WinFBE Suite 1.6.4 (June 3, 2018)
Started by Paul Squires, June 03, 2018, 11:07:44 AM
Version 1.6.4 (June 3, 2018)
- Fixed: Tweak code related Codetips to fix several regressions preventing TYPE elements from displaying.
A Minor Test
Win 7 Pro
Dell Optiplex 9010
WinFBE64 and WinFBE32
Release 1.6.4
No changes to anything - settings left as downloaded.
Win64 Console (Release) and Win32 Console (Release)
Sample Projects (without modifications)
FBPiano                - No Errors.
GraphCtx_Demo         - 32 - No Errors
    - 64 - linking failed: 'C:\WinFBE_Suite\FreeBASIC-1.06.0-win32\bin\win32\ld.exe' terminated with exit code 1
ImageCtx_Demo        - 32 - No Errors
MenuWithIcons        - No Errors.
MonthView            - MSCOMCTR2.OCX not loaded (My setup no doubt)
PickIconDialog        - No Errors.
PickIconDialogRes    - No Errors.
RichOleDemo            - No Errors.
RichOleDemo2        - No Errors.
Split_Button
    - Compiled just once but menu option had no return value. From that point on,
TaskDialog
TaskDialogIndirect    - No Errors.
ToolBar_64px        - No Errors.
ToolBar_64px_res    - No Errors.
ToolBar_256px        - No Errors.
ToolBar_256px_res    - No Errors.
ToolBar_HDPI        - No Errors.
ToolBar_HDPI_Res    - No Errors.
ToolBar_REBAR_Res    - No Errors.
TreeView            - No Errors.
Indentation Guides fixed at "Text" colour
If adding line continuations "_" to existing Function or Sub parameters,
    editor adds End Function or End Sub. Example:
    FUNCTION WinMain (BYVAL hInstance AS HINSTANCE, _
    Code
--------------------------------I hope this is helpful.Clive
Thanks Clive!!!! That was a lot of work you went through and thanks for documenting your findings. I appreciate it. :)
You're welcome, Paul; and thanks for all your hard work.
I don't understand. Are you trying to compile to 64 bit using the 32 bit linker?
32 bit compiled and ran without errors. The 64 bit attempt was unsuccessful with the "linking failed:" error.
I should have written it thus:
GraphCtx_Demo - WinFBE32 Win32 (Console Debug) - No Errors
GraphCtx_Demo - WinFBE64 Win64 (Console Debug) - linking failed: 'C:\WinFBE_Suite\FreeBASIC-1.06.0-win32\bin\win32\ld.exe' terminated with exit code 1
(The above Quote would apply to ImageCtx_Demo error with "- 64" as the second line under the project name, bad shorthand.)
And the path that you are showing is "win32".
Should not be "win64"?
BTW that message isn't very useful. Could you post the contents of the "Compiler Log File" tab?
Thanks for looking into this José.
QuoteFreeBASIC Compiler - Version 1.06.0 (05-27-2018), built for win64 (64bit)
standalone
target:       win64, x86-64, 64bit
compiling:    C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.bas -o C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.c (main module)
compiling C:  C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\bin\win64\gcc.exe -m64 -march=x86-64 -S -nostdlib -nostdinc -Wall -Wno-unused-label -Wno-unused-function -Wno-unused-variable -Wno-unused-but-set-variable -Wno-main -Werror-implicit-function-declaration -O0 -fno-strict-aliasing -frounding-math -fno-math-errno -fwrapv -fno-exceptions -fno-unwind-tables -fno-asynchronous-unwind-tables -masm=intel "C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.c" -o "C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.asm"
assembling:   C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\bin\win64\as.exe --64 --strip-local-absolute "C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.asm" -o "C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.o"
compiling rc:               C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\bin\win64\GoRC.exe /ni /nw /o /machine X64 /fo "C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\Resource.obj" "C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\Resource.rc"
linking:      C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\bin\win64\ld.exe -m i386pep -o "C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.exe" -subsystem windows "C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\lib\win64\fbextra.x" --stack 1048576,1048576 -s -L "C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\lib\win64" -L "." "C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\lib\win64\crt2.o" "C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\lib\win64\crtbegin.o" "C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\lib\win64\fbrt0.o" "C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.o" "C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\Resource.obj" ".\.wfbe\MenuWithIcons64.o" "-(" -lkernel32 -lgdi32 -lmsimg32 -luser32 -lversion -ladvapi32 -limm32 -lcomctl32 -luuid -lole32 -loleaut32 -luxtheme -lpsapi -lshell32 -lcomdlg32 -lshlwapi -lgdiplus -lddraw -ldxguid -lwinspool -lglu32 -lopengl32 -lfb -lgcc -lmsvcrt -lmingw32 -lmingwex -lmoldname -lgcc_eh "-)" "C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\lib\win64\crtend.o"
.\.wfbe\MenuWithIcons64.o:fake:(.text+0x0): multiple definition of `AFX::AFXISBSTR(void*)'
C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.o:fake:(.text+0x0): first defined here
.\.wfbe\MenuWithIcons64.o:fake:(.text+0x15a): multiple definition of `WINMAIN'
C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.o:fake:(.text+0x499): first defined here
.\.wfbe\MenuWithIcons64.o:fake:(.text+0x465): multiple definition of `WNDPROC'
C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.o:fake:(.text+0x69b): first defined here
C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\bin\win64\ld.exe: C:\WinFBE_Suite\Sample_Projects\GraphCtx_Demo\GraphCtx_Demo.o: bad reloc address 0x0 in section `.data'
linking failed: 'C:\WinFBE_Suite\FreeBASIC-1.06.0-win64\bin\win64\ld.exe' terminated with exit code 1
Project Properties attached.
I have not noticed any problems compiling those sample projects.
Seems weird that you are compiling the GrapCtx demo but there are lines in the error log file that seem to reference the MenuWithIcons project?  (MenuWithIcons64)
