ital,uline,WINDOW-FG,BG,dfltBg,bold,ital,uline
Default,0,4294967295, 0, 0, 0, 0,32768,16777215, 0, 0, 0, 0,65535,4294967295, 0, 0, 0, 0,16711680,16777215, 0, 0, 0, 0,15461613,4294967295, 0, 0, 0, 0,16777215,0, 0, 0, 0, 0,0,13421772, 0, 0, 0, 0,0,16711680, 0, 0, 0, 0,196,16777215, 0, 0, 0, 0,16777215,0, 0, 0, 0, 0,196,16777215, 0, 0, 0, 0,16777215,7884582, 0, 0, 0, 0,11337901,16777215, 0, 0, 0, 0,0,16777215, 0, 0, 0, 0,16711680,16777215, 0, 0, 0, 0,16777215,4294967295, 0, 0, 0, 0
VS(Dark),13421772,4294967295, 0, 0, 0, 0,8421504,4282393088, 0, 0, 0, 0,0,4294967295, 0, 0, 0, 0,15780500,4282393088, 0, 0, 0, 0,1973790,4294967295, 0, 0, 0, 0,1973790,4282393088, 0, 0, 0, 0,5921370,0, 0, 0, 0, 0,5921370,4282393088, 0, 0, 0, 0,196,4282393088, 0, 1, 0, 0,1973790,13421772, 0, 0, 0, 0,11896485,4282393088, 0, 0, 0, 0,13421772,7884582, 0, 0, 0, 0,5278147,4203008, 0, 0, 0, 0,13421772,4282393088, 0, 0, 0, 0,13421772,4282393088, 0, 0, 0, 0,4203008,4294967295, 0, 0, 0, 0
Bruce(Dark),13421772,4294967295, 0, 0, 0, 0,8421504,4282393088, 0, 0, 0, 0,0,4294967295, 0, 0, 0, 0,15780500,4282393088, 0, 0, 0, 0,1973790,4294967295, 0, 0, 0, 0,1973790,4282393088, 0, 0, 0, 0,5921370,0, 0, 0, 0, 0,5921370,4282393088, 0, 0, 0, 0,196,4282393088, 0, 1, 0, 0,1973790,13421772, 0, 0, 0, 0,11896485,4282393088, 0, 0, 0, 0,13421772,7884582, 0, 0, 0, 0,5278147,4203008, 0, 0, 0, 0,13421772,4282393088, 0, 0, 0, 0,13421772,4282393088, 0, 0, 0, 0,4203008,4294967295, 0, 0, 0, 0
Bruce(Default),16776960,4294967295, 0, 0, 0, 0,8421504,4203008, 0, 0, 0, 0,0,4294967295, 0, 0, 0, 0,52479,4203008, 0, 0, 0, 0,4203008,4294967295, 0, 0, 0, 0,8421504,4282393088, 0, 0, 0, 0,8421504,0, 0, 0, 0, 0,16777215,0, 0, 0, 0, 0,255,4203008, 0, 1, 0, 0,4203008,0, 0, 0, 0, 0,8978431,4203008, 0, 0, 0, 0,16777215,7884582, 0, 0, 0, 0,65280,4203008, 0, 0, 0, 0,15461613,4203008, 0, 0, 0, 0,16776960,4203008, 0, 0, 0, 0,4203008,4294967295, 0, 0, 0, 0
CURIOUS... What numeric format are the color values themselves?  Some of the decimal numeric values are obvious.  But some of those background colors are really big numbers... They don't appear to be a decimal format of an RGB value.
« Last Edit: December 04, 2017, 10:47:34 PM by Bruce Huber »
  • Master Member
The color values are returned from Jose's wrapper AfxChooseColorDialog (AfxWin.inc line 896), which is a wrapper around the WinAPI function ChooseColor. https://msdn.microsoft.com/en-us/library/windows/desktop/ms646912(v=vs.85).aspx
It is essentially a LONG value (COLORREF which is a define for DWORD). To create the value you can use FB's BGR function.
Bruce Huber
  • FireFly3 User
Update on the theme color problem:
There must have been a control character in the Visual Studio (Dark) theme record in the WinFBE.ini file.
(I had only looked for null chars before).
I was having strange problems - like WinFBE hanging on the WinFBE.ini file (via Process Monitor) during an exit, instead of closing down.  So I went in and deleted the VS theme and my attempted clone of it - leaving just the Default theme and my new clone of that.  Now WinFBE is working fine again.
