WinFBE 1.3.0 on GitHub (March 24, 2017)
Started by Paul Squires, March 24, 2017, 06:45:34 PM
Ok, looks like I have all of this figured out now. Working on incorporating it into the editor. Hope to post EXE's soon.
...only one problem that I can not figure out why there is an error. For UTF-16 unicode files I need to convert the UTF-8 string in the Scintilla control to a UTF-16 string in order to output it to the disk file. The Scintilla control has been set to use SC_CP_UTF8.
Here is the code that I thought would work but does not. It returns 0 and GetLastError returns 1004 which indicates a bad parameter.
Jose, maybe you know why it does not work?
' Maps UTF-8 string to Unicode (UTF-16)
FUNCTION Utf8ToUnicode(BYREF sUtf8 AS STRING) AS STRING
   dim sUnicode AS STRING
   dim dwLen    as long
   dwLen =  MultiByteToWideChar(CP_UTF8, _                 'Set to UTF8
                       0,                       _          'Conversion type
                       cast(LPCSTR, STRPTR(sUtf8)), _      'UTF8 string to convert
                       LEN(sUtf8), _                       'Length of UTF8 string
                       0,  _
                       0)
   sUnicode = string(dwLen * 2, 0)
' The conversion below returns 0 so need to use GetLastError
print   MultiByteToWideChar(CP_UTF8, _                 'Set to UTF8
                       MB_COMPOSITE, _          'Conversion type
                       LEN(sUtf8), _              'Lenght of UTF8 string
                       cast(LPWSTR, STRPTR(sUnicode)), _  'Unicode string
                       len(sUnicode))             'Lenght of Unicode buffer
print "GetLastError = "; GetLastError()   ' this is code 1004
   FUNCTION = sUnicode
#32
Why don't you use AfxUcode? Even if your function worked, the returned value will be converted by FB to ansi automatically, since the return type is AS STRING.
If you don't want to use AfxUCode for some reason, you need to use and return a WSTRING pointer. First allocate a buffer and cast it to a WSTRING pointer, pass it to MutiByteToWideChar, return it as the result of the function and later deallocate the memory.
Also don't use MB_COMPOSITE.
To be honest, I thought I had tried AfxUcode and it still failed.... I will try again. I believe I used something like:
PUT #f,, **AfxUcode(*psz, CP_UTF8)
Well, it will not be converted to ansi because the returned variable is a string, not a wstring.
Try this function:
PRIVATE FUNCTION AfxUcode2 (BYREF ansiStr AS CONST STRING) AS STRING
   DIM dwLen AS DWORD = MultiByteToWideChar(CP_UTF8, 0, STRPTR(ansiStr), LEN(ansiStr), NULL, 0)
   IF dwLen THEN
      DIM s AS STRING = SPACE(dwLen * 2)
      dwLen = MultiByteToWideChar(CP_UTF8, 0, STRPTR(ansiStr), LEN(ansiStr), CAST(WSTRING PTR, STRPTR(s)), dwLen * 2)
      IF dwLen THEN RETURN s
This works:
               ' convert utf8 to utf16
               dim cws as CWSTR = AfxUcode(*psz, CP_UTF8)
               dim as byte ptr lpBuffer = Allocate(LEN(cws))
               lpBuffer = cws
               put #f, , lpBuffer[0], LEN(cws) * 2
               Deallocate(lpBuffer)
Thanks Jose, your function worked perfectly :)
Here is the code I am using when saving the UTF-16 BOM encoded file.
         case FILE_ENCODING_UTF16_BOM
            ' Output the BOM first
            put #f, , chr(&HFF, &HFE)
            if sciCodePage = SC_CP_UTF8 THEN
               put #f, , Utf8ToUnicode(*psz)
            else
               ' need to convert ansi to unicode
               put #f, , WStr(*psz)
New EXE's uploaded to GitHub. You will need to download the English.lang file as well because new top menu option "File Encoding" added under the Edit menu.
WinFBE will attempt to determine the type of file being loaded. You will notice that files with words such as Jose will load as UTF-8 because of the é character.
You can change file encoding either by clicking on the encoding label in the status bar or by selecting the encoding from the "Edit", "File Encoding" option.
Please let me know if you run into any problems.
lpBuffer = cws
I don't see the need to allocate and deallocate lpBuffer, since it is simply a matter of casting, i.e. lpBuffer = cws does not copy the data, but it simply does cast(ANY PTR, m_pBuffer).
dim as byte ptr lpBuffer = cws
Maybe this will also work:
put #f, , cast(BYTE PTR, cws.m_pBuffer)[0], LEN(cws) * 2
Thanks Jose, I ended up using the function that you posted for the sake of simplicity. I have posted the new EXE's. I will now to see how ganlinlao makes out with the new code and functionality.
Above all, don't use
lpBuffer = cws
lpBuffer = cws will assign a pointer to the CWSTR buffer to lpBuffer. Therefore, Deallocate(lpBuffer) will try to deallocate the CWSTR buffer and the buffer allocated with Allocate won't be deallocated.
ganlinlao
Wow, I'm glad to see the code changes, the status bar of the ANSI and UTF8, Unicode can switch freely, and save the corresponding code file without any problems.
But the GetFileToString function has a problem. If an existing Unicode text file cannot be opened with a string variable, you must use Wstring or wtring ptr.
     if an unicode file:
         dim wsText as wstring*65536  'or  dim wsText as cwstr,  can not use aniStr as string
         if Open( wszFilename for input encoding "utf16" As #f ) = 0  then
               Get #f, , wsText
Thanks
ganlinlao
Hi ganlinlao, thanks for the feedback. Here are the changes I am making to the code. If you can copy them into your code and test then that would be great. I will not be able to post new EXE's for a few more hours yet.
New version of UnicodeToUtf8 function:
' Maps Unicode character string to a UTF-8 string.
FUNCTION UnicodeToUtf8(byval pswzUnicode as wstring ptr) AS STRING
dim sUtf8 AS STRING
'Maps Unicode character string to a UTF-8 string.
sUtf8 = string(LEN(*pswzUnicode), 0)
WideCharToMultiByte(CP_UTF8, _                 'Set to UTF-8
                     cast(LPCWSTR, pswzUnicode), _  'Unicode string to convert
                     LEN(*pswzUnicode), _       'Length of Unicode string
                     cast(LPSTR, STRPTR(sUtf8)), _     'UTF-8 string
                     LEN(sUtf8), _              'Length of UTF-8 buffer
                     BYVAL 0, _                 'Invalid character replacement
                     BYVAL 0)                   'Replacement was used flag
FUNCTION = sUtf8
Replace this portion of GetFileToString (around line 300 of modRoutines.inc)
         ' Convert to UTF8 so it can display in the editor
         ' Need to pass a WSTRING pointer to the conversion function.
         txtBuffer = UnicodeToUtf8( cast(WSTRING ptr, strptr(ansiStr)) )
Basically, I am mapping the raw binary received from loading the file to a WSTRING PTR. I am then feeding that pointer to the new UnicodeToUtf8.
Paul
I have also added code that sets the buffer to dirty whenever a user changes from one file encoding to another. This ensures that the file will be saved with the new encoding.
