ComboBox enabled or not ?
Started by Jean-Pierre LEROY, March 11, 2007, 06:52:09 PM
Jean-Pierre LEROY
Hello,
I can use FF_Control_Disable or FF_Control_Enable to disable or enable a ComboBox control.
Later in my program, I want to check if a ComboBox control is enabled or not ? how can I do that ?
Thank you.
Jean-Pierre
Use the IsWindowEnabled api function.
IsEnabled = IsWindowEnabled( HWND_FORM1_COMBO1 )
