Passing Data to a tab control form.
Started by John Messingham, October 08, 2007, 02:51:46 PM
John Messingham
Hi All,
I have a form with a tab control and one of the tabs has a grid. I need to pass a parameter from the main form to the tab child form in order to populate the grid.
What is the best way o do this please?
How about using SendMessage to send a user defined message to the TabControl form?
%MSG_POPULATE_GRID = %WM_USER + 100
' In the main form, send the message to the TabControl child form using wParam and lParam values that
' make sense based on what you want to achieve.
SendMessage HWND_FRMTABCHILD, %MSG_POPULATE_GRID, 1234, 0    ' e.g. 1234 could be a customer ID
' In the CUSTOM message handler for the TabControl child form intercept and act on the message
Function FRMTABCHILD_CUSTOM ( _
   Select Case wMsg
      Case %MSG_POPULATE_GRID
         ' wParam holds the customer id
... if this must occur when your Form is initially loading then it would be better to use PostMessage instead of SendMessage.
John Messingham
