Help for Line connection code
Started by Elias Montoya, August 05, 2006, 10:24:26 PM
Elias Montoya
I have done this code... i was wondering is someobody has a better way
to do this, and if someone can help me in detecting line crossing and
add a separation point if a line crosses another...
A bit messy, help?
%MIA_USED             = &H000000001
%MIA_NORMALSTREET     = &H000000002
%MIA_SEMAPHORE        = &H000000004
%MIA_AVENUE           = &H000000008
%MIA_GROUND           = &H000000010
%LAYER_VISIBLE  = 1
%LAYER_MIXED    = 2
%LAYER_MIXER    = 3
%LAYER_SHADOWS  = 4
%LAYER_BUFFER   = 5
TYPE GLayer
HmemDC  AS DWORD
HMemBM  AS DWORD
HHolBM  AS DWORD
END TYPE
TYPE PuntosType
X AS LONG
Y AS LONG
END TYPE
TYPE LineasType
Col     AS LONG   ' Color
F       AS LONG   ' Flags
P1      AS LONG   ' Point 1 (Start)
P2      AS LONG   ' Point 2 (End)
PA      AS LONG   ' Point 3 (Angle)
END TYPE
GLOBAL Ly() AS Glayer
GLOBAL Punto() AS PuntosType
GLOBAL Linea() AS LineasType
GLOBAL Dragging AS LONG
GLOBAL x1 AS LONG
GLOBAL y1 AS LONG
GLOBAL x2 AS LONG
GLOBAL y2 AS LONG
FUNCTION FORM1_WM_PAINT ( _
                       hWndForm      AS DWORD _  ' handle of Form
                       ) AS LONG
IF ISTRUE(Dragging) THEN
CALL Copy_Layer(%LAYER_BUFFER, %LAYER_MIXER)
Draw_Line(%LAYER_MIXER, X1, Y1, X2, Y2, 1, %RED)
Copy_Layer(%LAYER_MIXER, %LAYER_VISIBLE)
Make_visible(%LAYER_VISIBLE, hWndForm)
Clear_Layer(%LAYER_VISIBLE)
CALL Draw_Whole(%LAYER_VISIBLE)
FUNCTION FORM1_WM_DESTROY ( _
                         ) AS LONG
CALL Delete_Layers()
FUNCTION FORM1_CUSTOM ( _
                     hWndForm      AS DWORD, _  ' handle of Form
                     wMsg          AS LONG,  _  ' type of message
                     wParam        AS DWORD, _  ' first message parameter
                     lParam        AS LONG   _  ' second message parameter
                     ) AS LONG
FUNCTION FORM1_WM_LBUTTONDOWN ( _
                             MouseFlags    AS LONG,  _  ' virtual keys that are pressed
                             xPos          AS LONG,  _  ' x-coordinate of cursor
                             yPos          AS LONG   _  ' y-coordinate of cursor
                             ) AS LONG
SETCAPTURE(hWndForm)
CALL GETASYNCKEYSTATE(%VK_CONTROL)
IF GETASYNCKEYSTATE(%VK_CONTROL) THEN Dragging=1 ELSE Dragging=2
x1 = Xpos
y1 = Ypos
CALL Copy_Layer(%LAYER_VISIBLE, %LAYER_BUFFER)
FUNCTION FORM1_WM_LBUTTONUP ( _
                           ) AS LONG
RELEASECAPTURE()
X2 = Xpos
Y2 = Ypos
FUNCTION = AddNewUnion(X1, Y1, X2, Y2)
Dragging = %false
FUNCTION FORM1_WM_MOUSEMOVE ( _
                           ) AS LONG
X2 = Xpos
Y2 = Ypos
IF ISFALSE(Dragging) THEN
SELECT CASE Start_point(Xpos, Ypos)
 CASE %WHITE       : MOUSEPTR 1
 CASE 1 TO 2000000 : MOUSEPTR 10
 CASE ELSE         : IF GETASYNCKEYSTATE(%VK_CONTROL) THEN MOUSEPTR 5 ELSE MOUSEPTR 1
CALL INVALIDATERECT(hWndForm, BYVAL %NULL, %FALSE)
FUNCTION UpdateLine(LineID AS LONG, Point1 AS LONG, Point2 AS LONG, Point3 AS LONG) AS LONG
 Linea(LineID).P1 = Point1
 Linea(LineID).P2 = Point2
 Linea(LineID).PA = Point3
 FUNCTION = %TRUE
FUNCTION AddNewLine(Point1 AS LONG, Point2 AS LONG) AS LONG
 ERRCLEAR
 REDIM PRESERVE Linea(UBOUND(Linea())+1) AS LineasType
 IF ERR THEN EXIT FUNCTION
 Linea(UBOUND(Linea())).P1 = Point1
 Linea(UBOUND(Linea())).P2 = Point2
 Linea(UBOUND(Linea())).PA = 0
 FUNCTION = UBOUND(Linea())
FUNCTION AddNewPoint(X1 AS LONG, Y1 AS LONG) AS LONG
ERRCLEAR
REDIM PRESERVE Punto(UBOUND(Punto())+1) AS PuntosType
Punto(UBOUND(Punto())).X = X1
Punto(UBOUND(Punto())).Y = Y1
FUNCTION = UBOUND(Punto())
FUNCTION AddNewUnion(X1 AS LONG, Y1 AS LONG, X2 AS LONG, Y2 AS LONG) AS LONG
LOCAL HitLine AS LONG
LOCAL OnPoint AS LONG
LOCAL Pp1 AS LONG
LOCAL Pp2 AS LONG
LOCAL NLP1 AS LONG
LOCAL NLP2 AS LONG
HitLIne = Start_point(X1, Y1)
OnPoint = (Hitline>2000000)
IF (HitLIne>2000000) THEN HitLIne=(HitLIne-2000000)
IF ISFALSE(HitLine) THEN  ' Starts in white area.
NLP1 = AddNewPoint(X1, Y1)
IF OnPoint THEN          'Starts in a point
 NLP1 = HitLine
ELSE                     'Starts in a line
 Pp1 = Linea(Hitline).P1
 Pp2 = Linea(Hitline).P2
 Linea(Hitline).P2 = NLP1
 AddNewLine(NLP1, Pp2)
HitLIne = Start_point(X2, Y2)
IF ISFALSE(HitLine) THEN  'Ends in white area.
NLP2 = AddNewPoint(X2, Y2)
IF OnPoint THEN          'Ends in a point
 NLP2 = HitLine
ELSE                     'Ends in a line
 Linea(Hitline).P1 = NLP2
 AddNewLine(Pp1, NLP2)
FUNCTION = AddNewLine(NLP1, NLP2)
FUNCTION Clear_Layer(LayerNum AS LONG, OPT ClearColor AS LONG) AS LONG
LOCAL RC AS RECT
LOCAL OBMP AS BITMAP
GETOBJECT(Ly(LayerNum).HmemBm, LEN(OBMP), OBMP)
RC.NLEFT   = 0
RC.NTOP    = 0
RC.NRIGHT  = OBMP.bmWidth
RC.NBOTTOM = OBMP.bmHeight
IF VARPTR(ClearColor) THEN
 LOCAL Hbrush AS LONG
 Hbrush = CREATESOLIDBRUSH(ClearColor)
 FUNCTION = FILLRECT(Ly(LayerNum).HmemDc, RC, Hbrush)
 DELETEOBJECT Hbrush
 FUNCTION = FILLRECT(Ly(LayerNum).HmemDc, RC, GETSTOCKOBJECT(%WHITE_BRUSH))
FUNCTION Create_Layers(NumLayers AS LONG, Wid AS LONG, Hei AS LONG) AS LONG
ERRCLEAR
IF UBOUND(LY()) > -1 THEN EXIT FUNCTION
REDIM PRESERVE Ly(NumLayers) AS GLayer
LOCAL Index AS LONG
LOCAL Hdc AS LONG
HDC = GETDC(%HWND_DESKTOP)
FOR Index = 1 TO NumLayers
 Ly(Index).HmemDc = CREATECOMPATIBLEDC(HDC)
 Ly(Index).HmemBm = CREATECOMPATIBLEBITMAP(HDC, Wid, Hei)
 Ly(Index).HHolBm = SELECTOBJECT(Ly(Index).HmemDc, Ly(Index).HmemBm)
 CALL Clear_Layer(Index)
NEXT Index
RELEASEDC %HWND_DESKTOP, HDC
FUNCTION = (ERR=0)
FUNCTION Resize_Layers(Wid AS LONG, Hei AS LONG) AS LONG
ERRCLEAR
IF UBOUND(LY()) < 0 THEN EXIT FUNCTION
LOCAL Index AS LONG
LOCAL Hdc AS LONG
FOR Index = 1 TO UBOUND(Ly())
 DELETEOBJECT SELECTOBJECT(Ly(Index).HmemDc, Ly(Index).HHolBm)
NEXT Index
FUNCTION = (ERR=0)
FUNCTION Delete_Layers() AS LONG
ERRCLEAR
LOCAL Index AS LONG
 DELETEDC Ly(Index).HmemDc
NEXT Index
FUNCTION = (ERR=0)
FUNCTION Copy_Layer(Orig AS LONG, Dest AS LONG) AS LONG
ERRCLEAR
IF Orig < 1 THEN EXIT FUNCTION
IF Orig > UBOUND(LY()) THEN EXIT FUNCTION
IF Dest < 1 THEN EXIT FUNCTION
IF Dest > UBOUND(LY()) THEN EXIT FUNCTION
GETOBJECT(Ly(Orig).HmemBm, LEN(OBMP), OBMP)
BITBLT Ly(Dest).HmemDc, 0, 0, OBMP.bmWidth, OBMP.bmHeight, Ly(Orig).HmemDc, 0, 0, %SRCCOPY
FUNCTION = (ERR=0)
FUNCTION FORM1_WM_CREATE ( _
                        BYVAL UserData AS LONG _  'optional user defined Long value
                        ) AS LONG
CALL Create_Layers(5, 800, 800)
DIM Punto(0) AS GLOBAL PuntosType
DIM Linea(0) AS GLOBAL LineasType
FUNCTION Start_Point(X AS LONG, y AS LONG) AS LONG
FUNCTION = GETPIXEL(LY(%LAYER_SHADOWS).HmemDC, X, Y)
FUNCTION Draw_Line(LayerNum AS LONG, x1 AS LONG, y1 AS LONG, x2 AS LONG, y2 AS LONG, _
                  LineThickness AS LONG, LineColor AS LONG) AS LONG
LOCAL HPen AS LONG
HPen = SELECTOBJECT(Ly(LayerNum).HmemDc, CREATEPEN(%PS_SOLID, LineThickness, LineColor))
MOVETOEX(Ly(LayerNum).HmemDc, X1, Y1, BYVAL %NULL)
LINETO(Ly(LayerNum).HmemDc, X2, Y2)
DELETEOBJECT SELECTOBJECT(Ly(LayerNum).HmemDc, HPen)
FUNCTION = %true
FUNCTION Draw_Square(LayerNum AS LONG, x1 AS LONG, y1 AS LONG, _
                    BYVAL Bs AS LONG, LineColor AS LONG, FillColor AS LONG) AS LONG
LOCAL RC AS RECT
LOCAL Hpen AS LONG
LOCAL HBrush AS LONG
HPen   = SELECTOBJECT(Ly(LayerNum).HmemDc, CREATEPEN(%PS_SOLID, 0, LineColor))
HBrush = SELECTOBJECT(Ly(LayerNum).HmemDc, CREATESOLIDBRUSH(FillColor))
Bs = INT(Bs/2)
MOVETOEX(Ly(LayerNum).HmemDc, X1-Bs, Y1-Bs, BYVAL %NULL)
LINETO(Ly(LayerNum).HmemDc, X1+(Bs*2), Y1-Bs)
LINETO(Ly(LayerNum).HmemDc, X1+(Bs*2), Y1+(Bs*2))
LINETO(Ly(LayerNum).HmemDc, X1-Bs, Y1+(Bs*2))
LINETO(Ly(LayerNum).HmemDc, X1-Bs, Y1-Bs)
CALL SETRECT(RC, X1-Bs, Y1-Bs, (X1+(Bs*2)), (Y1+(Bs*2)))
FILLRECT(Ly(LayerNum).HmemDc, RC, BYVAL %NULL)
DELETEOBJECT SELECTOBJECT(Ly(LayerNum).HmemDc, Hpen)
DELETEOBJECT SELECTOBJECT(Ly(LayerNum).HmemDc, HBrush)
FUNCTION = %true
FUNCTION Make_Visible(LayerNum AS LONG, HwndForm AS LONG) AS LONG
LOCAL HDC AS LONG
LOCAL PS AS PAINTSTRUCT
HDC = BEGINPAINT(hWndForm, PS)
 BITBLT HDC, 0, 0, OBMP.bmWidth, OBMP.bmHeight, Ly(LayerNum).HmemDc, 0, 0, %SRCCOPY
ENDPAINT(hWndForm, PS)
FUNCTION = %true
FUNCTION Draw_Whole(LayerNum AS LONG) AS LONG
LOCAL Index AS LONG
Clear_Layer(%LAYER_SHADOWS, %BLACK)
FOR Index = 1 TO UBOUND(Linea())
 Draw_Line(LayerNum, Punto(Linea(Index).P1).X, _
                     Punto(Linea(Index).P1).Y, _
                     Punto(Linea(Index).P2).X, _
                     Punto(Linea(Index).P2).Y, _
                     1, %BLUE)
 Draw_Line(%LAYER_SHADOWS, _
                     4, Index)
NEXT Index
FOR Index = 1 TO UBOUND(Punto())
 Draw_Square(LayerNum, Punto(Index).X-2, _
                       Punto(Index).Y-2, _
                       5, %BLACK, %RED)
 Draw_Square(%LAYER_SHADOWS, _
                       Punto(Index).X-2, _
                       Punto(Index).Y-2, _
                       5, Index+2000000, Index+2000000)
NEXT Index
JR Heathcote
Elias,
This is what I use to detect if two line segments cross and to calculate an intersection point from the two line segments.  I use this code for real world calculations dealing with large coordinate values hence the use of double precision.  You can convert the input values to a long data type if you wish.
The two line segments cross if the parameters S and T are both in the range of 0 <= S <= 1 and 0 <= T <= 1.  This routine will also tell you if the end point of one line segment falls on another line segment, in this case S or T will be equal to 0 or 1.  The parameter S applies to the first line segment, T to the second.
If the two line segments are parallel the FUNCTION value will be %FALSE.
' Purpose:
' Function to calculate the intersection point of two line segments.  Two
' line segments will intersect if the parameters s# and t# are in the
' range of 0 <= s# <= 1 and 0 <= t# <= 1.
FUNCTION isect2d_LineLine_XY ALIAS "isect2d_LineLine_XY" _
                        (BYVAL X1 AS DOUBLE, _
                         BYVAL Y1 AS DOUBLE, _
                         BYVAL X2 AS DOUBLE, _
                         BYVAL Y2 AS DOUBLE, _
                         BYVAL X3 AS DOUBLE, _
                         BYVAL Y3 AS DOUBLE, _
                         BYVAL X4 AS DOUBLE, _
                         BYVAL Y4 AS DOUBLE, _
                         dIpX AS DOUBLE, _
                         dIpY AS DOUBLE, _
                         S AS DOUBLE, _
                         T AS DOUBLE) EXPORT AS LONG
 LOCAL dSnum AS DOUBLE
 LOCAL dTnum AS DOUBLE
 LOCAL dDenom AS DOUBLE
 FUNCTION = %FALSE
 S = 0#
 T = 0#
 dDenom = (((X2 - X1) * (Y4 - Y3)) - ((Y2 - Y1) * (X4 - X3)))
   IF dDenom = 0 THEN           'Line segments parallel?
 dSnum = (((Y1 - Y3) * (X4 - X3)) - ((X1 - X3) * (Y4 - Y3)))
 dTnum = (((Y1 - Y3) * (X2 - X1)) - ((X1 - X3) * (Y2 - Y1)))
 S = dSnum / dDenom
 T = dTnum / dDenom
 ' Calculate intersection point from line segment 1 using vector equation
 ' of a line.
 dIpX = X1 + ((X2 - X1) * S)
 dIpY = Y1 + ((Y2 - Y1) * S)
 FUNCTION = %TRUE   'Set return status.
HTH
JR
Elias Montoya
Thanks for your time JR!!, i think i can adapt this to my code...
JR Heathcote
Elias,
The intersting thing is you can tell a lot about the geometry of both line segments by examining the values of S and T together.  One other issue that this routine does not cover adequately is the possibility of having two line segments that fall on top of each other.  This routine will report this possibility as a parallel condition which is technically correct, but in this case you would have an infinite number of possible intersection points.
JR
Elias Montoya
Oh no... I forgot something important... This program works only in 32
Bit screen mode... is any lower... it crashes!! Back to the design table...
