Notepad expl question
Started by Frank Bruebach, April 03, 2024, 09:00:24 AM
Frank Bruebach
hi all, hello paul, can you please fix this Notepad.bas example, doesn't work here
thanks, frank
Examples \Visual_Designer_Projects\Notepad\Notepad.bas
"afxRichEdit.inc"
error in line 1165
' // Loads the resource
   hResInfo = FindResourceW(hInstance, wszResourceName, RT_RCDATA) 'RT_RCDATA
   IF hResInfo = NULL THEN EXIT FUNCTION
warning 3(2) : passing diffeerent pointer types, at parameter 3 of FINDRESOURCEW()
I am not sure why you are getting an error but the code attached to this post works perfectly.
