Controlling another Form...
Started by paulDiagnos, May 25, 2007, 09:03:02 AM
paulDiagnos
Hi guys,
Im interested in controlling another form using power basic. Im quite happy sending messages to the form simply to find the EnumWindows CODEPTR(EnumWindowsProc), 0 and the ParentCallback, and child call backs i need.
i have sucessfully found the window i need and press a button on it using :sendmessage HWND ,%WM_COMMAND, %BN_CLICKED,HwndchilD
but i need to change a activate a tab.  I have tried varius sendmessages but so far no luck.
below i have put some code which might explain a little better what im trying to do...
FUNCTION PBMain AS LONG
END Function
FUNCTION EnumWindowsProc(BYVAL lHandle AS LONG, BYVAL lNotUsed AS LONG) PRIVATE AS LONG
        DIM gsTitle AS GLOBAL STRING
        gsTitle = STRING$(256,0)
        GetWindowText lHandle, BYVAL STRPTR(gsTitle), 256
        gsTitle = EXTRACT$(gsTitle,CHR$(0))
        IF LEN(gsTitle) THEN
              If GSTITLE = "My external Control Panel" Then
                    HWND =LHANDLE
                  Call SetWindowPos(lHandle, %HWND_TOP,0,0, 0, 0,%SWP_NOSIZE)
                    EnumChildWindows(lHandle, CODEPTR(ParentCallback), 0&)
        FUNCTION = %True
End FUNCTION
FUNCTION ChildCallback (BYVAL hWndChild AS LONG, lRaram AS LONG) AS LONG
DIM szClass AS ASCIIZ * %MAX_PATH
DIM szText  AS ASCIIZ * %MAX_PATH
DIM lRes                AS LONG
lRes = GetClassName(hWndChild, szClass, SIZEOF(szClass))
lRes = GetWindowText(hWndChild, szText, SIZEOF(szText))
FUNCTION = 1
END Function
FUNCTION ParentCallback (BYVAL hWndChild AS LONG, lRaram AS LONG) AS LONG
DIM lRes                AS LONG
''If szText = "Calibrate" Then
   put$ filenum, "  Child: Class=" & szClass & " " & "Text=" & szText +$crlf
   'sendmessage HWND ,%WM_COMMAND, %BN_CLICKED,HwndchilD      ' here i have success sending a message to press a button
'##### here is wher ei really want to press a tab
   sendmessage HWND ,%WM_NOTIFY, ,HwndchilD
Function = 1
really hope one of you wizards can help
I assume that your code is able to correctly find the windows handle of the Tab Control, right?
If it can, then you simply need to call the following function to programatically change the tab.
Example:
FF_TabControl_SetTabFocus HWND_FORM1_TABCONTROL1, 2   '<--- tab is zero based
Or, if you know the Form but not the Tab Control handle (and you know the Tab Control ID) then you can do the following:
FF_TabControl_SetTabFocus GetDlgItem( hWndForm, IDC_FORM1_TABCONTROL1), 2
If you don't know the Tab Control ID then you can use EnumWindows to find the Form and then EnumChildWindows on that Form to find the Tab Control windows handle.
If you are enum'ing the child windows and want to test for each of their ID's then you would use the GetDlgCtrlID( hWndControl ) to see if it matches the Tab Control ID. This may be easier than testing for class names.
paulDiagnos
cool, Ok, didnt even think to try the Tab controls in firefly.
il give it a try thanks...
paulDiagnos
worked fine, but also good to have a sneaky look at the ff code gen files.
theres a macro in winapi. TabCtrl_SetCurFocus(hwndchild, 1) gets the job done
thanks again guys
