WinFBE new code on GitHub
Started by Paul Squires, June 26, 2016, 09:23:59 PM
The new code should be in Git now. Please let me know if experience any issues.  :)
Quote from: Jose Roca on June 27, 2016, 07:56:38 PM
In clsConfig.LoadFromFile you are passing default.lang as the name of the language file, but default.lang does not exist.
Then you are calling LoadLocalizationFile( Exepath & "\" & this.LocalizationFile ) and returning FUNCTION = 0, when it should be:
FUNCTION = LoadLocalizationFile( Exepath & "\" & this.LocalizationFile )
and in WinMain you should check the success or failure of loading the localization file.
' Load configuration file
IF gConfig.LoadFromFile() = FALSE THEN RETURN FALSE
It is GPFing because loading the localization file is failing and then the program is trying to access a non dimensioned array.
I think you might be using old code? I am pretty sure that I changed the default value for the this.LocalizationFile equal to "english.lang".
I will double check the returning TRUE logic and add it based on your suggestion. Thanks Jose
I am changing a little bit of code related to the selection of the localization file. I am also going to add an error message should the language files be missing and then abort loading the application.
Okay Jose, the new code is on GitHub now. I moved the loading of the language file to WinMain and am aborting the application should the language file not be found or loads incorrectly.
Modified español.lang file.
In UpdateMRUMenu you're using WStr("(Empty)") instead of L(11,"(Empty)").
Thanks Jose, I have fixed the "Empty" problem and added the updated Spanish file. I have also corrected a problem in the UpdateMRUList code where I was not converting the "{CURDRIVE}" parameter to the current drive letter before comparing filenames in the current MRU list to see if it already existed.
All code is now in GitHub.
AndAlso is not highlighted as a keyword.
Quote from: Jose Roca on June 27, 2016, 10:14:46 PM
Yes, there are a few keywords like that. OrElse is another one.
I am hoping to add a new option to the Environment Options window to allow the user to easily type in the FB keywords (rather than having to manually edit the text file).
I will start updating the keyword list as I notice them. I should have already updated the AndAlso, OrElse ones but simply forgot to do so.  :)
Modified the Spanish language file to fit the Find dialog controls.
Quote from: Jose Roca on June 27, 2016, 10:24:39 PM
Awesome! I was hoping that there existed shorter words!  :)
Well, "Find next" translates as "Buscar siguiente" or "Buscar siguiente ocurrencia", but it is too long for a button.
I made the first translation without knowing where it was going to be used. In the context of the find dialog, "Siguiente" fits the size of the button and its understandable.
Question: Do you ever sleep?   :)
Isn't it like almost 4:00 AM in Spain right about now.
Like the Count Dracula, I go to sleep at dawn.
Hahaha, awesome. :)
I am off to bed soon. It is about 11:30 PM here. I have to crawl myself into work in the morning. Hope to get more coding done tomorrow.
