how to read an entire text file into a string?
Started by ChrisC, August 03, 2018, 01:11:33 PM
ChrisC
Hello all
can someone please give me some code to read an entire text file into a string?
and what kind of string shall i use ?  WSTRING or ordinary string
thanks a lot
Pierre Bellisle
Try this...
FUNCTION FileDataGet(BYVAL sFileName AS STRING, BYREF sFileData AS STRING) AS UINT32
Dim hFile        AS HWND
Dim FileSizeLo   AS DWORD
Dim FileSizeHi   AS DWORD
Dim ReturnCount  AS DWORD
sFileData = ""
hFile = CreateFileA(Cast(LPCSTR, STRPTR(sFileName)), GENERIC_READ, FILE_SHARE_READ, _
                     BYVAL 0, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, 0)
IF hFile <> INVALID_HANDLE_VALUE THEN
   FileSizeLo = GetFileSize(hFile, @FileSizeHi)
   sFileData  = String(FileSizeLo, 0)
   ReadFile(hFile, Cast(LPVOID, STRPTR(sFileData)), FileSizeLo, @ReturnCount, BYVAL 0)
   CloseHandle(hFile)
   IF ReturnCount = FileSizeLo THEN
     FUNCTION = ReturnCount
FUNCTION FileDataSet(BYVAL sFileName AS STRING, BYREF sFileData AS STRING) AS UINT32
Dim hFile        AS HWND
Dim WrittenCount AS DWORD
hFile = CreateFileA(Cast(LPCSTR, STRPTR(sFileName)), GENERIC_READ OR GENERIC_WRITE, _
                     FILE_SHARE_READ, BYVAL 0, CREATE_ALWAYS, FILE_ATTRIBUTE_NORMAL, 0)
   WriteFile(hFile, Cast(LPCSTR, STRPTR(sFileData)), LEN(sFileData), @WrittenCount, BYVAL 0)
   SetEndOfFile(hFile)
   CloseHandle(hFile)
   IF WrittenCount = LEN(sFileData) THEN
     FUNCTION = WrittenCount
What kind of string you have to use depends on if the contents of the file are ansi or unicode.
Jim Dunn
#3
(and don't forget about processing line-endings (CR or LF or CRLF))
I usually do something like this:
    fpIN = FREEFILE
    OPEN sfilename FOR BINARY AS #fpIN
    IF ERR THEN
        STDERR "File [" & sfilename & "] could not be opened."
    GET$ #fpIN, LOF(#fpIN), a
    CLOSE #fpIN
    REPLACE $CRLF WITH $CR IN a ' for Windows line-endings
    REPLACE $LF   WITH $CR IN a ' for Linux line-endings
    REPLACE $CR   WITH $CRLF IN a ' for Mac line-endings
Sorry it's "PowerBASIC"... haven't moved to FreeBasic yet...
#5
My CFileStream class works both with ansi and unicode.
#INCLUDE ONCE "Afx/CStream.inc"
USING Afx
' // Ansi
DIM pstm AS CFileStream
pstm.Open(AfxGetExePath & "\TextA1.txt", STGM_READ)
DIM strText AS STRING = pstm.ReadTextA(-1)
' // Unicode
DIM pstm2 AS CFileStream
pstm2.Open(AfxGetExePath & "\TextW1.txt", STGM_READ)
DIM cwsText AS CWSTR = pstm2.ReadTextW(-1)
Besides being easier to use.
With text files, we can use CTextStream instead.
'#CONSOLE ON
#INCLUDE ONCE "Afx/CTextStream.inc"
USING Afx
' // Ansi
DIM pstm AS CTextStream
pstm.OpenForInputA(AfxGetExePath & "\TextA1.txt")
DIM strText AS STRING = pstm.ReadAll
PRINT strText
' // Unicode
DIM pstm2 AS CTextStream
pstm2.OpenForInputW(AfxGetExePath & "\TextW1.txt")
DIM cbsText AS CBSTR = pstm2.ReadAll
PRINT cbsText
