Monitoring Command Button in a DO - LOOP procedure
Started by Andy Flowers, December 20, 2005, 06:51:16 PM
Andy Flowers
How do I monitor a Command button click while in a DO-LOOP?
Here is a very simple example:
Global gExitLoop As Long
Function FORM1_CMDENDLOOP_BN_CLICKED ( _
                                  ControlIndex     As Long,  _  ' index in Control Array
                                  hWndForm         As Dword, _  ' handle of Form
                                  hWndControl      As Dword, _  ' handle of Control
                                  idButtonControl  As Long   _  ' identifier of button
   gExitLoop = %TRUE
Function FORM1_CMDSTARTLOOP_BN_CLICKED ( _
   Do
      FF_DoEvents
      If gExitLoop Then Exit Do
   Loop
   MsgBox "loop has been exited"
One of my favorite things is on clicking the button, disable it...then check for the enabled status of the button in the loop.  I saw a lot of web sites doing this and liked it since it eliminates the possibility of it clicking twice and doing something in the loop twice or the global being set again after the loop exits causing unwanted results on entry to the loop again, etc.  And it is a visual notification to the user that they clicked the button and it is stopping/starting/whatever.
Only issues with disabling is if it is the default button sometimes it is drawn funny, and sometimes if it is the cancel button Windows will beep on exiting the app if it is disabled.
Andy Flowers
Thanks - I forgot about the DoEvents function. It works!
