Creating Excel WorkBooks without Automation
Started by Paul Squires, October 15, 2012, 10:50:42 PM
The FB version works like a charm.
Well done Paul!
Ps: How do one do a Shellexecute in FB?
Shell is slow and shows a DOs window, so that cannot be right.
This is perfect for my needs. Thank you.
-Peter
-Regards
Peter
Quote from: Petrus Vorster on November 13, 2023, 09:25:33 AMPs: How do one do a Shellexecute in FB?
Maybe something like this?
   dim ShExecInfo     As SHELLEXECUTEINFOW
   dim wszCommand     As CWSTR
   dim wszParameters  As CWSTR
   With ShExecInfo
      .cbSize       = Len(SHELLEXECUTEINFOW)
      .fMask        = SEE_MASK_NOCLOSEPROCESS
      .HWnd         = 0
      .lpVerb       = Null
      .lpFile       = wszCommand
      .lpParameters = wszParameters
      .lpDirectory  = 0
      .nShow        = SW_SHOWNORMAL
      .hInstApp     = 0
   End With
   ShellExecuteEx(@ShExecInfo)
#47
Hi Paul
That works pretty well, and it opens the file-open dialogue.
After some struggles, I came up with this :
shellexecute (NULL,"Open","TEST.XML",0,0,1)
This opens the file immediately in Excel, but I was hoping you could take a look and tell me if this is correct or is there a better way to do this?
-Thank you
Peter
-Regards
Peter
