commandbutton chg to form in list
Started by Paul D. Elliott, October 05, 2006, 03:32:59 PM
Paul D. Elliott
I'm working on a set of 10 programs based on a common screen layout
with 10 buttons along the bottom that perform set functions. not all buttons
are used in each program so when I start a new program I'm going thru
them and removing the Tabstop attribute from the ones not used. Going
in the Workspace then Properties tab, I select a button then change the
Window Style. when I select the next button, I noticed that the one I just
changed now has a type of Form instead of CommandButton.  If I select
another button then go back to the list, the button that got changed to a
form is generally changed back to a button.
Just a strange occurance and doesn't seem to be hurting anything. but this
has happened thru 4 programs now and I thought that maybe you could
fix it for v3. I'm using v2.75.
